Is the leccy supply to the railway 'just enough'?
Elecman
31 Dec 2013
Lancashire
Given the complexity of the station it may be considered desirable to have granularity in overhead wiring energisation in the station complex.
So they can knock out platforms without taking them all out for example.
Correct and the LMD as well
WesternS
5 Aug 2015
As a software developer I do find your comment extremely condescending and quite harmful to an entire industry, especially the "Agile" method, which when done correct, has been proven in more cases than not to actually produce better quality code, that matches specifications far better.
In my experience, issues are almost always created due to poor specifications or communications. We software developers are NOT railway engineers, train drivers, etc. We dont and more importantly are not EXPECTED to know all the nuances of the railway, just like the engineers and drivers are not expected to know programmign and how software is made.
All the details need to be specified in the requirements, otherwise the developer may not know about it. Indeed, even if a developer sees a issue that is not in the specs, we often do approach the client to try and discuss the resolution to it, and in some cases the client works with us, in other cases, the client doesnt care, putting us in a dilema.
Note the Agile method you are pretty much critisizing orinated in Japan and is used by the Japanese extensively, including Hitachi, having worked with them before. In japanese companies, the software developers and engineers (and all other sections) work better at communicating, hence the "better quality". Sadly in many traditional western companies, there is no such good communication, as well as a lot of interference by accounting, MBEs and other persons who are trying to justify their positions and push costs and other agendas over quality.
I have worked for good companies and poor companies, even different projects within the same company where communication/specifications were great versus very poor, and seen the resulting software.
The well-worn comment from Belfast people about the Titanic springs to mind: "It was alright when it left here".
WAO
10 Mar 2019
I think that both the hardware and software functioned well on the Titanic; it was blundering through an ice field (when other ships were hove to) in the dark with the look outs' binoculars confiscated in order to catch the New York morning papers that caused the disaster, aided by only half filling the life boats.
Janahan's comments:
"In my experience, issues are almost always created due to poor specifications or communications. We software developers are NOT railway engineers, train drivers, etc. We dont and more importantly are not EXPECTED to know all the nuances of the railway, just like the engineers and drivers are not expected to know programming and how software is made."
show why software development so often fails. Engineers have to be in charge of technical solutions and are trained/educated to integrate many disciplines with lateral thinking in technical solutions. Having professionals in narrow, insulated silos, communicating with written specifications rarely works well as there are always items not fully expressed. Where there is a success such as in signalling is where I imagine the software developer has acquired the S&T mindset. Where there are problems such as in the 769's, I suspect that there has not been the same understanding of traction and the need to avoid "sitting down".
Back to topic.
WAO
I have to disagree there. It works more often than it doesn't, you just don't hear nearly as much about the successes.
If it didn't work then organisations would adopt techniques that did - businesses make more money by getting it right the first time than they do cleaning up messes when things go wrong.
Also worth noting that historical successful computerised systems were built over years with the Formal B Method or similar rigorous development tools.
Not the methods that many contractors resort to to cut costs these days....
WAO
10 Mar 2019
I would agree where there is established technology with everyone practiced at what they're doing. Then you can have the accountants, lawyers, administrators and project managers successfully progressing their business cases like clockwork. When there's something new, needing research, development, training or intangible risk, then you need such a senior engineer or other polymath in charge. John Armitt was a recent example that comes to mind. There are also plenty of impeccably managed disasters, such as in Defence.
Physics has precedence over economics.
WAO
WAO
Not that simple. Even if engineers are in charge, there is a risk of lack of co-ordination between engineering disciplines. Very few projects are small enough that one person can understand all the detail.
There's also the issue, discussed above, that engineers will tend to build an engineering solution to whatever they perceive the problem to be. The problem may be misinterpreted, incorrectly specified, or have a better solution that doesn't involve engineering.
Roast Veg
28 Oct 2016
The issue is when you introduce programmers who have absolutely no concept of how their code will be used in the real world.
Most of this can be attributed to laziness and silly management practices - See: Agile.
Agile is rarely well disciplined in the west. We use it notionally, but the project managers working too many projects at once demanding speed of implementation over quality of software leaves us with impossibly large backlogs of "fix it later". I add "TODO"s that I highly doubt I'll ever return to almost every day...
WAO
10 Mar 2019
Engineers (i.e Chartered Engineers) are in charge of relevant projects by law, both in EU and UK. It's just that some outfits restrict that to a signature, not real supervision.
They are (now) educated and trained to degree level both in their own discipline and related ones so that they have common skills. They have management courses and are taught to work in cross disciplinary teams in a sequence of major projects and are tested on communication skills. They then have to take a complementary study to Master's level, after which they must undergo industrial training and responsible experience before qualifying as CEng.
We would not have in our home a gas fitter who is not Gas Safe nor an electrician who is not Part P registered.
There is never zero risk but it can be minimalized.
WAO
WAO
I am a chartered engineer working on major rail projects, with colleagues who are the equals of any in the industry. I assure you there is plenty of opportunity to get things wrong if the disciplines don't work together, or if the client doesn't know what they want.
Elecman
31 Dec 2013
Lancashire
Absolutely
Ken H
11 Nov 2018
N Yorks
Gets worse when people are in different countries and time zones. I am working on a multi disciplinary IT project with developers in UK, Ukraine, Netherland and Germany. We never meet, its all done on teams and email and documents shared on the company cloud.
Except they’re not. I’ve been in charge of hundreds of rail projects, and I am not an engineer.
Of course the designs of the projects were produced, checked and accepted by suitably qualified engineers.
WAO
10 Mar 2019
Agree with all of the above.
There is never zero risk of failing engineers, or doctors, or any other professions.
I do however feel in very good, safe hands with you all!
And the signing off (or not) is by the CEng.
WAO
Jozhua
6 Jan 2019
It doesn't surprise me that Agile is done well in Japan, because the Japanese invent a tool and then use it to a sensible degree while understanding it's limitations. Also see "just in time logistics", which the west takes to an extreme degree and creates "not in time logistics".
In the west, we have an obsession with fads that will magically fix all of our problems and agile is treated as such. "We can get 10X the performance out of our programmers if only for a different management practice!!!!!"
I agree that communication in most Western companies is poor and that accounts/MBEs run around desperately trying to cut costs like they are pulling out the sticks in a game of Kerplunk. Of course the result is a product that doesn't work, unsurprisingly!
Oh yeah, this is true. Although that speed of implementation is called "efficiency". This is all well and good, if you don't care wether or not your software will work in the real world.
WAO
10 Mar 2019
Do we mean MBA's rather than MBE's?
The British Empire can't have been that bad!
WAO
WAO
In the current climate the MBAs may well have managed to get made MBEs thanks to kickbacks to the Government!
Well it doesn't help that we don't appear to design systems for longevity, so we have to constantly reengineer everything every five minutes.
With the availability of Linux and similar tools we have the capability to design "eternal software" and in many cases "eternal equipment", but we don't.
superkev
1 Mar 2015
west yorkshire
I have not looked back to read all of this thread but reading the title perhaps the question should be "Is there enough lekky to supply the uk as a whole".
Many years of incompetent politicians kicking the power geraration can down the road wil eventually come to bite.
Perhaps with its large land portfolio the railway should invest in its own wind farns and storage.
K
I'd much prefer that they agreed to buy a significant portion of the output of a new nuclear plant. Or lease a few SMRs.
K
The railway land portfolio is particularly unsuited to wind generation. For the former, you need wind, obviously. By far the best places to have wind turbines are out on the open sea, or on exposed high ground, and GB railways are notable for their absence at the former and very few at the latter.
There is some mileage in solar generation, but to put it into context, you need a mile of solar panels 5 metres wide in the middle of a sunny day in June to power a typical 4 car EMU (rough calculation). Whereas one large offshore wind turbine can power 10 EMUs at any time with a reasonable level of wind.
Put a few on the embankments around Shap, to slow the wind down a bit and reduce dewirement risk?
[/JOKE]
GRALISTAIR
11 Apr 2012
Dalton GA USA & Preston Lancs
And one nuke ( nuclear power station to make sure I am not misunderstood) will take care of the bloody lot and for foreseeable railway electrification and expansion.
Nicholas Lewis
9 Aug 2019
Biggest wind turbines are currently 8MW in UK waters but Dogger Bank are going to deploy teh 13MW GE - Hallide model.
So A 4car EMU when accelerating need 2MW plus so more like 4 EMUs currently and only when the wind is blowing!!
Siemens have a 14MW turbine; they will be installed at the Sofia wind farm.
I used a 377 @ 1.2MW as a reference 4 car, with a bit to spare in the calc.
Accepting the wind needs to blow, but in this country the wind does blow more often than the sun shines at full whack!
Falcon1200
14 Jun 2021
Neilston, East Renfrewshire
I guess it wouldn't be possible to run an extension lead from Bingley Feeder Station to Skipton and feed Skipton station area only if there was a need to isolate the rest of the line?
IIRC that was done in Glasgow, between Eglinton Street Feeder Station and Polmadie Depot, so that when the main lines past the Depot were isolated it could remain live. Over a much shorter distance however !
Dai Corner
20 Jul 2015
I believe Network Rail do purchase exclusively nuclear generated power for traction.
Though the Welsh Government have gone for renewables for their bit of devolved infrastructure. It's a good job the two systems won't be interconnected at Cardiff!
(Yes I know it's all a paperwork exercise and in reality they'll get whatever mix the grid happens to have at the supply points).
