Incident controller/signaller
Chadh97
17 Aug 2019
Wolverhampton
Would you need a PTS cert for a signaller or incident controller role? Would you need to do a full medical etc as part of it?
thanks
Llanigraham
23 Mar 2013
Powys
Some signallers do have PTS. It depends on where they are stationed.
I would say that Incident Controllers would need it. Certainly MOMs do.
If you are applying for one of those jobs then you WILL need to undertake a medical.
MOM67
6 Mar 2019
Neither role requires PTS but both require a full medical as they are Safety Critical roles.
C J Snarzell
11 Apr 2019
I applied for a role as Customer Information Controller with Northern a couple of months back and there was no mention about needing a PTS certificate. However, like the other forum member has stated, as they are classed as safety critical roles you would have to do the standard medical and pass any screening for drugs and alcohol.
Chadh97
17 Aug 2019
Wolverhampton
Thanks for the info guys. Do you think they’d accept people with hearing aids for signaller jobs that don’t require pts?
Nippy
13 Aug 2013
No reason why not, we have a few at TVSC. An Incident Controller is based in Control (in my case Swindon) and as such does not require PTS.
Llanigraham
23 Mar 2013
Powys
If you can pass the hearing test whilst wearing your hearing aid then it shouldn't be a problem, however you may find that there is a local instruction specifically to YOU that you must always wear your aid, must always have batteries for it, and if it fails you must inform you Manager immediately. That was what happened to me when I started to wear one.
Tom Quinne
8 Jul 2017
You can have a hearing aid, and sub standard eyesight at big multi man locations - but if your a lone worker at a single manned location you’d have to be PTS standard.
Llanigraham
23 Mar 2013
Powys
and
Not correct, see my reply at #11 above.
My hearing deficiency was picked up at one of my medicals after starting and I continued at the Box as before for several years with those provisos added (and sometimes checked by the MOMs on their inspections). It was not the reason I had to retire.
Tom Quinne
8 Jul 2017
I have a restriction placed on my working location - multi manned only - due to my sight.
