I've tried Forest Hill to Leyton Midland Road as an example of a journey which could involve changing between Leytonstone Und and High Road. No restrictions are showing, but the SDR is a whopping £11!
How are you getting the itinerary to show changing at Leytonstone as I cannot get journey planners to show it?
I used brfares.com with the usual paramters. Unless I did something wrong?
I will if I have to!If your connection's looking tight, I've run it in around 7 minutes, faster running can do it in maybe 5 or 6!
You quite possibly don't want to run, though. :P
Sorry about the delay in getting back, I didn't expect so many prompt replys!
I'm going from Blackhorse Road (well, TOM probably) - Fairlop. There's no GA service this weekend otherwise I would have gone TOM - Stratford, then up. I always prefer the train (instead of the bus option TFL journey planner suggests) if I can do the connection, no matter how random!
Edit: Hmmm...just had a thought. I think I could take my bike on this journey if I start from Blackhorse Road. Is the Central line is out in the open by the time it reaches Leytonstone? If so then bike should be fine...
You can take them on the tube (excluding DLR) outside rush hour as long as the tube is not deep level stock in a tunnel. I think. Sadly, as you highlight, the Central line goes back underground so not sure I could get away with it. Unless it's possible to go the long way round (ie - Leytonstone to Fairlop via Hainault?) but got a feeling that's only during rush hour.It's in the open at Leytonstone, but then goes back underground until Newbury Park. Fairlop is above ground too though :P I'm not sure what TFL's policy on bikes are though
I could, though, in the taking my bike along example i'd just start at Blackhorse Road as it's closer.Could you start at South Tottenham rather than Tottenham Hale?
Thanks for that link. It is indeed useful but sadly shows what I didn't know - that the Central line plunges back into a tunnel for the short section I want to use!Might be useful: tube map showing where bicycles can be taken. (Note it is just for the tube and DLR, no Overground or other rail services.)
