I am going to church Stretton on 28th December.
The ticket will originate from Potters Bar (boundary of my season ticket) & I will travel via London.
I usually travel to CTT via Paddington & Newport but that option is not available this time due to engineering works that week in the Severn tunnel area so there will be no through trains from Paddington to South Wales all week.
The online journey planner on national rail site shows that the quickest (& easiest) journey is to get the xx:07 liverpool train from Euston (or the xx:10) & change at Crewe - there is a cross-platform change there onto a train direct to Chruch Stretton.
However, it is indicating that there are no return fares available for this route (other than advance fares which are available)
on the NXEC site, all journey options shown involve several changes & take at least 30 minutes longer than it would travelling via Crewe due to connection times in Birmingham & shrewsbury (plus a least 1 extra connection and the ones a Birmingham/wolverhampton etc would not be a convenient as a cross-platform change at Crewe)
If you specify Shrewsbury as the destination, fares on the NEXEC site do now provide a journey option to travel via Crewe, using the same trains that I would use for Church Stretton (if the any permitted fare is used).
there is also a lower priced "route Birmingham" fare to Shrewsbury.
The Church Stretton fares are slightly higher than those to Shrewsbury, so why are the journey options to Church Stretton not showing up as being valid via Crewe when it is the quickest route?
The only difference I can see is that fares to shrewsbury are priced by VT and use off-peak returns. CTT fares are priced by FGW and a super off-peak is available, but still costs more than the off-peak return to Shrewsbury.
On the Routeing guide, they are essentially the same London-Shrewsbury journey
Maps BD+LM show Euston-Crewe & also Crewe-Shrewsbury (& onwards to Newport)
On the basis that this is the quickest & easiest journey option & I am using exactly the same trains as a journey to Shrewsbury which is permitted via crewe I would argue that travelling to church Stretton is also valid that way but there is probably an error in the online booking systems.
Would the experts on this forum tend to agree with this?
Fyi, on the return journey I will be using WSMR back to Marylebone (Can't use WSMR on the outward journey as there isn't a northbound train at the time I need to arrive in Shrewsbury)
As an afterthough: if you try Potters Bar-craven Arms on National rail site for 28th Dec, default journey time outwards is 5 hours 38 minutes
if you add "via crewe" the journey time is dramatically reduced to 3 hours 56 minutes, but the return fares are again not shown.
Many thanks,
Jeremy
Many thanks,
Jeremy
