Locomotive Services Fleet (LSL) updates
Nym
2 Mar 2007
Somewhere, not in London
Just returning it to it's as-converted class 57 appearance, seeing as LSL see no requirement for Dellner couplers in their usual business activities.
One does have to wonder what they're going with the 27 way on the front of it... Given that 57/3s don't have multi working and the removal of the Dellner means it's not going to couple to anything other than with a screw coupler.
And no, there has never been any requirement for any head end jumpers on this 57/3 as it hadn't been through the "BIU Mod" for Network Rail that fitted a 27 way to connect to the drop head Dellner.
Some suspicions here that LSL are having some wishful thinking of Multi-Working 57/3s without issues...?
12LDA28C
14 Oct 2022
The back of beyond
Isn't green circle just a variant of blue star?
The two systems are very similar but not identical. I wouldn't like to try to multi up a blue star loco to a green circle.
They are planning to be able to work the 57s in multi with each other I believe, but not with their 47s.
Nym
2 Mar 2007
Well, even though it's not possible for them to work in multiple with Class 47s, I'm sure someone would be hopeful that they could make 57s work in multiple with 47s.
I do suspect that LSL haven't considered the nuances of making 57s work in multiple though. It's not as simple as join them together and shove the control wires through.
Wyrleybart
29 Mar 2020
South Staffordshire
Don't know much, but I do know that the blue star system uses control air (white pipe) to increase and decrease the power application on the locos - because most indigenous Uk locos used air for engine control. North American locos on the other hand tend to work on notches which can be controlled electrically - via the AAR jumper cable, so control air is not used.
What I don't know is how the 57/0 multi works - fitted after they had passed from Freightliner to DRS
The_Train
2 Jun 2018
I'm sure I have seen a photo of one of the 57s at Eastleigh in a very stateman like livery but I can't seem to find it anywhere now and I'm starting to think I dreamt it (we all dream of trains, right?!?).
Does anyone have a copy of the photo or if it cannot be shared, advise of the colour scheme please?
12LDA28C
14 Oct 2022
The back of beyond
It's in LNWR lined black livery, very similar to the colour scheme Pete Waterman had his 47s painted in, in the late 1990s.
Quite surprising that the 57s are not receiving 'chocolate and cream' livery to match the Statesman stock, if that is the train they will be used for.
The_Train
2 Jun 2018
Thanks, it's definitely that which I saw so at least I know I am not dreaming of 57s :D
The colour scheme would suggest it is planned for the Statesman stock, certainly unlikely to appear on the Intercity jobs. I think sometimes, a loco livery slightly different to the coaching stock but of similar class can look quite good
Edit: Can I also please confirm that it is indeed 57311 that has received this paint job?
12LDA28C
14 Oct 2022
The back of beyond
Yes, 57311. The colour scheme doesn't really suggest anything as it doesn't match any stock LSL operate and they don't have any other diesels in this livery, but I understand the 57s are to be used on the Statesman.
Certainly when DRS operated the Northern Belle, the locos were painted to match the stock but clearly LSL are taking a different approach, using more authentic 'historic' liveries for their locos.
The_Train
2 Jun 2018
I don't think anyone would have batted an eyelid had it been painted to match the stock but I often think LSL prefer to turn eyes. Will be interesting to see how it looks with the stock!
As one final question, I presume it has also lost it's "Thunderbird" name since leaving DRS?
12LDA28C
14 Oct 2022
The back of beyond
I would certainly assume so as it would appear rather incongruous now, no longer being a 'rescue' loco. Most likely LSL will apply their own name in time, as they see fit.
Nym
2 Mar 2007
LSL being attention seekers, no... who'd have thunk it...
Wonder if they'll apply the same enthusiasm for liveries to making the locomotives work properly?
12LDA28C
14 Oct 2022
The back of beyond
I'm sure you'd aim the same question at Arlington, as they're doing the overhauls.
Cowley
15 Apr 2016
Devon
I don't wish for this to descend into a B-wording contest but I've never been too happy with the work done by Arlington either.
I wouldn’t worry too much because I don’t expect the bills are coming to you @Nym. :)
Cowley
15 Apr 2016
Devon
The last I heard about 118 was that it was still in bits, the bogies had been shot blasted and were waiting on reassembly. I think it's still a way off being ready for anything.
I might be getting my Peaks mixed up but wasn’t that booked to run a railtour fairly recently?
31160
18 Mar 2018
Thanks, the clock is ticking on having out of the Cross before the new fangled signals are put in then its a big full stop on that
Wyrleybart
29 Mar 2020
South Staffordshire
Is an old locomotive not compatible with new signals?
As Intercity110 implied ETCS is going to be installed between Kings Cross and Stoke tunnel. This is basically an upscale of the system used on the Cambrian lines since it replaced RETB. The class 37s fitted with it had to have one of the boiler / fuel tanks removed to fit the ETCS kit underneath, and the TfW class 158s have had a pair of seats removed to get the "suitcase" of ETCS kit into the salon.
You will appreciate that any train working the ECML between Kings Cross and Grantham will in future need the same "suitcase" of electronic gubbins to allow it to run. I believe the track between Peterborough and the Helpston will have signals whereas south of Peterborough I believe they eventually intend to chop down all the signals and rely totally on in cab signaling.
You might want to look at the work being done on the steam loco 60163 "Tornado" as that will be the first ETCS fitted steam loco, a deltic also to be fitted.
Take a look at this video from about 36 minutes
D365
29 Jun 2012
Also worth noting that ETCS fitments for Class 37 are also being progressed, although the future of this particular workstream really depends on whether DRS/Colas see a long term future for heritage vehicles in their respective fleets.
they could mean ETCS and the loco may not have enough space for that.
Most ex-BR locos don’t have space, but we’re still trying!
Richard Scott
13 Dec 2018
It's not just the computers; at least half of the volume is relays and power supplies.
Going back to 45118, 45s have next to no space inside for any substantial kit. In a 45/1, if the equipment is not too large, may be space in former boiler room.
