How close does a replacement bus stop need to be to a station?
AlastairFraser
12 Aug 2018
Reading to Wokingham replacement buses calling at Earley, Winnersh Triangle and Winnersh stop at the bus stop on the main road between the two and make no attempt to deviate to the actual stations.
Although at least all 3 stations are relatively close to the A329 - it mustn't be more than a 5 min walk to the station entrance from the respective replacement stops.
There are some pretty hideous distances in other areas from replacement bus stops.
Kilopylae
9 Jan 2018
Oxford and Devon
Great discussion! From my experience with Northern Rail disruptions last winter:
  • Absolute max should be 200m for accessibility compliance (PSVAR regs), but practically, anything over 100m causes chaos during peak hours. Saw this at Leeds when buses stopped near City Square—mobility scooter users struggled badly on cobbles.
  • Best practice?
    • Terminal stations: Use existing bus interchanges (e.g., Victoria Coach Station for London Victoria).
    • Rural stops: Temporary hardstanding within 50m (Network Rail did this well at Aviemore during flooding).
    • TFL’s ‘Wayfinder’ system: Staff with flags guiding to stops <75m away—cuts confusion by 80% based on their data.
  • Hidden snag: Drivers often refuse ‘unofficial’ stops near stations due to insurance risks. Had this at Crewe—buses had to use Nantwich Road (350m away) despite a closer layby.
Ultimately, if it’s not step-free and signed within sightlines of the station entrance, it’s failing passengers. The 2019 ORR report agrees [p. 32].
Thanks for this, it's really interesting.
It seems perverse that bus insurance doesn't cover RRB duties/doesn't ascribe the railway any innate trust to create bus stops! You'd think RRBs are enough of a "thing".
izvor
11 Jun 2014
on the SER
Normans Bay is also situated along a narrow country lane but unsure how that is served..?
Normans Bay was not served by RR buses until about 5-6 years ago, when a shuttle minibus service was introduced to/from Cooden Beach, allegedly in response to a public complaint.
I did a shift there once as a bus controller: the Southern spec was 2 buses to run the half-hourly service, plus one to provide meal breaks, and a standby bus and controller at each end. Double this for early/late shifts to reach the total spec. Total passengers on my shift: zero. Quite a few mild complaints about buses blocking the lanes though!
I wondered if Southern were trying to prove a point, rather like loading costs onto rural branch lines to boost the case for closure, back in the 1950s/60s.
I believe a service of some sort is still offered but on a rather more realistic scale. Maybe like Crowhurst, served by a single minibus to/from Battle.
Dr Hoo
10 Nov 2015
Hope Valley
At Chapel-en-le-Frith the long station access road is unsuitable for full-sized buses with a low bridge and sharp bends. I am not aware of the station ever being used as a train <> bus transfer point other than in a dire emergency.
The trick is to ensure that as far as possible nobody goes up the approach road in the expectation of travel at these times, so signage and possibly staffing is important. Even getting a bus to the foot of the station approach is awkward because of the local road ‘network’ and heavy ‘calming’ of many roads.
A taxi shuttle back to the main RRB route and stops is by far the most customer friendly.
Obviously there may be edge cases of car parked at station on a previous day or whatever but these must be pretty rare.
izvor
11 Jun 2014
on the SER
Cowden was to do with the fact that the road going up to the station was so narrow that generally nothing bigger than a bread van could be used. At the same time, if an oncoming vehicle came in the opposite direction, it would create a very awkward situation! Stopping at the crossroads allows for slightly larger single deckers to be used and as you say is much closer to the village which is where the few punters who do want Cowden probably wish to go.
This is largely true, except that RR buses did stop at Cowden station (in the lane outside, where there is still a bus stop) until, from memory, around 8-10 years ago when it was moved to the present location at the crossroads on the main road, which as you say is nearer to the village, but doesn't have a car park: I would estimate that 90% of users there arrive/depart by car.
I don't know why this move was made, because the route via the station is more direct, and at the time was served by a regular bus route - full-size buses, not bread vans - I drove them regularly! My guess is that there was an "incident" with a driver not familiar with the narrow lanes and it was pulled.
Nutfield was always a problem, RR buses formerly served the station (actually in the large village of South Nutfield) on a one-way loop round the lanes but this too was pulled and buses now stop on the main road in Nutfield village - avoiding the long diversion but no good for the station which is over a mile away up/down a very steep hill. Station staff at Redhill will arrange a taxi for any mobility-impaired pax.
Teds
14 Nov 2023
Cambridgeshire
Not stopping at any other stops than those set by the company because of insurance is a sort of half truth. It is used to justify not adding stops to drop people off which will add to the journey times. The driver cannot agree a stop for one passenger and not for another and agreeing all extra stops would extend the journey times.
Having said that, the driver is at fault if he stops at an unauthorised stop and the passenger falls getting off the bus or something similar.
Most drivers that I worked with would agree additional stops at marked service bus stops in special circumstances such as in the early hours of the morning with 3 people on the bus. Some absolutely won't consider it.
I worked on rail replacement for many years and I don't think I ever heard of a formal complaint about the location of a stop on accessibility grounds. The most inconvenient stops were usually where the station was inconvenient too and the bus stopped outside!
AlastairFraser
12 Aug 2018
Indeed.
Unfortunately, due to the short notice commissioning of many Buxton line RRBs, I doubt you'd have enough time to set up proper diversion signage or personnel most of the time.
davews
24 Apr 2021
Bracknell
This last weekend, and whenever there are RRBs, Longcross station was closed and they make no attempt to run a bus. Yes, no road access to the station but most users live in the adjacent estate which obviously does have road access. Maybe they decided that with the small number of users of Longcross it is just not worth the effort....
CornishDave
2 Jun 2016
In the case of Looe Valley line, the replacement bus stop for Causeland is over a mile away in Duloe up one very steep hill! I should know as I've walked it! :rolleyes: At least its convenient (and quicker) for those who live in Duloe.
Same goes for St Keyne Wishing Well Halt where the bus stops in St Keyne itself.
plugwash
29 May 2015
There does seem to be a huge amount of inconsistency in this, at cheadle hulme the rail replacement busses go past the station entrance, before the busses heading for handforth go round a roundabout and back the way they came (though the busses heading for Bramhall do continue straight on) after passing the station. Meanwhile at Heald green they seem to stop on Styal Road about 260m away from the start of the station approach road. Both suburban stations in the same conurbation, but treated very differently.
Dr Hoo
10 Nov 2015
Hope Valley
Is this sort of ‘inconsistency’ anything more than what can be explained by local road geography, low bridges, dead ends, space (or not) for layovers and so on?
700007
6 May 2017
Near a bunch of sheds that aren't 66s.
In TfL land some routes are perhaps quite strange - one particular oddity is the London Overground service 'X' which operates sometimes when trains do not run between Dalston Junction and New Cross Gate through the East London Line core section. A mixture of awkward road geography, low bridges, the river Thames and tight back streets means this service stops at some stations not usually served by trains (for example, Deptford Bridge) and skips other stations (Shadwell, Wapping and Rotherhithe) normally served by trains.
Shadwell and Wapping would add a lengthy detour and restrict this double deck route to single deckers so it is understandable why neither are served. But the lack of a stop at Rotherhithe (or at least nearby Southwark Park, on current line of route) is a bit confusing. Passengers are told to walk from Canada Water if they want Rotherhithe, which isn't the worst walk in the world provided you know where you are headed to and don't have accessibility needs. Probably to make this worse (and a regular complaint from the public) is southbound buses do not stop at Canada Water station but instead by the Seven Islands Leisure Centre some five or six minutes walk away. Not only does this make the interchange to the Jubilee line needlessly awkward but means there's no common stop with the 'M' replacement service to Clapham Junction either.
Falcon1200
14 Jun 2021
Neilston, East Renfrewshire
In March I used an Avanti RRB from Carlisle to Glasgow which dropped us off at Wellington Street, a full city block, and the busy Hope Street, away from Central station itself. And on Sunday just gone the RRBs from Glasgow to Carlisle were being announced as departing from Wellington Street. Presumably congestion at Gordon Street, right outside Central, is the reason for this, but it is inconvenient for passengers, especially those with large or heavy luggage, often a feature of long-distance services.
Dr Hoo
10 Nov 2015
Hope Valley
But for a journey arriving at Glasgow from The South passengers would typically be alighting well down Platform 1 or 2. This is actually a longer walk than from Wellington Street, to Gordon Street. (And vice versa.)
4 Dec 2011
God Knows
  • Best practice?
I didn't know ChatGPT had an opinion on RRBs. ;)
Nailsea and Backwell has to be one, or at least used to be. Buses can access the road outside the station but I believe the issue is turning around.
GatwickDepress
14 Jan 2013
I think you’re right! Confusing as it’s only RRB’s that stop at this bus stop (despite the timetable behind).
Service buses do use the Wadhurst station bus stop (I was on a 1066 last week that called there), but I'm sure it used to be confusingly marked as an RRB stop with a blue Southeastern flag.
Some other stations in the South East where the replacement bus stops are a long way from the station -as far as know- unless the situation has changed in recent years-
Winchelsea- Stops on A259 in the village as the station is some distance from the village and along a narrow country lane..
Doleham and Three Oaks buses stop on A259 at Guestling Thorn. One stop serves both stations as they are both located along narrow country lanes. Doleham is about a mile from the A259.
Winchelsea buses still depart from outside the New Inn, but the Doleham and Three Oaks bus stop is now outside the Three Oaks pub - a far more civilised place to wait! A conductor told me the reason for the change was safety related, which makes sense.
Normans Bay is deceptively simple, even though the station feels like its in the middle of nowhere. From the Eastbourne direction you just turn off at the Pevensey Roundabout and drive down Sluice Lane, stop at the junction down to the station for passengers (there's never any) then continue on across the level crossing, and it takes you right outside Cooden Beach station. The road is quite wide too from what I remember.
williamn
22 May 2008
Using Wadhurst station again today the sign has been removed which makes me think it *was* related to the RRB rather than the service bus.
dk1
2 Oct 2009
East Anglia
Perhaps we could do with a new thread…
Furtherest Rail Replacement Bus Stop from Rail Station….
A few contenders could be:
Cromford
Entwistle
Dent
Berney Arms
Berney Arms is simple. It doesn’t have any form of RR and the station is simply closed during engineering works etc.
Brundall Gardens is served from a RR stop on Cucumber Lane approx a mile away.
Falcon1200
14 Jun 2021
A longer walk from the back of a long train perhaps, but also a walk which is mostly undercover, does not involve crossing busy roads, has station staff and vehicles available for assistance purposes, and which does not have (as I observed) pedestrians squeezing past while luggage is unloaded from the coach.
darloscott
12 Dec 2013
Stockton
On my old network in the North East the furthest RRB stop we probably served was Great Ayton where buses stopped at the Green near the Royal Oak in the village itself. A mile or 20 min walk (uphill) to the actual station. Caught out one of my friends who was a co-ordinator and contacted me to find out where one of our RRBs was when I told him buses don’t stop at the station. Unfortunately other operators weren’t reading instructions and seemingly went up there!…
Kilopylae
9 Jan 2018
Oxford and Devon
You'd be surprised how many topics of company internal reports ChatGPT has surprisingly detailed opinions about. What a clever machine, eh...
