Joseph_Locke
I don't believe there is any listing at Crewe,
The 1867 east and west curtain walls, and the buildings on the 1-5 island and 6-11 island are all grade II listed
Why would any post HS2 trains pass Crewe at speed?
I understand that currently there are no spare paths available between Crewe and Manchester. So will they will be taking paths from trains that currently DO stop at Crewe?
QUOTE]
I find that rather strange - surely not between Crewe and Wilmslow with 4tph in each direction and with a passing loop in each direction!
I think the paths may re restricted further in to Manchester, so the paths that will be taken will be from local services not from long distance trains that pass through Crewe!
Of course you are correct. Currently there are 3 Pendolino paths into Manchester, 2 via Stoke and 1 via Crewe. If these are used by the 3 HS2 phase 2a trains then the issue for Crewe is losing that stop on the current path via Crewe.I think the paths may re restricted further in to Manchester
I don't think the basic station layout can be rearranged much through its core without demolishing the whole lot which I presume is listed. The LNWR built everything on the cheap and there are spindly pillars holding up random bits of roof everywhere.
I don't think any part of Crewe station is Listed.
Does any heritage listing apply to the buildings on the old island with only platform 12 in use today?
I haven't read the listing in detail (perhaps you can?) but it doesn't mention them explicitly; they will probably come under the heading of "significant but not worth listing" - they date from the 1905-8 expansion, I believe.
A link to the official listing record for the 1867 station:
https://historicengland.org.uk/listing/the-list/list-entry/1436435
On the map search, this appears to be the only set of buildings in the immediate vicinity to be listed. The only mention of the platform 12 island is that a hole was cut in the west curtain wall to provide access to the later facilities.
I think that is pretty conclusive that platform 12 island buildings are not protected, so might be demolished more easily for new facilities if that was advantageous.
Interesting, from the history section, that the very first station, since completely removed, was actually to the north of Nantwich Rd.
You'll need to confirm with a heritage expert, but anything attached to (and fixed inside i.e. ticket counters) a listed building is also listed by default, but not necessarily of any worth, otherwise it would be described in its own right in the listing description. But, in simple terms, Listed Building Consent to demolish, alter or remove would be required. But then we get into Acts of Parliament, Hybrid Bills, permitted development rights and what have you that the rail infrastructure may benefit from.
It definitely would be advantageous to demolish and rebuild the platform 12 island. You could make it double-decker and part of a flyover.... On the map search, this appears to be the only set of buildings in the immediate vicinity to be listed. The only mention of the platform 12 island is that a hole was cut in the west curtain wall to provide access to the later facilities.
I think that is pretty conclusive that platform 12 island buildings are not protected, so might be demolished more easily for new facilities if that was advantageous... .
the road bridge that passes over and the Independent Lines that pass under.
Have you read #31?
Provide access to the Manchester lines and the London "Up" lines by flying over other lines so avoiding flat crossings.A flyover to do what exactly?
So the road bridge would have to be raised. No big deal in the modern age. It's already raised, it can be raised some more.Assuming you're referring to the North junction, that would be very difficult considering the road bridge that passes over and the Indpendent Lines that pass under.
As high as necessary.Id suggest you go look at the Nantwich road at that point, just how high are you expecting it to be raised, based on the fact you are clearing an electrified line with another electrified line and the clearances that requires?
How about you tell me?So how steep is the road down to the roundabout by the Crewe Arms going to be with your plan?
Based on best engineering of minimal clearances of course. GC gauge.
Gross exaggeration.It would be about (or at least) 1 in 4, I would guess!
