ChrisCooper
Personally I'd scrap IEP and look for an EMU option to replace the 225s when the time comes. HST replacement is more complicated. It depends really on electrification. With enough electrification, the HST could be replaced with EMUs on the GWML, and also largely on the ECML (remember many HSTs on the ECML these days operate entirely under the wires to places like Leeds). Depending on timescale, I'm sure more could be done to extend the life of the HSTs, e.g power doors on the coaches. For services that go off the wires I'd build 125mph electric locos and coaching stock ("Mk5s"), and 100mph diesels. With fully automatic couplers, changeover time should be small, gained back by removing the need to drag useless equipment around over long parts of the journey. Infill electrification would deal with those routes where short sections were off the wires. The Europeans still like their locos, and if it's good enough for them, surely it's good enough for us. The same could be used on a partially electrified GWML and, if needed, Cross Country. If the GWML electrification was to be delayed beyond the feasable life of the HSTs then I think this could be built into my solution by having a proper "HST 2". This would be a set of "Mk5" coaches sandwiched by two of the diesels, which would be upgeared for 125mph running and feature one streamlined cab (like the 91s, I'd keep a blunt cab for flexability). If electrification occured within the lifetime of the stock, additional 125mph electric locos could be built for haulage under the wires, with the diesels then used for off wire work.
There is no reason why driving trailers could not be included in the coaching stock, steamlined and blunt, the latter maybe even having gangways, preventing the need for running around and allowing easy splitting. In terms of the latter I could see the electric propelling the train to say Edinburgh with a steamlined driving trailer (I avoid DVT, as that implies a wasteful full length luggage van, wheras these would have passenger accomodation) leading, at which point it would propel onto a waiting diesel. The train would then be split with the diesel taking the front part forward, and the rear part and electric loco waiting at Edinburgh. A southbound service would then arrive, propelled by a diesel at the north end with a blunt, corridor fitted driving trailer leading, and would couple onto the waiting stock. The diesel uncouples from the back, and the electric hauls the whole lot to London.
Most of my ideas are straight out of Modern Railways. The interesting thing is, I'd thought the same thing long before reading it. Another part of my idea would be that the new "Mk5" coach design would also be used for units, just as the BR coach designs were, so there would be much commonality between the EMUs and the hauled stock, and also other units of the same design elsewhere on the network.
