A lot of the growth/ improvements since privatisation seem to have been on the "InterCity" and "Network South East" bits of the old BR.
The services on many bits of the old "Provincial" have seen little improvement, with Pacers and Sprinters still running the same routes, often at the same frequencies.
This is true of other areas of England though, but because some of those routes are part of "London" franchises, it's easy to ignore them. I don't think that "Provincial" routes in northern England have done much worse than equivalent ones elsewhere - but since they are part of EMT/ LM/ FGW they can go under the radar.
Easy for someone to moan about how few new trains "Northern" has had since privatisation but that's only because of the way that the services were split up here. Plenty of 175/ 185/ 220/ 221/ 390s etc running around the "North", it's just that they have different coloured vinyl on the side.
The chip/shoulder interface doesn't help much either
I think we can all agree that DfT, based in London, only look at the country from within the boundaries of Greater London and the Home Counties
Hence the WCRM, the commitments to electrification of the TPML, GWML and MML, all of the infrastructure improvements that we've had?
Yes, we get stock up here, but it's third-hand. London asks for new stock: London gets it
You should maybe google classes like 170s, 175s, 185s, 220s, 221s, 222s, 333s, 390s and other brand new stock introduced in northern England since privatisation?
Maybe even look to the future with 195s, 331, 800s, 801s, 802s and other stock being built right now to serve the north of England?
It'd save you some time, next time you feel the need to rant about how all of our stock is "third hand"
The North of England has a population 3 times the size of Scotland with the population of Yorkshire and Humberside alone being similar to that of Scotland yet Scotland has no Pacers while the North is infested with them, that suggests to me a lot of improvement is long overdue
One big difference is that much of the population of Scotland that you refer to is confined to the area between about Dundee and Ayr - having that population density makes rail much easier/ more attractive.
Plus, Scotland has much simpler "nodes" - there's demand into central Glasgow and demand into central Edinburgh.
Northern England has a much messier mixture of cities - it's not just about Manchester/ Leeds but also about Newcastle/ Liverpool/ Sheffield. Then there's places like Bradford/ Hull/ Sunderland. It becomes harder to provide a simple service, given the number of potential "centres" to serve.
Also worth pointing out that Scotland only has a handful of rural branches - quite long in the case of the WHL/ Kyle/ Far North - but not taking up a large number of DMUs.
In my experience the primary issue is the short trains.
If all the Pacers were actually 3-car Class 172s, and the 185s were 5-car, and the new TPE stock was to be 8-car sets etc, and a few more wires went up, it'd be just fine, I reckon.
I'd generally agree.
Things are much harder to improve around London, where you have lots of busy services already at the natural maximum length (ten/twelve coaches), so it becomes disproportionately expensive to improve their problems.
We don't need expensive solutions to solve every problem in "the North".
In terms of London services, I think they are pretty good. I certainly wouldn't want services from Yorkshire to be much faster as it runs the risk of the area becoming a London dormitory.
You aren't in favour of faster services to London?
My opinion is that in essence "the North" has a rail service which on purely economic grounds could be a lot worse
I agree.
Given the subsidies required to operate the services, just keeping the status quo can't necessarily be guaranteed.
Since nothing is being done to focus on the costs (guards retained, no service cuts even on the weakest branchlines, no routes being converted to cheaper Light Rail, no routes planned to close), is it any wonder that the Government is reluctant to spend more money?
(it bugs me when we just focus on one-off "infrastructure" spending and ignore the large amount of money required for annual subsidies)
I do hope however that the Northern metropolitan areas and counties will take up the Grayling offer to listen to their needs, and make them public.
We've spent years moaning about the lack of devolution... now we moan that "London" won't wave it's magic wand and insists that we are the ones making decisions about improving things in our neck of the woods.
On the subject of HS3 and trans-Pennine in general, it often seems to me as though the slowest section is that between Stalybridge and Pic/Vic, therefore reinstating the four tracks between Guide Bridge to Piccadilly might be a cheaper way to shorten journey times.
Terminating the TPE services in the low numbered platforms at Piccadilly would have solved a lot of that (so that they weren't dependent upon getting a path to cross bits of the station throat to head on to Liverpool or into platforms where they could reverse out to the Airport).
Piccadilly would have been much more efficient if it was operated as three parallel stations that were pretty much operationally independent from each other (in the way that Clapham Junction functions fine because the Southern and SWT/SWR services aren't getting in each other's way).
All water under the bridge now that there's the Ordsall Chord, of course.
