Heard on th grapevine that in the next few weeks NR are going to announce the Thameslink work at London Bridge will be delayed or descoped.
Things are way over budget :cry:
I think you meant the Central line? The circle line isn't that frequent and is far from self-contained!37 trains per hour is only possible on metro services (e.g. the Circle line) because trains on those lines tend to be self-contained and won't be affected by delays from other services, which will have a knock-on effect on punctuality..
And the cost? £80,000 in 1920 prices.
Passenger modelling is a very important part of this, many rail stations are full to the brim of passengers and can cause a lot of delay in peak periods, Birmingham New Street being one such example. This is all taken into account when assessing new schemes.
Indeed a whole profession is dedicated to it and conferences are held.
This doesn't actually sound a lot does it but I did some timing of this at City and Blackfriars on a regular basis and found most 319 and 377 do it in around this time so its possible.
What does worry me is have anyone seen what happens before the Ashford/Rochester service? Commuters line the platforms by the yellow line blocking all other commuters so image what its like when you start mixing all these different lines on platforms that aren't ideal for all this. I await to see the final design of these trains as I fear the ones we are going to get are going to make matters worse. The easy boarding/exiting of the Alstrom bid made me back this train above the Siemens/Bombardier bids.
Having today (about 6pm) used St P to go down the Wimbledon route to Sutton (first time), I was surprised how empty the station was, and then I got on a rush hour train that could not have been more than 20% full.
Getting on Trains at Victoria or London Bridge at the same time and they are rammed solid - I've even been left on the platform. So perhaps currently the trains don't go where people want to go - except the Ashford/Rochester service.
I don't believe they will fill up trains in 30 seconds when the platform is lined with people for different trains all passing through within 15 minutes - squeezing through will take ages. Especially at City Thameslink, Blackfriars and London Bridge - The latter I expect there will be no seats left.
Hope they have planned it well and maybe frequency of trains is the key that will make it work
Just a quick point about 30 second dwell times. The Southern Region and Southern Railway have been running those sorts of dwell times for years. This is why on inner suburban lines some of the trains had doors at every seat.
This happens day in and day out, and it is a tribute to staff that the service runs as well as it does with timekeeping in excess of 90% on most lines.
It was found with some of the newer trains recently that they take longer to load than the older stock, possibly because of the power operated doors. This is why some of the times were extended and timetables more padded
Think there is some long term intention of running northbound Thameslink train to destinations other than Luton/Bedford. Indeed, just north of St Pancras International (Thameslink basement platforms), there's a new piece of track which would allow Thameslink trains to run upto Finsbury Park and north to Peterborough/Cambridge.
Does anyone know what's happening about this ?
Its not track *yet*. Its a tunnel that they built the same time the works on St Pancras. Its empty with no track, OHLE or signals.
They should keep to the core route that they have today, albeit with more frequent services, and all southeastern and Sutton loop line services terminating at Blackfriars (inconvenient for some, but with a high frequency core service, you won't have to wait long for an onward train).
Maybe run between 6 and 8tph from each of Bedford / Luton / St.Albans through to terminate at either East Croydon (via the South Croydon turnback), Three Bridges or Brighton. Forget about all those other destinations, which all already have good connections along the route. Keep to a simple core route and the line will function, but have trains filtering in from all kinds of places and chaos will inevitably ensue.
Only with that kind of simplicity will the core section be able to handle the train numbers required.
p.s. on a slightly different note, they should reinstate the centre platform at New Cross Gate too, so that Thameslink passengers can change directly onto the East London line, which would cut back on London Bridge congestion for Docklands passengers
A through train is revenue earning service.
I do agree on the "keep it simple" idea though. Changing from the GN to Thameslink is now pretty damn easy, and will be better once all the building work is finished. Whilst it would be nice to be able to travel to the south coast without changing from up here, it's hardly essential.
6tph to/from Cambridge? There's only four I thought? Two Cambridge Express (one splitting to/from Kings Lynn), one semi-fast and one taking all the stops on the Hitchin-Cambridge branch as well as a few south of there? The other Cambridge services (two off peak, up to four in the peaks) are on the West Anglia.
It's all stuff to go wrong. FCC struggled recently to run a service on the sections of TL that had track, overhead lines and signals.
Interesting map to show 2015 Thameslink programme services south of the river.
http://4.bp.blogspot.com/_RZ_ujIXCINU/R_FgXeYLriI/AAAAAAAAAZw/dM83NNzfWj8/s1600-h/thameslink2015.png
