Is Bury St Edmunds-Cambridge valid via Ely?
backontrack
2 Feb 2014
The UK
Just a query:
Would a Cambridge/destinations south of Cambridge - Bury St Edmunds return ticket be valid direct via Newmarket one way and with a change at Ely the other way? Or am I missing something obvious here?
Many thanks (in advance),
-backontrack
Romilly
5 Nov 2013
Yes in the case of a Cambridge-Bury St Edmunds ticket, according to NRE and VTEC.
LexyBoy
Fares Advisor
23 Jan 2009
North of the rivers
Yes, there's no need to use the same route on both legs of a return. In fact, it's common for connexions to work out such that the fastest routes are different depending on direction.
arb
31 Oct 2010
How do you reach that conclusion? If I search for a Cambridge to Bury St Edmunds ticket, NRE offers me a £10.80 off-peak day return for using direct trains via Newmarket, but says I need multiple tickets if I also add in "via Ely" to the search.
Andrew1395
30 Sep 2014
Bushey
I think this governed by local journey rules (as Bury St Edmunds uses Cambridge as its routeing point for this journey) of the Routeing Guide and I would check this out as I doubt the return via Ely is the shortest route.
greatkingrat
20 Jan 2011
Cambridge is a routeing point for Bury St Edmunds so it is only valid routes no more than 3 miles longer than the shortest route. Going via Ely is a lot more than 3 miles longer so would not be valid.
However for longer distance journeys such as Bury St Edmunds - London, both Ely and Cambridge pass the fares check so you can go either way.
Romilly
5 Nov 2013
In my defence I will simply say that putting Cambrige to BSE into the VTEC journey planner without a via point produces itineraries for the offpeak day return some of which are direct (i.e. via Newmarket) and some of which are via Ely.
On the other hand, I must have mis-read the NRE result, for which my apologies.
There would seem to be a discussion to be had as to whether the VTEC journey planner should have offered the itineraries it offered.
