Whistler40145
Do any of you know nicknames of lines on the Network Rail system?
Steep gradient near Sutton (1:40?), as the line was constructed for EMU operation in the 1930s.I note in Quail Maps the junction to the south of Sutton where the Wimbledon line diverges is annoted 'the Wall of Death' - what's the story behind that?!
Nicknames of a couple of lines used by bashers down the years...
'The Desert' = Berks & Hants line (which doesn't actually pass through Hants...)
'The Mule- = Waterloo - Exeter line
The line between Peterborough and Doncaster via Spalding, Sleaford and Lincoln is known as The Joint amongst rail staff and enthusiasts
Chiltern also internally refer to their mainline—at least the southern section of it—as the Joint line (being as it was originally joint between the GWR and GCR, later LNER), with the one via Amersham referred to as the Metropolitan line.
Have heard of the Princes Risborough - Bicester stretch of the former GWR / GCR Joint line referred to as the "green desert" due presumably to lack of any significant habitation in the area.Indeed that is so, although it is always the Met rather than the Metrolpolitan. The Joint line is always referred to by Aylesbury drivers as "round the houses" too. Aylesbury - Risborough is referred to as "the branch".
But surely High Wycombe through to Ashenden Junction was also part of the Joint line as it was used by Great Central trains.Should point out that the GWR/GCR joint section was only from Ruislip to Wycombe. Beyond there what is now the Chiltern system was exclusively GWR.
Maybe this was a slightly poetic description from a railway book rather than actually used by railway staff themselves.
