Locomotive Services Fleet (LSL) updates
Trackman
28 Feb 2013
Lewisham
LSL have successfully started up Deltic D9000/55022 last weekend with it's overhauled power units.
XCTurbostar
13 Sep 2014
That's great to hear.. literally :)
43059 and 43049 are currently on their way back to Crewe as 5Z44. Interestingly, 43059 has the words 'Pullman' with the omission of 'Midland'.
Trackman
28 Feb 2013
Lewisham
Blue Pullman 43055 power unit has gone bang (camshaft), being replaced with power unit from 43058.
fgwrich
15 Apr 2009
Between Edinburgh and Exeter
Not good news, hope it wasn’t in traffic when the failure occurred
Quite possibly, it wasn’t very happy on its last trip out (the Kyle of Lochalsh trip where it started smoking very heavily). It hasn’t been out since.
But what I find odd, is that 083 was a runner and has since found itself stored outside in Eastleigh. 058 is a runner and was recently on a Crewe > Eastleigh > Crewe trip with 049. While 058 will no doubt get 055s engine in time once reconditioned, it just seems a little bit of an odd way of doing it.
12LDA28C
14 Oct 2022
The back of beyond
D1944 (47501) 'Craftsman' is no longer part of the active LSL fleet, having been withdrawn. Rumours going around of the loco being put on display at the Margate site after reusable components have been removed to keep the rest of the fleet in traffic.
Whistler40145
30 Apr 2010
Lancashire
Unfortunately, 47501 wasn't the most reliable of locomotives when DRS owned it
12LDA28C
14 Oct 2022
The back of beyond
Indeed, although when it went, it went like a rocket. I believe there were some power unit / generator issues which led to excessive current being passed through the electrical system and to the traction motors with predictable results.
Richard Scott
13 Dec 2018
That would mean the diesel engine must have been operating above rated setting. Often happened with 50s set up at a depot.
fgwrich
15 Apr 2009
57311 Nose Job complete and is now in the Arlington Paint Shop
57302 Now about to start it's Nose Job and up on stands. Who needs Harley Street?
Also in Carls updates, Staycation Mk3 TGF (44081) turning Blue, and former GWSR Mk1 FO (3091) "Marguerite" now about to enter the works (It since has and will be eventually be joining LSLs main fleet).
adc82140
10 May 2008
I have 40808 and 40902 as being at Eastleigh for LSL. Is this still the case?
cce
10 May 2018
Does the ScotRail set use the original push pull control system or something different? I'd assume different because the DBSO has been modified more than once.
43096
23 Nov 2015
Blue star is used.
12LDA28C
14 Oct 2022
The back of beyond
No, the original system used the coaching stock lighting circuits but the ScotRail set has now been fitted with a dedicated hard-wired system specially for the DBSO control, for robustness and reliability.
Richard Scott
13 Dec 2018
Has the loco's control system been modified or is that the original push pull system?
43096
23 Nov 2015
It's all Blue Star multiple controlled. The original push-pull system is long since obsolete - and no doubt long since skipped for the DBSOs as they were converted to standard TDM in the late 1980s/early 90s. The DBSO involved had been fitted with Blue Star capability for use on the Cumbrian Coast with Class 37s, so make sense to fit 47712 similarly.
Richard Scott
13 Dec 2018
Ok, thanks for info. Guessed original system was obsolete especially as DBSO had been modified a few times.
12LDA28C
14 Oct 2022
The back of beyond
To be pedantic, I believe it's a modification of the green circle MW system, as that is what is fitted to 47712 and other 47s in the LSL fleet.
43096
23 Nov 2015
Isn't green circle just a variant of blue star?
