That’s probably because, if it did, people like you would be on here endlessly complaining, calling for sackings etc.
over the vastly increased numbers of trains running late.
I wouldn’t complain about it, it’d be a very valid reason for a train running late. And the vast majority of passengers would understand if it was explained that was why the train was running late.
An interesting event, but with a number of unanswered questions;
How long did the connection need to be held for?
If it had not been held, when was the next service?
Now running late, did it conflict with and delay any other services?
Now running late, did it in turn connect into any other trains which then also had to be held?
Did it have sufficient turnround at destination to return on time?
These are all points considered when deciding whether or not to hold connections.
1. 10 minutes delay
2. Next connection would have been 30 minutes later.
3. Not sure if it caused conflicts en-route as a result but quite possible as it involved a single track line.
4. Yes, it connected onto a Vienna bound Railjet which was also held as a result, and that would have had a much higher potential to cause issues running late.
5. Yes it did have enough turnaround time.
Sure it’s not the most difficult thing to do in that example, but it’s a level of customer service you’d rarely see in the UK, especially if the connecting train was from a different TOC. I’m sure most guards would phone ahead to ask but the chances of the connection actually being held are low.
If, say, you were travelling from Edinburgh to Seaham, and the inbound service arrived at Newcastle too late to make the connection, unless it was the last connection of the day there’s virtually zero chance of the connection being held even if only by 2 or 3 minutes you’d be told to wait an hour for the next one.
I’m not going to discuss this further on this thread as I think this would be a topic for elsewhere.
