LNWR service from Liverpool to Birmingham and London.
Ianno87
3 May 2015
Does TL have the same level of interworking between the branches? I thought they were much simpler diagrams, which even with the long through services and congested centre must make it easier to unpick problems.
IOW, the problem is less that there are through services and more that units and crews are coming and going to all sorts of destinations so you can't simply bring everything back on time by cancelling a round trip and stepping up.
Generally, everything (rolling stock wise) is on self-contained circuits most of the day. E.g. trains just ping back and forth between Cambridge and Brighton, with decent turnround times at both ends to recover late running. There are a few quirks in the peak (e.g. trains starting from Horsham go to Bedford in the morning peak, then Peterborough thereafter) but otherwise it's fairly 'set' and standardised.
I think train crew is intended to be fairly simple too, with limited mid-route crew changes and drivers working end to end as far as possible.
I'd suggest, then, that if LNR want to maintain the through services, this is how they need to do it.
Ianno87
3 May 2015
LNR is however kind of having to fit around everything else, so it can't be optimised in the same way Thameslink can.
Ideally, it just needs the pre-joining up TT pattern as the starting point, but then looking for the opportunities to create longer through services without breaking key principles:
-Symmetrical pattern
-Mid-route recovery opportunitu
-Decent destination turnround time
-Etc.
gazzaa2
2 May 2018
Was waiting at Crewe today for 13.33 to Lime St, im going to Acton Bridge. Service was nearly 30 mins late, in fact loads of delays being announced.
When i did get on the train it was announced the service will terminate at South Parkway.
Seems to happen a lot that it's cancelled between Lime Street and South Parkway or Crewe in either direction or between Birmingham or Northampton and Euston. The percentange of trains on the service that actually make it from Lime Street to Euston, and vice versa, and make all the stops with minimal delay (a few mins) must be pitifully low.
AndrewE
9 Nov 2015
Apart from the annoyance of an unreliable service, with connections being missed all over the place, the most damaging aspect of this is that they don't warn people at Lime St that it is going to happen, so you don't get a chance to get out to your train at South Parkway. Result: they claim their train is on time, but none of the intending passengers from Lime St are on board. Tough if you were hoping to get a connection at Nuneaton, for example.
frodshamfella
25 Sep 2010
Frodsham
Yes I think your right.
frodshamfella
25 Sep 2010
Frodsham
That's really poor.
Old Yard Dog
21 Aug 2011
Regarding the stroll from Central to Lime Street it certainly isn't the most pleasant in the world but I have had equally bad if not worse in London, Manchester, Birmingham, Leeds, Glasgow etc.
If you are really worried about walking, there are very frequent trains from Lime Street to Central and, in the other direction, from Moorfields to Lime Street.
Dr Hoo
10 Nov 2015
Hope Valley
From Lime Street I've switched to the new Frodsham service, the LNWR has gone down the pan.
Am I missing something? I didn’t think that LNWR (or London Midland or even Central Trains before them) had provided regular services at Frodsham.
Penmorfa
16 Nov 2011
North Wales coast
I have seen it both announced and shown on the screens at Lime Street, allowing sufficient time to get to South Parkway.
frodshamfella
25 Sep 2010
Frodsham
I think the confusion (and I'm confused too) is how you would switch between LNR and TfW as they don't serve the same line or places?
Oh ok, my two most handy stations are Acton Bridge or Frodsham. So now I have a choice because of the new TfW service. Sorry for confusion.
Matt_pool
9 Nov 2016
This mornings 7.49 LNR service from Euston to Lime Street only made it as far as South Parkway where it was terminated!
https://www.realtimetrains.co.uk/train/P46016/2019-10-26/detailed
This means the 12.05 from Lime Street is now starting at South Parkway!
https://www.realtimetrains.co.uk/train/P44872/2019-10-26/detailed
It's probably already been pointed out, but occurances like this will put more pressure on other services from South Parkway to Lime Street (and vice versa) as passengers who had the option of getting the LNR serice will now have to use EMR, Merseyrail and Northern services, which at times are already very busy.
gray1404
3 Mar 2014
Merseyside
I really hope they return to a more reliable Liverpool to Birmingham service. Then a separate connection for Euston.
I very regularly travelled this route taking the 2 separate trains and provided the service from Liverpool wasn't more then around 7 minutes late could make the Euston via Northampton connection.
If they really want to provide a Liverpool to Euston direct service with WMT then this can only be realistically achieved by extending the existing Crewe to Euston via Trent Valley service. Moreover now it runs direct between Crewe and Stafford. I cannot believe this hasn't been done already.
Grumpy Git
13 Oct 2019
I was on an early morning LIV-EUS LNW service in early September. As we left Crewe, the guard announced delays south of Birmingham and told anyone going south of there to change at Stafford if they wished, (for the faster service via Tamworth). Result for me as I was in EUS 20 minutes earlier.
fowler9
29 Oct 2013
And I've seen it not announced or shown on the screens until it is too late to get to Parkway, and that happens frequently especially during the peak when most of the other services to Parkway are up the wall anyway.
They are having a large impact on other operators as well. As I have mention before, when you get a service terminated at Parkway everyone off a packed LNR service piles over to platform 2 to get on to whatever already crowded service turns up. This is obviously also delaying other services.
fowler9
29 Oct 2013
I'm actually just passing through Liverpool South Parkway and as if by magic after what I just said the LNR service has been terminated here and all the passengers are further delaying the East Midlands in to Lime Street. It is a farce.
LowLevel
26 Oct 2013
Every shift I've had that's interfaced with them this week has been a total farce. They've become a bit of a joke and not a very good one.
Carlisle
26 Aug 2012
Im getting the impression similar to GTR
2 years previously certain posters appear as almost on commission to criticise TOCs their union might have currently fallen out with.:s
LowLevel
26 Oct 2013
2 years previously certain posters appear almost on commission to criticise TOCs their union might have currently fallen out with.:s
I'm quite happy to critique or praise anyone that deserves it :lol:
Abandoning chunks of your network while failing to ensure your control is adequately staffed seems to be reasonable grounds for criticism to me, no? They're up the creek even without traincrew shortages as they have a totally unworkable service plan. Cross Country went as far as posting in their incident reports yesterday that WMR's failure to get a handle on running the service mucked half the country up.
How on earth can you get away with centralising a control and security team then in the middle of mass disruption simply declare that 'customer information screens and disruption messages will not be updated for the rest of the day, if stations are able to assist by managing their screens can they please do so' !?!
Lovely ideas - absolutely appalling implementation.
AndrewE
9 Nov 2015
Do you think LNWR shouldn't be criticised for this behaviour? I'm only a customer but I think they deserve it, especially for starting trains short at S Parkway and not warning passengers so that they can get out there in time
Dr Hoo
10 Nov 2015
Hope Valley
In the interests of wider understanding could you flesh out what the changes to the control arrangements have been? Is it a case of experienced staff not wanting to move, perhaps?
It would also be interesting to know what the ‘security team’ does (unless you would then have to shoot us all).
AM9
13 May 2014
St Albans
Having just dipped into this thread, (I occasionally use LNR to get to the NW cheaply) I can see that there are quite fair complaints abouit terminating/starting short at LPY. What surprises me is that nobody has suggested a delay repay application as a result of a TOC decision to change from the advertised service. Early this year I managed to get a 100% refund because of confusion on announcements at Milton Keynes even though the train ran to it's published timetable. Surely this is a similar situation, even if the switch only becomes apparent just after purchasing a ticket at Lime St.
Of course the imnconvenience would still occur, but frequent claims might make LNR consider their options when confronted with disruption.
LowLevel
26 Oct 2013
It was carried over from London Midland in fairness but there was a significant change in manning at West Midlands stations a few years back with staffing heavily reduced having for decades been first train to last. Part of this was an assurance that the stations would be monitored by CCTV - the customer information and security desks were apparently both unmanned in the midst of yesterday's turmoil.
Carlisle
26 Aug 2012
IHow on earth can you get away with centralising a control and security team then in the middle of mass disruption simply declare that 'customer information screen and disruption messages will not be updated.
Sorry didn’t intend to be rude,
It sounds from what your saying many of the problems for a TOC like WMR/ LNWR are attributable to a combination of over complex timetables, capacity problems & train & station staffing regimes that haven’t fundamentally been changed in several decades to better reflect the modern railway, but have (probably wrongly) all been allowed to be tinkered with here and there simply to save a few quid :frown:
