IETs (not) banned through Dawlish during rough seas
irish_rail
30 Oct 2013
Plymouth
As above, according to colleagues IETs will now be considered same as voyagers and will not run west of Exeter when dawlish gets a bit rough. Don't shoot the messenger if turns out to be wrong.
irish_rail
30 Oct 2013
Plymouth
The sea has other ideas!!! Keeps knocking out multiple engines. Oh dear oh dear. Bring back HSTs!!!
class26
4 May 2011
Ian`t it in the contract that they must be able to operate through Dawlish even with high waves? If so , could be expensive for Hitachi
northernbelle
10 Oct 2018
First I've heard of this - is this an official policy?
Peter C
13 Oct 2018
GWR land
Interesting.
I hope this gets sorted, if it is the case (I assume you are right - I have no proof to the contrary). As much as I hate the IETs as well, they need to be able to run through Dawlish!
-Peter
As per the Train Technical Specification:
TS1983 Full Functionality of the IEP Trains must be maintained during and after exposure to salt water spray and such exposure must not cause excessive cosmetic degradation of exposed surfaces, components and equipment.
Now I'm not a contract specialist but that seems like a pretty explicit requirement that they should be able to run through Dawlish when there's salty water in the air without failing!
irish_rail
30 Oct 2013
Plymouth
Just going on what I've heard from a colleague could be total BS , but I know there have been multiple incidents of losing engines in past two days and 1703 off padd I believe is down to 1 of 6 engines , time will tell I suppose
irish_rail
30 Oct 2013
Plymouth
I imagine longer term the part of the wall that is normally worst affected (not the bit NR are currently working on) but the bit on Exeter side of dawlish station will have to be raised as well. I hope Hitachi will foot the bill and not taxpayers!!!!
hexagon789
2 Sep 2016
Woah! That's quite some loss of power, isn't it? I don't know the ins-and-outs of the IETs, so I can't comment further really.
-Peter
I'd guess it's a 10-car from the number if engines, so with only one they won't be moving quickly but at least should be able to move
30907
From RTT: 1703 suffered serious problems, looks as if 1-2 others were held back until it was clear of the section and then ran at reduced speed through Dawlish.
pdq
7 Oct 2010
I guess there's 'salt water spray' and there's tonnes of seawater being thrust onto a train.
43096
23 Nov 2015
And one half of the train will have no auxiliary power.
Network Rail have already published options for the entire stretch from Exeter to Dawlish. I suspect it falls under NR responsibility as do the stretches currently in hand or undergoing planning approvals.
hexagon789
2 Sep 2016
Eurgh, that's definitely not an ideal situation. Obviously no air-con, but I presume the lighting is designed to last a few hours without power - running off batteries?
29 Nov 2016
Was just going to post the same, salt water spray and a full on wave strike are two different things. I guess it’s all down to the interpretation of spray, but in no one’s book will a spray be a deluge.
Pete_uk
28 Jan 2017
Stroud, Glos
Any engine will be knocked out if you chuck enough water over it. I guess it's a air intake issue?
9 Dec 2012
I always like watching the Dawlish beachcam on you tube, the humble pacers and 153's take a battering , built to last eh !
Intakes can be designed to avoid water ingress - think the likes of snorkels on Land Rovers. Or boats and ships!
It reads to me like someone missed a trick on the specification, as what happens there is clearly more than spray. Oops.
SuspectUsual
11 Jul 2018
That is a spectacularly badly drafted paragraph. Multiple people here have immediately and rightly seen it doesn’t reflect the reality of what can happen. I’d like to say I was amazed it could get into the specification like that, but this is the DfT so I’m totally unsurprised
Failed Unit
26 Jan 2009
Central Belt
They could have possibly said can keep running along the sea walls in the same conditions as the exist stock. At least dft has some use for all the pacers. To run an emergency timetable between newton abbot and Exeter.
I am sure they are working on a fix and it will cost the taxpayer a fortune as it is a contact variation.
From history hasn’t it operators choice to order IEP for that route. Dft only wanted it for London - Bristol / Wales. FGW choose the IEP? (For sensible reasons of same fleet) if they had gone for another train builder they could still have the same problem.
Pacerman99
23 Apr 2019
Third Rail Land
Aren't the 802s modified, compared to the 800s, specifically to operate through Dawlish? Does this restriction apply to class 802s as well? If so then that seems a big failure from Hitachi.
AM9
13 May 2014
St Albans
That document refers to the IEP but the 802 units were procured separately, so may have different clauses in the specification.
Then if the IET stock is more hardened, swap them in times of need. I'm sure that the GWML services can be run with 802s for a few days per year.
