Lancaster to Morecambe Line
rishton82
6 Aug 2014
Would any one know if there is any freight on the Morecambe to Lancaster line. Also at Morecambe there was a third line which extended beyond the station towards the coast, am I correct in thinking that this allows freight trains to access the line to Heysham.
crispy1978
4 Feb 2013
Scarborough
driver9000
13 Jan 2008
The only freight is the flask traffic to Heysham. When BR built the new Morecambe station they provided a headshunt and run round loop for the flask trains but this is no longer used as DRS top n tail the train now.
Iskra
11 Jun 2014
West Riding
It's a mixed use line to Heysham Port- there is also a limited passenger service.
HLE
27 Dec 2013
Believe it's just one passenger train per day to Heysham to connect with the ferry.
TB
8 Aug 2013
1 passenger train a day to/from Heysham and 1 top and tailed nuclear train. Rest of the service is passenger to/from Lancaster with some through to Leeds or Barrow.
Condor7
13 Jul 2012
Penrith
I think this is the only line when twice as many passenger trains run on a Sunday as they do in the week. (Two on Sunday) :D
Buttsy
20 May 2011
Hanborough
Indeed it is. I rode it in early July and on the late Sunday train to Heysham, I was the only passenger to Heysham, but a lady did get on for the return trip.
There has been a bit of house building up to the line in the Heysham area, so my thinking is that if a cheap platform (in the style of Humphrey Park with a ramp down from the overbridge) could be provided by one of the overbridges (Meldon Road area perhaps) and also one by the Westgate overbridge that a regular service down the line could recoup costs within a few of years once more DMUs are available to run it or the route is, once again, electrified.
thenorthern
27 May 2013
As the others have said there is the DRS trains to Heysham Power Station as freight and the rest is passenger trains. There is also 1 passenger train per day which uses the northern chord at Hest Bank an thus avoids Lancaster. If I remember correctly as well there is no cross over between Bare Lane and Morecambe which in effect means the 2 platforms and line are independent of each other at Morecambe.
crehld
1 Nov 2014
Norfolk
Two actually. Weekdays it's 05:46 Lancaster to Windemere and 16:05 Lancaster to Leeds.
Indeed.
DynamicSpirit
12 Apr 2012
SE London
As I recall, Network Rail did look into the possibility of running a few commuter trains along the line some years ago. They rejected the idea on the grounds that the line didn't go near enough to where many people lived to be worth it. Perhaps if there has been house-building near the line, that could be worth looking into again?
Yep. It's effectively not a double track, but two independent single tracks from Morecambe to just east of Bare Lane - only the southernmost track leads to Heysham. I'm not sure why such an apparently odd track arrangement was chosen. It must be confusing for passengers at Bare Lane since it means little consistency of which platform trains depart from - and if I recall correctly, if you get it wrong, the only access between platforms is via the level crossing.
Buttsy
20 May 2011
Hanborough
My understanding is that it is only the Heysham service that ever uses platform 2 at Bare Lane in normal circumstances and so it means you might miss 1 train a day by being on the wrong platform (except Sundays).
thenorthern
27 May 2013
I think it before Morecambe was re-sited in 1994 there was a cross over at the former station which was slightly further on from where the current station presently is. I think it was just laziness that new cross-over wasn't put in when the station was re-sited although given the present station opened just after Railtrack PLC came into existence I am not sure if it was the fault of Railtrack or British Rail. Its a nice little branch though the Morecambe branch line.
rishton82
6 Aug 2014
You may miss the train but surely most people using Bare lane would be locals anyway
Tomnick
10 Jun 2005
The current arrangement of two independent single lines was presumably preferred when Morecambe station was relocated because it meant that the signalling could be heavily rationalised on the branch - effectively nothing beyond Bare Lane. It's quite a clever arrangement in that respect, allowing trains to run to Morecambe and back whilst there's a train on its way to Heysham and back, without having to worry about shutting the latter inside the Heysham branch proper.
DynamicSpirit
12 Apr 2012
SE London
Would that be the case (about not needing signalling beyond Bare Lane)? There are still points at Morecambe to allow access to the Heysham line for reversing trains. I don't know much about signalling, but I would imagine those points would have to be signalled to prevent trains running into points that are set against them.
That does sound very plausible.
I'm sure you're right that most would be locals, but even most locals are unlikely to have memorized the details of which train goes from which platform (except for any particular trains each person frequently uses). I'd be very surprised if a few people haven't been caught out going to the platform 1 (where I believe most trains will depart from) to discover their particular train is one of the few that goes from platform 2, and they can no longer get to it because the level crossing is closing for the train's arrival. (Although admittedly I'm speculating - I haven't regularly used the station since before the Morecambe got moved - so before the odd dual-single-lines arrangement existed).
markydh
30 Jan 2011
Newcastle upon Tyne
Platform 2 is actually uses several times a day because there are a few occasions where local and Leeds services are on the branch at the same time. Doesn't help that the service is so irregular!
underbank
26 Jan 2013
North West England
Only one train at a time allowed on the line, so the points will be set right - the previous train leaving Morecambe to Bare, will mean the points are right for the next one leaving Bare to Morecambe, and the same with trains between Morecambe and Heysham.
Which is why there are now departure boards on each platform. Whilst the signal box was there, the signalman would shout across to passengers who were on the wrong platform. When the signalbox was decommissioned, a network rail worker had to sit in the signalbox to do the same job, but eventually the electronic departure boards were introduced. Yes, indeed, it was confusing for locals, many of whom were accustomed to the traditional/standard method of platform directions on double track lines and who were easily caught out if the signalman didn't notice them before the crossing gates closed!
Dunc108
10 Jun 2013
Morecambe
Bare Lane station had Electronic Passenger Information Screens installed a year or two back - these could be really useful at Morecambe as well as the ticket office is only open limited hours. I have heard they may be on the cards at some point but when they may be installed I don't know.
Its a handy branch service but the irregular timetable is probably due to Branch trains having to fit in between fast Virgin services on the WCML. Had the former direct line via Lancaster Green Ayre closed in 1966 still be in situ the service would have been more frequent and with no conflicts with the WCML, but thats another story! :lol:
Iskra
11 Jun 2014
West Riding
Some nearly missed it the other day due to that issue when I was on board, but luckily the level crossing barriers went up when the train was in the station so they could cross platform.
The service is great at peak times because of the traffic situation around the Lune bridges/Lancaster town centre making buses take ages.
I do wonder if it will be less competitive once the long awaited bypass opens.
thenorthern
27 May 2013
This may seem a strange question but if the the train is delayed and misses the ferry then does the ferry wait?
70014IronDuke
13 Jun 2015
For want of something better to do, prompted by this thread I looked up the passenger numbers for Morecambe and Bare Lane.
I was astonished to find the last data puts that at:
217,000 for Morecambe - 300 on, 300 off per day
168,000 for Bare Lane - 235 on and off per day.
Which I thought is quite something.
Presumably the Morecambe figures are quite season sensitive, and probably mean something like 450 on/off on summer holiday days, and maybe only 200 a day in winter - or does school travel mean a healthy level in winter too?
DynamicSpirit
12 Apr 2012
SE London
I've used the line a few times the last few years - generally daytime during the week, and my impression has been that most people travelling on it are locals - and trains seem to be reasonably well loaded. I have a friend who lives in Morecambe and would use the train rather than the bus to Lancaster because she claimed the train was cheaper - I don't know if that's still the case.
Interesting point. I'd expect it to make some difference, but not a huge amount. It will certainly cause some reduction in traffic at the Lancaster end of the A683 and over the bridges. A long time ago at one of the council open events, it was mentioned that the aim was to take advantage of this to convert one of the 3 lanes on Greyhound Bridge to be a dedicated bus lane - I don't know if that's still the intention, but obviously if that does happen, that could help buses quite a bit.
But on the other hand, the by-pass will only be useful for traffic heading to/from Morecambe from the M6 or from the Caton direction - anything coming from Lancaster itself (which I would imagine accounts for most traffic) wouldn't use it. Also, the very existence of the by-pass is almost certain to attract many more cars, and that could easily lead to existing roads being more, rather than less, congested between Lancaster and Morecambe college (where the by-pass joins the existing network) and Morecambe.
Iskra
11 Jun 2014
West Riding
There's always been a good number of school children using the line. The 2 car 150 from Leeds I was on last week had every seat taken going to Morecambe/Heysham but then was fairly empty on the way back. They do seem to be either packed or half empty in my experience. There were also lots of suitcases onboard indicating long distance travellers. Morecambe is the traditional holidaying destination from Bradford which is easily accessed on the Leeds train.
The train is much cheaper- the bus fares in that area are ludicrous in my opinion.
A lot of traffic, especially lorries go to the ferry terminal from the M6 which currently go through Lancaster (or skirt it), so I think it will make a huge difference. Presumably, the authorities expect it to also considering its a an expensive project that wouldn't be justified otherwise.
It used to take me 45-60mins to do Lancaster Uni-Morecambe Asda at peak times or ferry times, which is probably only about 5 miles.
Spurious question- is your avatar in the trough of bowland? I think I recognise it, jubilee tower looking westwards?
KendalKing
4 Mar 2009
North Lancs
Train vs Bus between Lancaster & Morecambe.
Train takes about 10-mins, and cost £3.10p return
Bus takes about 20-mins+ (depending on traffic), and cost £4.90p return.
I have always said that this line should never had been closed, what a great pity that a group of enthusiasts, didn't buy the line to preserve.
DynamicSpirit
12 Apr 2012
SE London
Wow, well spotted - that's exactly what it is. One of my favourite places. (Although I have to admit, I don't think it works that well as an avatar picture - I keep meaning to change it but never getting round to it...)
Xenophon PCDGS
17 Apr 2011
There was a short-lived intermediate station at Scale Hall that was opened as late as 1957 with concrete sectional platforms, but this became a victim of the closure programmes. I think that the site of that station is now partly used by the road which was widened to give a better road traffic access.
Is the goods yard crane that was preserved on the site of the former Lancaster Green Ayre station still there?
Buttsy
20 May 2011
Hanborough
The points to Heysham are guard worked and locked with a key on the 'staff' issued on the Heysham service. The points are then locked facing Heysham until the train has cleared them on it's return leg, whence they are locked facing Bare Lane again. This adds a couple of minutes to each trip on the Heysham branch.
