LIV-HFD, any more interesting routes?
Techniquest
19 Jun 2005
Nowhere Heath
Hi all,
I'm beyond useless at using the routing guide, so I'm having to ask you all here instead.
I'm a little bored of the Liverpool-Crewe-Hereford route, so I'm looking for something more interesting. It appears it's valid via Warrington, but not certain on that. I see I can book Advances with a change at either Manchester Piccadilly or Stockport, so it's a reasonable assumption it's valid that way too.
I know I can also go via Chester or via the Borderlands line, which on its own is interesting but then it still involves the awfully boring run between Wrexham and Shrewsbury. I hate that bit between Gobowen and Shrewsbury especially.
So anyone able to confirm validity via Manchester or Warrington?
Loop & Link
22 Feb 2015
I've just had a look on the Journey Planner and it won't let me do it via Manchester or Warrington. The only way would be splitting the ticket.
Loop & Link
22 Feb 2015
Am just as useless at the routing guide (must be in the wrong job) so just going off the journey planner on the Star machine!
Techniquest
19 Jun 2005
Nowhere Heath
Ahhh. National Rail will happily route me via Warrington, then gives me a walk up single of more ching via Manchester but not a return fare!
Quakkerillo
23 Jan 2015
Liverpool Group Hereford BV+HB//CH+AW//CH+BJ+HB//CV+AW//NO+BM+HB//NR+BM+HB
First is via Chester/Runcorn and Birmingham, second via Shrewsbury, third via Rugeley and Birgminham, fourth via Crewe and Shrewsbury, fifth is via Warrington (or Manchester) to Birmingham via Earlestown, last is same as the fifth, but via Warrington Central
So if I understood the routeing guide correctly, you can go via Manchester or Warrington.
lyndhurst25
26 Nov 2010
Liverpool Group and Hereford are both routeing points so all you have to do is look up the map combinations in the Routeing Guide yellow pages: no fares checks are required. Via Manchester or Warrington seems to be allowed by map combinations NO+BM+HB or NR+BM+HB, so you are in luck.
Paul Kelly
Verified Rep - BR Fares
16 Apr 2010
Reading
If you're going via Manchester you have to then continue via Birmingham - you can't take the direct train from Manchester to Hereford via Shrewsbury. Maybe you haven't put in enough via points?
30907
That may be the case in terms of getting a through fare or itinerary, but in practice there would be no way of preventing Liverpool-Manchester-Crewe then Crewe-Hereford, switching to CV+AV, and I would be very surprised to have the second leg queried.
There was a similar anomaly that meant Marylebone-Birmingham-Blackburn was theoretically only valid via Manchester.
