HS2 Euston - Development, design and construction news (not speculation, please)
InTheEastMids
31 Jan 2016
The upper deck over the north end of the train shed (not open to the public)
Take a look on google maps it's quite obvious
The high numbered platforms, it was what used to be called the parcels deck above the platforms.
Based on Google Earth's historic imagery, the bulk of this work was done between June 2022 and November 2023. Does not look to have had much activity since then (latest image seems to be March 2025).
Russel
30 Jun 2022
Whittington
Ah yeah, spotted it straight away on Google Maps!
What was the reason behind removing only a part of it, rather than all?
hwl
5 Feb 2012
Likely just a work in progress
Perhaps Mr Sunak in 2023 had something to do with the work not progressing
The previous plan (currently paused) was to demolish some more of the west side of the station to enable a bigger phase 1 build of the HS2 station (~13-15m at the southern end).
The Parcel Deck roof has been stripped back roughly to the centreline of the P14-P15 island where major support at the platform level below is.
The plan was to:
1) lift the "Middle Siding 2" track, very slightly realign the "Middle Siding 1" track (including approach in throat), build a new temporary platform (new 16) beside "Middle Siding 1" on the current "Middle siding 2" track alignment. This needs some more parcel deck removal due to where the supports are at the country end (hence the cutting back of the parcel deck roof)
2) which enables ripping out the existing P16 track and adjacent ultra wide P16 (with ramp from the parcel deck above) to give HS2 a wider work site.
I'm not sure if any HS2 siding would have been retained.
It is worth noting that the previous HS2 station design involved digging out to the equivalent of 4 floors below the current level and is unlikely to change in the new design.
There aren't many HS2 Euston area drone videos:
This is the most recent I could find quickly:
(I sure there have been more recent ones but search isn't finding them)
One overall HS2 and other infrastructure programme issue is that HMT's total annual capex limit is being hit across all sectors not just transport hence prioritising of some part of HS2 build (even with the core OOC - Birmingham station approaches) so the build will be longer overall.
So while it would make sense to be getting on with Delta Jn - northwards or OOC site prep (given the volumes to be removed from digging out) this will wait till a significant number of other structures north of the Chiltern Tunnel complete (the other useful effect is that requirement for civils staff and non specialised equipment is smoothed out).
Not digging out at Euston is actually probably quite useful in the short term will they start getting on with the Hampstead Road utility diversions (there will also be some buried tram track removal fun)
hwl
5 Feb 2012
When I was in Euston last month I saw workers at the HS2 works there
That was the more recent video I was looking for.
Yes utilities diversion and other slow burning preparation works are still very much is progress on the south part of the site, Granby Road Bridge and further north (not part of the "station" area) needs to be ready for the arrival of the TBM from OOC presumably at some point in late 2027 or early 2028.
The HS2 track level will be significantly below the current concrete ground surface level.
Class 170101
1 Mar 2014
I think the most effective way to do it would be to start removing the building in stages, based on whatever the functional unit of the structure is. You'd probably only have to close 2-4 platforms at a time.
Already lost a couple of platforms. I don't think Euston can afford to lose anymore and keep the current service working.
I suppose you could just close the station, do a controlled implosion and then throw everyone possible at it to clear the rubble off the platforms and get temporary overhead wiring back up - but that would likely take weeks from closure to even partial reopening.
Christmas / New Year period only depending how it falls in relation to the weekends at the beginning and end of the period, the best you will get will be 15 days without causing mass disruption I reckon.
You would never get a 15 day complete closure at Euston. Not even Paddington with Euston diversions would ever get that long. It would be done half station at a time.
Class 170101
1 Mar 2014
Didn't Paddington have some long closures over the Christmas holiday period with Waterloo and Marylebone diversions during Crossrail construction?
In any event I think its is extremely unlikely to get 15 days at Euston at Christmas / New Year and impossible the rest of the year
hwl
5 Feb 2012
It should be possible to remove the parcel deck roof (at the country end) with out any closures. In terms of functional units of construction for minimum closure level it is effectively 2 tracks but would need to two platforms islands on either side to be closed so effectively 4track/platforms at once, potentially more.
London Bridge was done as mostly a series of 4-9 day closures, the ~9day which might be replicateable here.
THe big problems is some platforms are much more useful/usable at Euston than others.
Geogregor
16 Sep 2016
Latest shots from around Euston:
What is this "blue shed" on top of the Granby Terrace bridge? Looks like maybe something to hold utilities temporarily rerouted from Hampstead Road.
hwl
5 Feb 2012
Correct. The Hampstead Road is a major utilities corridor (and plenty of tram rail still buried under the tarmac too).
Nicholas Lewis
9 Aug 2019
Ian Visits has picked up an item that the Crown Estate has taken a 50% stake in the development company setup to exploit the oversite of HS2 Euston station. That in itself isn't going to get the station built but perhaps demonstrates that the government is keen to push this forward.
https://www.ianvisits.co.uk/article...-euston-station-oversite-redevelopment-81268/
Currently, the property company, Lendlease, is the government’s Master Development Partner for Euston and is responsible for developing a master plan for the area above and around the stations. Lendlease has now set up a 50/50 joint venture with the Crown Estate for several of its projects, including the HS2 Euston station redevelopment.
Technically the King owns the Crown Estate but reality is its an independent property investor whose profits go to the government.
Fazaar1889
5 Oct 2022
South East
I mean...a win is a win. Progress is progress. I wonder when the final station design will be released.
