Better wire Acton Bank so that some GWML trains can reach Euston...
Assuming you can get across West London Jn and then find a platform at Euston...Better wire Acton Bank so that some GWML trains can reach Euston...
Will be blocks between Xmas and New Year from around 2024.Modern Railways Newsletter this week has item about the extensive alterations that are going to be required at Old Oak Common to integrate the station into the existing network which was revealed in a response to Grand Central Trains request for paths Paddington to Wales
https://www.modernrailways.com/article/five-years-disruption-old-oak-common
Maybe merits a separate thread in due course when the changes start impacting the classic network.
or as in the past running to marlybone and waterloo thou would have to be under dieselBetter wire Acton Bank so that some GWML trains can reach Euston...
For the bi-mode trains?Better wire Acton Bank so that some GWML trains can reach Euston...
prob thinking more for the 387'sFor the bi-mode trains?
Good luck with that surely?Assuming you can get across West London Jn and then find a platform at Euston...
Kind of my point.Good luck with that surely?
Marylebone is a long shot, Chiltern would probably need to thin their service out to let GWR in and the divert would need to be from Didcot. At least diverting to Waterloo is possible from Reading.More chance of getting a path to London Waterloo or Marylebone, but I would think an outside bet for the latter given HSTs (as was) only fitted in one Platform at Marylebone, as I recall.
16 isn't a permanent loss. It actually goes down to 14 for a while.Good luck with that surely?
Platforms 17 and 18 are out of Use already and doesn't Platform 16 follow this December?
Well another excuse for Avanti not to have to run the full service16 isn't a permanent loss. It actually goes down to 14 for a while.
You assume other TOCs would agree to thin out or flex and Victoria would likely add so much time that journey planners just push you a different way.going full speculation but if no one station could take capacity could do the following
Marylebone - Cotswolds services including Cheltenham (2tph cutting out oxford only serivce as Chiltern already serve that route)
Waterloo via reading - Devon and Cornwall services (3tp2h)
Victoria via west london Line - South Wales and Bristol Services (4tph)
Hopefully this will avoid delays caused by needing to get a specific injunction against protesters each time.HS2 Ltd has been granted an "extensive" injunction along the length of the high-speed line from London to Crewe to help tackle unlawful protests.
Has HS2 Ltd missed a significant milestone?
The start of tunnelling from West Ruislip eastwards has been posted for months to start in "August", but there has been no announcement and it is now September.
Check out our TBM cutterhead’s impressive journey back to start the second dig in #Warwickshire ⬇️ . After our first tunnel breakthrough, TBM 'Dorothy' has been dismantled and transported back to the tunnel's north portal.
Interesting that the initial spoil storage and segment delivery logistics at West Ruislip are "temporary".
Maybe the TBMs have to get out of the way at the portal first.
Rail delivery of segments (from the Isle of Grain) will be in place by the turn of the year.
The number of complaints registered by HS2 Ltd again saw an overall fall during the quarter. The latest figures would seem to support the downward trend which has been registered in previous quarters. In some cases this can be attributed to the handling of cases by HS2 Ltd and its contractors but I suspect also that there is a degree of resignation by the public to construction works now that we are well into the main phase.
The primary issues of concern continue to be those of noise, traffic, lighting, dust, and site management.
Phase 2a remains relatively quiet as would be expected at this stage....
No sign of any TBM start-up today.
It's been all over the local news that tunnelling starts today. Unsurprisingly HS2 failed with their commitment to promise to inform local residents before it was due to start.Still no sign of the start-up of the Northolt TBMs at West Ruislip.
