Even better, put a pantograph on one of the coaches.However arent HST's desiel electric? Maybe sticking a panto could be a good way of cutting operating costs if desiel gets expensive?
Im not sure thered be space for the transformer and associated electrical gubbins in the open space made up of the guards van, not to mention whether the increase in axle weight would be acceptable. Theyre getting on a bit now as well.However arent HST's desiel electric? Maybe sticking a panto could be a good way of cutting operating costs if desiel gets expensive?
Considering the fact that they may remain in service for another 25 years, I wouldn't exactly call them old.Theyre getting on a bit now as well.
I would. 35 years for the oldest production power car is a respectable age for a diesel locomotive on the railways, especially one that has remained in front line service doing exactly the same demanding job throughout that time, even with three new handles and five new blades. In 25 years theyll just be ancient.Considering the fact that they may remain in service for another 25 years, I wouldn't exactly call them old.
How much more does a tiliting train vehicle cost than a normal one? Infrastrure wise, the only cost should be that of the electrification (unlike Pendos, APT didn't use a tilt-athorisation system did it? so perhaps such a system wouldn't be needed on the routes in question). Costpeed benifit wise, I think you may be right in that, once IC125s are gone, wiring via Bristol and sending everything that way would be better. However, might you not also have to quadruple sections of the Reading to Taunton via Bristol route to provide sufficient capacity for all the services on the route?
I think alot of Cardiff - Swansea (Cardiff to somewhere between Port Talbot and Neath) can probablly take 100mph anyway. Without adding to the frequency to allow some London trains to ommit Bridgend, Port Talbot and Neath there's not going to be much in the way of time savings there. I'd be supprised if the trains would really have space to accelerate beyond 100mph without missing those stations out.
HSTs are the wrong type of Diesel Electric and would take a hell of a lot of work to convert, unlike the 22x series, the only type easy to convert.
If you want a more detailed explanation let me know and I'll either PM or post, but I won't bore everyone now.
(please don't get into an argument about swapping locos at Swansea so Pembroke Dock can get 225s - realistically loco-swaps are too much hassle for TOCs)
Im guessing somthing to do with the three phase power supply?
I'd be interested (though probably won't understand). Did the Hitachi hybrid experiment completely replace the electrical systems?
I think this whole idea shows just how good a base design the 22x is, particularly given the awesome reliability the maintenance guys achieve with them.
You will want a third rail pick up on your pantograph cars for XC...? Easy to do? Shame you can't do it on the 171s.
OK, yes that is the quick explanation, hope it makes some sense.
Voyager Leasing is, as far as I am aware, a partnership between Angel Trains and Lloyds Bank.Am I right in thinking Virgin Group owns the trains (through Voyager Leasing)?
Or is it some faceless bank?
It's possible that Voyagers could be cascaded to the Paddington to Plymouth/Penzance route to allow earlier retirement of HSTs.additional Pendolinos could be ordered, to allow the Voyagers to join the standard XC fleet which would also already have panto cars by that point. In short, it makes sense to do all the 22X fleets at the same time.
I hope not, Crosscountry really need the additional Voyagers, especially if passenger numbers continue to climb. Theyve got five HSTs of their own, which makes for a very small non-standard fleet, which theyll have to get rid of at some point (Not that I want to see them go).It's possible that Voyagers could be cascaded to the Paddington to Plymouth/Penzance route to allow earlier retirement of HSTs.
Or you could just add pantograph cars the the 222s and keep them on the MML. If you are going to electrify the MML though I'd also electrify Bristol to Plymouth so that almost all intercity services can go over the EMU operation. There may not be a business case for it now but a lot can change in 15 years. As for just cascading Voygares to the Paddington to Penzance route, I wouldn't put that beyond the dft.It would be better to see the MML electrified by 2025/2030 and the Meridians moved over to replace FGWs remaining HSTs on the South West services (At about the time they’ll be due a big mid-life overhaul and refurb), with a new fleet of electric IEPs on the MML.
Admittedly, neither would I. The DfT works in mysterious ways.As for just cascading Voygares to the Paddington to Penzance route, I wouldn't put that beyond the dft.
I wish they could do it with 171s, but unfortunately, they're not DEMUs...
I think one major point of caution about the pantograph cars is that they have the potential to screw with reliabilty, at least for a while. Obviously not a good reason to abandon them, and I am totally for them.
EDIT: Just going to slip this link in... http://www.publications.parliament.uk/pa/cm201011/cmselect/cmtran/writev/economy/te89.htm
Unless there is electrification, a DMU is what you will most likely be getting in the future.Dear god no, I don't fancy 5 hours on a DMU
It would be better to see the MML electrified by 2025/2030 and the Meridians moved over to replace FGWs remaining HSTs on the South West services (At about the time theyll be due a big mid-life overhaul and refurb), with a new fleet of electric IEPs on the MML.
My idea is some (maybe all if you wire to Chester and base some 57s there to drag Pendos) 221s from Virgin replaced by new Pendos, cascaded to XC with panto cars added. XC 220s would be cascaded to the Cotswolds line with a panto car added (there seems to be a fairly strong opinion on the forums that 180s should go back to the Cotswolds line, and a 220 with a panto car is the nearest you can get to that while making use of the wires from PAD to Oxford). Would be great if the other 220s could have a panto+3rd rail shoe car added for XC's services into 3rd rail zone.
Following that, my current thinking is MML electrification to Corby and Nottingham, replacing the IC125s with EMUs or electric LHCS and putting 222s with panto cars on the other services. That would be followed by wiring Plymouth to Bristol and Zoe's suggested re-routing of all direct services from London to Taunton and beyond via Bristol, completing the replacment of IC125s with all-electric trains (either EMUs or IC225 style trains, the latter provides a new build of LHCS to replace the sleeper stock). I wouldn't stop wiring at Bristol, and carry on through Birmingham to Derby and from there to Doncaster to complete MML wiring and replace 222s with EMUs or electric LHCS. Asuming the Scots get their wires to Aberdeen, most XC services could be EMUs, perhaps with a few 222s for Penzance. The other INTERCITY services beyond Plymouth could be dragged EMUs.
