If/when it ever happens I expect this to be the case - I can currently go to Manchester and back for £5.05 with a railcard at "off peak" times, I think it's unlikely that the equivalent single leg pricing (contactless or not) will be two fares adding up to the same amount (adjusted for inflation), it'll be for a lot more.
Indeed, very much so. Single leg pricing has been used as an excuse to :
- reduce the range of fares available in a way that means some people pay more than previously
- introduce evening peak restrictions to some journeys which previously didn't have such restrictions
- prevent Railcard holders getting the full discount where they previously were able to
If Single leg pricing is introduced, the powers that be will be making a huge deal of the benefits while being very quiet about the disbenefits. I wouldn't trust Transport Focus to have any effective opposition to this either.
I would far rather get rid of the obnoxious afternoon peak restrictions, such as Northern's ND:
There are similar restrictions elsewhere, such as to/from Birmingham New Street, as well as London of course.
I have no problem with "cheap after 09:30" although I see the argument you make also, but the afternoon ones are confusing and intimidating - most people don't know that it's not an offence to upgrade on the train if you fall into the excluded times, so will buy a full-fare ticket "just in case". Also you get an issue that if you board a train, say at Manchester Airport to Wilmslow, the cheap ticket isn't valid because it's after 16:00 but people already on the train who joined before 16:00 can use a cheap ticket. It's confusing and should be abolished. |
Under the old Penalty Fares Rules and under the current Conditions of Travel it is stated that anyone using a time restricted ticket at an invalid time should only be subject to an excess fare.
However there are insufficient safeguards in place to ensure this happens; in relation to Penalty Fares the new Guidelines do not mention the entitlement to an excess exists in the NRCoT (I still believe that the NRCoT applies, but this is down to interpretation).
This has resulted in passengers being charged for whole new tickets or, worse, issued Penalty Fares when using time restricted tickets at an invalid time.
As you say, some people either aren't aware of their entitlement to an excess or don't want to risk it, so end up overpaying (or delaying their journey until the end of the evening peak).
There is no prospect of any of this being resolved in a manner that is satisfactory for customers as the DfT will be looking for any changes to either be "revenue neutral" (which means fares go up as well as down!) or, worse and perhaps more likely in this day and age, to see it as an opportunity to increase revenues.
My understanding is that the DfT has a belief to the effect that if any "levelling" of fares has to occur, then as a general rule, they should be levelled
up and not down. However in some (rare) instances they have been forced to level down, due to political (or other) pressures.
