Learn to code with Dennis - tutorial 1-3 now available
LondonBVE
22 Dec 2005
Lost!
Dennis I everytime try loading the route, it gives me a list of error that lead your tutorial route to an end.
Dennis
8 Aug 2005
Trowbridge
e-mail (dennislance@hotmail.co.uk) me a zipped copy of the route file and I'll try and highlight the errors.
Mushroom
6 Mar 2006
Altrincham
When I try and run the route i get a 'Train Not Found' message. This happened both with my original attempt at the code and then using the section on code (what it should look like) at the start of tutorial 2.
Any ideas or remedies?
tubenutter
24 Apr 2006
Rugby
Mine works but the link to that german site is broken, you may like to fix that.
Thanks again for the tutorial Dennis -- interesting and fun!
Tom B
27 Jul 2005
Change the train to one you have in your collection.
Dennis
8 Aug 2005
Trowbridge
Thats probably me and my freewebs skills - copy and paste the link into the address bar and it will take you there. I'll try nd fix it, thanks for the alert.
[EDIT]
Make sure the route file is saved in the same directory as your other route files, I use c:\program files\bve\railway\route.dltutorial_1.csv (and my train files are in c:\program files\bve\train\
nutter
13 Nov 2005
Albrighton, Nr. Wolves, Shrops
I'll send them via MSN to you, as a word document. Just get in contact if you spot me online with you
Is the cab supposed to go really dark, especially strange as dark cabs (tunnels etc) dosen't work on my computer. I get the same problem with the 170 on the edinborough-Aberdeen route
LondonBVE
22 Dec 2005
Lost!
Nutter not all routes will turn dark when it enter a tunnel. It is to do with the coding.
nutter
13 Nov 2005
I know, what I'm saying is even on routes which are coded like that, it dosen't work, so why does it 'work' on here.
It isn't the nightime cab which comes up, the day cab just goes dark
NORTH STAR
27 Mar 2006
Berks
darkavenger38 said:
again dennis well done, i am now coming to grips with coding and may code a short but fun route.....slough to windsor and eten central
Regards
Tom
Tom,
If you're going to have a go at Slough-Windsor, I have some information that will be of great use to you. PM me for more info.
Matt
