NSEFAN
richieb1971 said:Ok, I see why longer trains are needed.
So based on what you guys are saying the railways are doing as good as they can right now? I find that hard to believe.
You could probably squeeze in more trains on the current WCML by using in-cab signalling. However, this was tried in the past when the line was last upgraded. It caused nearly a decade of disruption to the route and had to be downgraded to conventional signalling because project costs were spiralling out of control. (Originally £2 billion, ended up at nearer £10 billion for a scaled-back programme).
Whilst £32 billion sounds like a lot, bear in mind that it will be for the entire route from London to Manchester and Leeds over the course of 20 years, as well as the fleets of trains which will use the line.
Of course, the current lines which will feed HS2 shouldn't be forgotten. I personally would like to see more reopenings and improvements happening alongside to encourage more people out of their cars. If you look at Network Rail's plans for Control Period 5 (2014-2019), you find a long list of improvements all over the country. These will happen regardless of HS2.
