The transcript for the recent industry hearing on the ECML track applications mentions a current project Network Rail are doing called L2E4. Other than saying that this is a project to enable SETs to run at a higher speed, including 140mph in some places, on the ECML there is no other information.
I would be interested in any further information anybody can provide on this project? The scope? Timescales? Areas they are looking at?
It's ETCS Level 2 dependent, so is absolutely in-cab signalling dependent, and in turn means it'll be between Kings Cross and Doncaster by 2020, assuming the ETCS Level 2 roll-out isn't delayed in the cost reviews. The existing signalling is life expired and lacks bi-di in a lot of areas restricting any ability to deal with problems though, so it's a reasonable bet that it will go ahead almost at all costs.
Location wise, it'll be mainly the same places that British Rail planned 140mph running, so around Peterborough and Grantham, south of Doncaster etc.
It will also require replacement of the headspans for the wire runs on 140mph sections of route because the existing ECML wiring isn't capable of 140mph running with multiple pantographs (but can support 140mph running with a single pantograph - i.e the IC225 sets).
The current catenary (primarily contact wire) can't be sufficiently tensioned to deal with the oscillations two pans at 140mph cause, as it's at the limit for tension in relation to diameter, so the contact wire needs to move up to a larger diameter, but a larger diameter contact wire is too heavy for the rest of the headspan components, they too would need upgraded, and that provides Network Rail with a good opportunity to replace headspans.
Network Rail like mechanically independent registration - i.e not headspans, so will be moving the 140mph sections of the ECML to mechanically independent registration, by using a modified variant of the Furrer+Frey Series 1 components.
The lightweight portal boom structure they've developed, chiefly for the twin track cantilever on the GWML, can be fabricated into a full boom, and mounted on the existing headspan masts without problem. The small part steelwork is planned for Series 1 equipment also.
There's a trial boom at Potters Bar with older OLE components which looks good, and there should be a roll out this year of portal booms to replace headspans at key 'high risk' locations - mainly switches and crossovers, where there's a higher risk of dewirements.
