Livery under Great British Railways
2 Jun 2023
Richmond
Will, if successful, Labour plan to strip all current liveries and repaint everything into a similar scheme? What sort of logistics would have to be enabled to allow this to happen?
My personal opinion on this - I think it would be a waste of time and resources, passengers are already used to the separate operators and I believe just utilising the current branding with new names (GBR Southern, GBR Northern, GBR South West, etc etc) and better ticketing would be much easier for both passengers and government. Additionally, these days with time between major maintenance work on trains (when they usually get repainted) the amount of time it would take to get everything switched over to new colours you'd undermine it completely. TLDR resources could be better spent elsewhere
AF91
21 Jun 2022
Watford
I doubt that anything would be done immediately but I'm guessing that stock would be slowly rebranded when going through refresh works or as new trains join the network.
I think a consistent livery would push the messaging of a reformed and united system but also would think that there'd need to be some sort of differenciation between intercity, regional and commuter.
AF91
21 Jun 2022
Watford
Consistent in terms of how they various types of services look and feel wherever you are in the country. So an intercity service would have the same livery and interior colours whether you are on the western or going up the east coast for example.
eldomtom2
6 Oct 2018
TfL is a good example of how to have a set of liveries that differentiate different services while still having a consistent feel.
Neptune
29 May 2018
Sorry I’ve just bolded what you said here - ‘United system’.
So is the system one whole system (as in GBR) or a load of segregated systems (as in latter day sector used BR) that means that everyone has to fight for funds against each other as that doesn’t feel like a unified system.
Alternatively is it like SWT with an identical interior decor for each train but differing external liveries based on the same theme which identify a service segment but still has the feeling of one system.
Topological
20 Feb 2023
Swansea
Stagecoach used a similar approach with East Midlands, differentiating the "Intercity" with white and the "Regional" with blue. Under that system Liverpool to Norwich was given white. All had the same red ends then yellow fronts.
South West Trains also had a red variant, but that needed a blue front to differentiate. I think they were the inner suburban "metro" trains.
It is clear enough to me that these all belonged to the same operator, but there was differentiation by service.
GEoI6FeWsAAhiPZ
Image is from: https://x.com/VinPink2/status/1750221203631964663
Neptune
29 May 2018
GEoI6FeWsAAhiPZ
Yes that’s exactly how I’d do it if you have to have different liveries for different service groups, at least the liveries feel like they all belong to the same company. If you are just going to splash any old non harmonised colour scheme on different service levels and worse still as suggested different interior colour schemes then it just makes it look like the same old hot potch un-coordinated system which we have now.
Sorcerer
20 May 2022
Although I'd personally opt for a single colour scheme applied appropriately to each bit of rolling stock, I think the South West Trains approach could work too. I don't think you'd even need that many colour differences because of the use of red, white and blue also matching the flag and GBR logo. I'd even stick with the original variants of red for urban and commuter, blue for regional, and white for intercity.
Thirteen
3 Oct 2021
I think it'd be risky to have trains of all the same livery especially at stations which have different services.
Plus I can't imagine London Overground or the Elizabeth Line being rebranded.
Topological
20 Feb 2023
Swansea
I am not sure it is that risky to have limited numbers of liveries.
At Cardiff the dominant liveries are TfW (which is essentially suburban and regional combined) and GWR (which is basically Intercity). There is an hourly CrossCountry but labelling that regional would not cause too many issues.
Move down to the South West and somewhere like Exeter presently just sees GWR (All 3 roles) and CrossCounty (Intercity). There you would see a better segregation when dividing by type.
Although currently you could conclude a CrossCountry train will take you to Birmingham* at both locations, everything else comes with permutations beyond the colour of the train. You cannot assume GWR takes you to London* for example. (* We assume that the public know which direction is which, since both companies have destinations in the opposite direction as well, e.g. Plymouth at Exeter, or Swansea at Cardiff)
2 Jun 2023
Richmond
Another thing to keep in mind though is if they were to rebrand everything they'd also have to refit all the interiors on these trains (if they wanted it to be consistent). That involves new seat covers, pulling up carpets, repaint grab poles, etc
GEoI6FeWsAAhiPZ
I do hope they go for something a bit more modern than that!
Topological
20 Feb 2023
Swansea
I do not think anyone is advocating for the Stagecoach liveries (apart from maybe Stagecoach), rather the image reminds how Stagecoach varied a single theme according to the type of route the train usually operated.
CrossCountry are doing similar with the 170 vs Voyager differences, but that is still a work in progress.
I presume GBR would design something that reflected their image rather than that of Stagecoach.
Neptune
29 May 2018
I think it'd be risky to have trains of all the same livery especially at stations which have different services..
Yet we managed perfectly well in the late 70’s and early 80’s with 1 livery when there was less information available at stations and online info didn’t exist.
irish_rail
30 Oct 2013
Plymouth
One colour scheme nationwide also makes cascading of rolling stock easier , and in the long run will save money in costly vinyls and repaints when stuff gets re allocated. 175s for example, in theory if they go to GWR they will all need rebranding into green, however if we had one consistent standard throughout none of that would be necessary.
skyhigh
14 Sep 2014
Simple, as stock comes up for period refresh just do it in the new style.
Neptune
29 May 2018
Bad example. The 175’s are in TfW colours which won’t come under GBR so would need re-doing anyway.
PTR 444
22 Aug 2019
Wimborne
GEoI6FeWsAAhiPZ
I’d honestly make this the livery for GBR, albeit with the orange stripe repainted in white or blue to symbolise the Union Jack.
Now I wonder if there are any Network Southeast liveried units still lurking around…
vuzzeho
11 Apr 2022
I honestly imagine that a revitalisation of Intercity Swallow is the most likely to return. Retro revivals are very popular, and IC was (and is) iconic. I expect with a return to nationalisation, they'll want to remind the general public about all the glamorous parts of BR (v1) and that might include the livery.
Rail Quest
8 Apr 2023
Warrington
I imagine certain regions may demand some sort of unique branding for services operating in that area. I can imagine Manchester council fighting the corner for bee network branding on Manchester commuter services.
To be clear, I'm not stating this is either a good or bad thing, simply that I imagine it will come up when(/if) this is discussed.
WAB
27 Jun 2015
Anglia
If they’re happy to fund the rebrand when the units are deployed and the debranding when they are redeployed, then sure. It’s their money…
Class450/4DES
16 Dec 2021
Hampshire (Sometimes South Yorkshire)
I came up with this on Discord using the Wikia diagrams for services that were originally on the NSE network. Going with my idea of SE absorbing other franchises to become a "spiritual" successor to NSE.
Here is the BR Class 450.
(If you want to edit this, let me know first. Please don't be disappointed if I am most likely going to stay no.)
Russel
30 Jun 2022
Whittington
Reusing old BR liveries won't work, trains are a lot more styled and curvy that back in BR days, look at LNER, the livery they've put the Mk4 sets into looks really good, but it wouldn't sit well on the 800s at all.
Honestly, that's awful, the branding doesn't work and the big yellow square just looks messy.
Russel
30 Jun 2022
Whittington
Little offended but okay.
The contradictory geographical names just don't work, if you used GBR Southwest, GBR Thames and Chiltern, that would make more sense than SouthEastern Southwest etc...
As for the livery it's self, as I said, the yellow square looks messy, it's too big and clashes with the rest of the livery, a yellow line above the window is all that is needed.
No offence intended, it's just honest feedback.
Thirteen
3 Oct 2021
If local authorities end up running local metro services then you're not going to get full GBR livery anyway.
LLivery
13 Jul 2014
Is there a single country with one livery for *everything*? As far as I'm aware, no. The idea an 800 will be in the same livery as a 377 on the West Coastway feels a bit nonsensical.
GBR will have control of English liveries only, so politically, InterCity services having a single English livery for services to Scotland and Wales is probably a no go - we're a 'union' and all that. It'll most likely be either done by Region (and IC) or sector - Suburban, Regional, Intercity - basically the German/French/Italian model.
There isn't an industry more in love with branding as much as the railways in this country, and the BR Corp Manual is held dearly as an icon; which gives me hope it'll be done well...
Sometimes you need a clean slate. You can't expect the railway to keep c2 flipping c - I don't think it can be anyway as a legal issue. There's too many brands, a unified railway doesn't need Southern, South West, Southeastern and Thameslink - it's all Southern, though I would expect Thameslink to be retained, if not, strengthened.
renegademaster
22 Jun 2023
Croydon
Pretty much the Southeastern citybeam livery. Going to confuse lots of people at London Bridge for first few years if everything coming out of it looks like that
Government owned LNER does and nobody cares
Why not?
