Lothian Group discussion (Lothian City, Lothian Country Bus and East Coast Buses)
Jordan Adam
12 Sep 2017
Aberdeen
It operates now with fair loads on each service.. the tram network does not cover for everything along the 22 and is not a suitable alternative to many customers. I'd argue if the 22 would be axed, this would've occurred a long time ago. The 1 & 2 would need improvements capacity wise i'd imagine if it did happen though.
Which is why i suggest the resources being redistributed and the network being revised. But the 22 returning to operating it's full route seems pointless since for the most part it'll just be duplicating the tram and the network can be revised to create new links/avoid duplicating links.
scosutsut
1 Jan 2019
scosutsut
I'd 100% agree with that. Lothian and the trams are both under the TfE umbrella and they need to start acting more like it. I suspect the restructure hinted in recent documentation will be to try and address exactly that.
It's not to say that buses can't run alongside the trams, but that the overall, combined network, should make sense.
29 Nov 2018
Maybe not a fair comparison but in London there are some bus routes that closely follow underground lines. In that case you'd find the underground stops are very much further apart than bus stops and of course subway trains aren't DDA or buggy-friendly. Maybe you could say in Edinburgh the tram won't suit everyone either so perhaps a few passengers might prefer the 22 over the tram.
However I think you're quite right that the 22 would serve little purpose operating down Leith Walk again. It's just a matter of the public getting over the initial feeling that they're being short-changed and losing a service.
25 Jan 2022
Edinburgh
Well, the tram does use Lothian DayTickets, so I wouldn't see this happening.
I think they will probably do something similar to what they done with the Service 12, I'm not sure which service, there's only a couple of viable options really.
Did you miss the accident damage?
I didn't realise 20008 was in an accident. She will probably end up being repainted just like 1004 was when she was getting repaired. Does anyone have a photo of her accident as I've not seen it, thanks in advance!
stevenedin
26 Jul 2021
Edinburgh
The section between Saughton and Balgreen tram stops doesn’t really get well served by the tram easily and that part is where a lot of people would experience a much longer route to the city centre if they had to rely on the 1 or 2. The 22 serves people who use these stops better than the tram as they would have a long walk.
FlybeDash8Q400
26 Jun 2018
Edinburgh
With the tram extension one has to question what point the 22 actually has going forward. Surely it's better to axe the route entirely and redistribute resources to where they can be better utilised?
The 22 would be best being kept and extended to somewhere else. It’s still far too busy to take out completely, and as others have said the tram or other services aren’t viable options for some of the areas it serves, particularly in Stenhouse and South Gyle.
For me the 22 going forward ideally should be a West to East route, possibly taking over from the 4 on the east side, which in my view has a particularly unnecessarily similar route to the 44 in a number of places. I’m aware I’m mucking around with what were once tram routes here which would certainly be controversial!
For those thinking that the 2 already connects the Gyle and The Jewel (and a few areas in between) you’d be absolutely right. But something is going to need to pick up Newcraighall Village (a single deck route) if the 30 is indeed moved to double decks and rerouted via the A1 directly to/from Queen Margaret University. The 2 for me would do this job perfectly. It could run from Niddrie via Fort Kinnaird, Newcraighall Village, Queen Margaret University, Stoneybank Crescent (which can have the regular service back) and maybe terminate at Tesco in Musselburgh? Sunday workings could stop short if needbe. So as to maintain the links that are lost from the 2, I’d propose rerouting the 14 to terminate at The Jewel in place of it. The 4 could then extend from the City to Greendykes to replace the 14, possibly via Pleasance/Jeffrey Street etc? The latter is just an idea that may or may not work in practice. When the 35 was being diverted via Holyrood Road it was actually well used so I think a service could work serving here again. If not I’m sure West Richmond Street would be fine. A scenario like that could work well and it tidies it all up rather nicely while offering new links. The 30 can reduce to every 15 minutes too so that Prestonfield, Craigmillar and Niddrie Mains Road aren’t flooded with loads of unnecessary extra buses per hour. Short 22 solved, and the 30 situation fixed too.
Not related to what the current discussion is about, but does anyone else think that the Airlink might switch to the North side of St Andrew Square now that the Tour Buses are being moved to Waterloo Place?
Simon75
25 May 2016
Since trams were reintroduced Edinburgh, have many routes been cut ?
29 Nov 2018
Since trams were reintrin Edinburgh, have many routes been cut ?
Apart from a significant reduction in service 22 frequency, I'd say there were very few bus cuts. It's difficult to say because bus routes are adjusted for all sorts of reasons, including Covid of course.
But even the 100 seems to remain similar to the pre tram situation.
Grumpyscot
20 Jul 2019
Just to add to recent "accidents" - the 10.30 ish X5 to Edinburgh last friday (10th) drove into the bus shelter at St Germains Level Crossing and took out his wing mirror. Passengers none too happy, as they had to wait for the next 124 and were quite late getting into town. Driver almost got taken out when going to inspect the damage - he couldn't access the nearside from the cab, so had to walk round the bus to collect the mirror. Almost got taken out by an Audi and a Range Rover doing their utmost to beat the land speed record....
roadierway77
23 Jun 2019
Edinburgh
I'd personally have the 22 go up Easter Road and then take over the route of the 49 to Fort Kinnaird. The 49's route is counterintuitive as it loops back on itself - someone coming from Rosewell or Dalkeith who doesn't know the route may think the 49 doesn't continue to the city like the 48, as the logical route from Dalkeith to the Fort avoids the centre. It would help even out route lengths as well, as the 22 is currently only 35 minutes in length while the 49 is 2 hours. Cutting the 49 back to the city centre and extending the 22 to Fort Kinnaird would give both routes an ~80min journey time from end to end.
10 Aug 2022
Scotland.
Sorry, no photos. Just saw it at the roadside in Longniddry with a cracked windscreen and some panel damage on the n/s front.
stevenedin
26 Jul 2021
Edinburgh
The only issue, although not too big, is the loss of the Leith Street & Leith Walk section of the 49 route. People using it will lose links to Midlothian and also Fort Kinnaird but they can walk if able as it's only 10 mins to Easter Road.
Avenger20
8 Aug 2011
A simple swap of old then. Run the 49 from Rosewell to Ocean Terminal via Leith Walk and Great Junction Street and run the 22 from Gyle to Fort Kinnaird via Easter Road and Portobello
buslad1988
28 Dec 2018
Do we really need yet another service from the Eastern Edinburgh area to the Gyle Centre though? It’s starting to get complicated enough already with the 2, 12, 21 and 400 all going different directions.
Bus9120UK
5 Oct 2019
Edinburgh
Wasn't aware that marine way back using their dual-door x London's again, until one appeared on a late night 21 journey from Portobello last night
They've been back in service since the Volvo B5LHs 579-590 moved to Lothiancountry - 1141-1142/4/5 re-entering service at Marine allowing for 1000/1/2/5 to move to Longstone. 1146-1153 also moved to Longstone, but the recent 31 changes lead to 1152/3 moving back into reserve. 1143 didn't leave service at all. 1152 is at Longstone now though for an MOT.
stevenedin
26 Jul 2021
Edinburgh
Thanks for that. I actually forgotten what nice buses these were to travel on and I really enjoyed my my long-distance trip from Portobello to drylaw last evening
I agree. They are also retro looking inside with the dual doors. I wish they would bring them back for all new buses.
roadierway77
23 Jun 2019
Edinburgh
That would certainly make more sense, but I thought the intention behind cutting the 22 back to Waterloo Place was to reduce the number of buses going up Leith Walk now that the tram will be providing a high frequency service along that corridor? Hence why I suggested running an extended 22 via Easter Road.
Not particularly, but the Gyle is a logical terminus as it's a popular destination close to the edge of the Edinburgh conurbation.
Bus9120UK
5 Oct 2019
Edinburgh
What services haven't come back after Covid?
The X15 you can say, the X44 to Balerno, services 61 & 67, the N49 (somewhat? I don't think it ever started..). Lothiancountry X17, it became the 276 and no longer operated to Edinburgh after covid though.
25 Jan 2022
Edinburgh
1004 and 178 are on their way to Central, this pretty much confirms that all of 176-190 are going to Central as well as 1003/4. Info given to me by @Bus9120UK.
Edit: Thanks to @FlybeDash8Q400 for supplying info that these vehicles are receiving MOT's at Central.
