Do the 225s really need replacing? They are only just over 20 years old.
225s on the GWML wouldn't have the acceleration that you'd get from an EMU though. Many of the GWML services stop frequently and so you'd want good acceleration.
What's stopping the Great Eastern upgrading the Ipswich to Norwich section (or Netwrok rail sorry) to 125mph as it's very straight and there's not much traffic the other side of Stowmarket and then putting the 225's there whilst giving a whole new fleet to the ECML as the ECML does look a little like a dogs breakfast of rolling stock at the moment. uniform fleet would be great from a modernity point of view and the 225's have life left but do look a little dated all of a sudden at either end even if the coaches in-between don't.
I know it won't happen but I think they'd be perfect for Great Eastern for many years to come.
If there's nothing blocking 26m coaches getting to Swansea
That's not a bad idea actually, provided you can build a new fleet of mark 5 coaches (with seated DVTs) to run behind the 91s on GWML you might be onto a winner. Seeing as 87s have the same 110mph top speed as 90s, yet are slab-ended, you could perhaps convert the mrk4 TSO(E) cars into DBSOs, to save on the length and weight of the DVT.I like the sound of the Mark 4's with 90's on the GEML... But then what to do with the 91's...
Any problems between Cardiff and Swansea, Bristol and Weston and Swindon and Severn Tunnel Junction (via Cheltenham Spa) can probablly be fairly easily rectified as you say. Whether these can be done cheaply is another matter entirely, and Pembroke Dock's right out for the simple reason if they really would have to widen a tunnel it definiatly cannot be done cheaply. My point is, if you restrict the lines mentioned to 23m mrk4s you might save enough to put the wires up, it would at least go some way towards paying the bill. Personally I think WAG should cough up for wiring the ValleyLines and Cardiff - Swansea on the condition that Westminster pays for the Severn Tunnel diversionary route, the savings from not having to reconfigure any platforms that might be in the way could cover at least part of the diversionary route.Well seeing as the current plan has Bi-mode IEP's running services to Swansea I'd suggest there is no problem or if there is, it can be rectified quite easily.
That's not a bad idea actually, provided you can build a new fleet of mark 5 coaches (with seated DVTs) to run behind the 91s on GWML you might be onto a winner. Seeing as 87s have the same 110mph top speed as 90s, yet are slab-ended, you could perhaps convert the mrk4 TSO(E) cars into DBSOs, to save on the length and weight of the DVT.I like the sound of that. After all I think mk5 coaches were going to be 26m
I like the sound of that. After all I think mk5 coaches were going to be 26mThat's not a bad idea actually, provided you can build a new fleet of mark 5 coaches (with seated DVTs) to run behind the 91s on GWML you might be onto a winner. Seeing as 87s have the same 110mph top speed as 90s, yet are slab-ended, you could perhaps convert the mrk4 TSO(E) cars into DBSOs, to save on the length and weight of the DVT.
I believe a 390 will reach 125 mph much quicker than a class 91 and mark 4 coaches will though?Acceleration really doesn't come into it until "frequent stops" is at suburban levels. HSTs and electric hauled trains will typically hit top speed faster than an EMU as whilst the initial acceleration is lower they can maintain acceleration longer.
As I have said though, due to the frequent stops on the GWML you really need an EMU for this due to the acceleration.
So there are going to be 8 car bi-mode units then, the entire fleet bi-mode fleet won't be 5 car?the 8 car bi-mode
Yep, with all the impracticalities of double manning, lack of walk-through ability between trains and lost space due to cab ends that such an arrangement implies.At least thats how I remember it from when I read it in Smiths. They were proposing two 5 car sets to make 10 car Bi-modes before wernt they?
However that does remove the abilty to split en-route. This was part of the dft specification.Yep, with all the impracticalities of double manning, lack of walk-through ability between trains and lost space due to cab ends that such an arrangement implies.
Yes, two five car trains do admittedly have that efficiency over one nine car train.However that does remove the abilty to split en-route. This was part of the dft specification.
Update according to Todays Railways on the talks between Hitachi and the franchises on detailed layout specification before the final contract signing has resulted in the franchises telling Hitachi that the 8 car bi-mode and electric sets should be lengthened to 9 car. Hitachi has agreed to reform the default set length it provides (since it is a contract to provide the sets for service on a daily basis not just build them) but this change needs the Dft to sign off on it.
