Hello there,
I hope everyone is enjoying the Easter break?
As my post title says I an looking for any noted rolling stock formations for any passenger services. Be that Intercity, NetworkSouthEast, Scotrail, Regional Railways or anything which was pulled by a diesel or electric traction. The more varied the better. If you have any services details too, that would be great. I am hoping to start building these formations up and eventually run them on my layout, when ever I get it finished. Many thanks in advance.
Kind regards
Quantumspotter.
ScotRail:
1980-1985 Edinburgh & Glasgow push-pull:
47/7, 4 Mk3A TSO, Mk3A FO, Mk2F DBSO
1985-1990 E&G push-pull:
47/7, 3 or 4 Mk3A TSO, Mk3A CO, Mk2F DBSO
1982-1990 Edinburgh/Glasgow-Inverness:
47/0 or 47/4 (only /4 booked post-1985) Mk2C BSO, 2 Mk2A TSO, Mk2C TSOT, Mk2C FK (CK from 1985). Strengthening with 2A TSO, 2C BSO or DB Mk1 TSO as required. MK1 BG additional some workings. One set had a BFK vice FK/CK.
Edinburgh-Inverness "The Jacobite" Low Fare push-pull, 1984 & 1985:
47/7, 3 Mk2Z TSO, Mk2Z FK, Mk2F DBSO
Glasgow-Aberdeen Mk3 push-pull set, 1980-1984:
47/7, E&G push-pull set with initially Mk1 RMB between FO and TSOs, Mk2D TSOT from ~1982. Mk3 push-pull sets also used on two Glasgow/Aberdeen 1984-1990 but without catering vehicle, trolley service provided instead as this was launched Edinburgh-Glasgow in 1984.
Glasgow-Aberdeen 1982-1985 Mk2 air-con:
47/4-Mk2A BSO, Mk2E FO, Mk2D TSOT, 4 Mk2D TSO
Glasgow-Aberdeen 1985-1986 Mk2 air-con push-pull
47/7, Mk1 BG, 3 Mk2D TSO, Mk2D TSOT, Mk2E FO (one set had a 2D BFK instead for a short period), Mk2F DBSO
Glasgow-Aberdeen Mk2 push-pull 1986-1990:
47/7, (Mk2Z TSO, two sets of 4 only), 2 Mk2D TSO, Mk2D TSOT, Mk2E FO or from 1987/8 Mk2A FK, Mk2F DBSO
Edinburgh-Aberdeen 1982-1986:
Services almost all provided by HSTs or LHCS from out of region. Only two internal LHCS workings.
Edinburgh-Aberdeen internal push-pull 1986-88:
See Glasgow-Aberdeen 1986-90
Inverness-Aberdeen: 1982-1986
Mk2Z TSO, MK2Z BSO, Mk1 BSOT, 2 Mk2Z TSO
Inverness-Aberdeen: 1987-1989
2MkZ TSO, Mk1 BFK, 2Mk2Z TSO
Inverness-Kyle/Wick&Thurso (Mk1/2Z mixed): 1982-1989
Base set: BG, 2 TSO (2Z or Mk1); Wick/Thurso also with Thurso portion of Mk1 BSOT, 2 TSO
Glasgow-Fort William&Mallaig/Oban 1982-1989 (Mk1/2Z mixed):
Winter: 3 TSO, Mk1 BSK
Summer: TSO, Mk1 BSOT, 3 TSO, Mk1 BSK
Glasgow-Dumfries-Carlisle Mk1 1982-88
3 SK, BSK (From 1987, one set did a Stranraer diagram)
Glasgow-Stranraer Mk2Z, 1985-Summer 1988
4 TSO, BSO (from 1987 one set did a Carlisle diagram)
Glasgow-Stranraer Mk2A/C, Summer 1987-1990
2 TSO, BSO, 2 TSO (one set on Glasgow/Carlisle trip as before)
Miscellaneous:
Evening Glasgow-Arbroath, & Arbroath-Dundee All Mk1 1987:
SK, BSK
Aberdeen-Stonehaven etc locals 1987:
5 SK, BSK
Glasgow-Perth/Dundee 1982:
47/7, 4 2Z TSO, 2Z FK, 2F DBSO
OR
3 Mk1 TSO, Mk1 BFK
Edinburgh-Perth/Dunblane weekdays push-pull 1983-88ish:
47/7, 4 2Z TSO, 2F DBSO (Spare push-pull set)
Probably some I've forgotten.
Can also do WCML, ECML & XC summaries as well but ScotRail is what I model so is my main area of knowledge.
