When your ticket was checked at multiple times during the 4 - 5 months, was it at the same entry/exit barriers?
twice it was checked at station (on platform bridge) where my last check failed and once or twice in train and once at Station B exit.
The reason I ask is South Western Railway will have access to your journey history on said Oyster card, including the RID hand held device inspection date/timings.twice it was checked at station (on platform bridge) where my last check failed and once or twice in train and once at Station B exit.
This may coroberate the information you have already given to the Revenue Inspector and could also be a mitigating factor as you may have thought you had the correctly loaded ticket!
I can't explain why they didn't notice. If they were properly reading your card then it should have flashed a red light saying that you were outside the zones on your card and it hadn't been touched in. I guess it's possible that doing such a repetitive task might mean they miss it occasionally, but I find it hard to believe that this would happen 3-4 times.
There's an incredibly easy way for this to be overlooked.
If the revenue staff are roving around different locations then they may set up the RID device for a specific numbered zone for the location, or if they are on trains they may set it up for "All London Zones".
Then, when the RID device is used to check, it can distinguish whether or not the products on the card allow travel either at a generic location anywhere in London, or else within a specified zone.
Unfortunately, if the device is set for all zones or for the wrong zone, it's entirely possible the card may be shown as being valid when it isn't (or is only valid for part of the journey).
If the member of staff is switching between different zones and different trains then it's easy to become complacent and set the device up for the wrong task. Many staff probably fall foul of this every day.
It doesn't show a red light of any description, either (you're thinking of the largely redundant MOVie readers, which shouldn't be used as they don't work correctly any more) - a fair amount of digging is sometimes required to determine if a product is actually valid. Sometimes the "No valid product" (or similar) screens will show even though there has been a successful touch-in.
Can you no longer get a Travelcard for one zone? You used to be able toFor the sake of avoiding confusion, you should use the correct terminology.
A Travelcard is a ticket valid for one or several days in two or more numbered zones.
A season ticket is a ticket valid for seven days, a month, or longer. It can be between two named stations (“a point to point season ticket”) or in two or more numbered zones (“a Travelcard season ticket”).
Referring to a point to point season ticket as a Travelcard will cause confusion.
No, minimum of two zones these days.Can you no longer get a Travelcard for one zone? You used to be able to
Glad to hear it. Thanks for letting us know.Quick update - all sorted now. Got out of court settlement letter form TOC and made payment today
