Major line-side fire between Wembley and Watford Jnc 15 Sept 2017
oversteer
26 Jan 2011
Curious to know.. normally when there's a building collapse etc it takes a while to assess and make safe
I don't think this fire was on NR land, so do they have some powers to demolish/rebuild retaining walls if it's likely to cause a safety issue?
Or is it something insurers get sorted quickly because the cost of delays is immense?
Antman
3 May 2013
For a fire near Harrow to result in no service whatsoever between Hemel / Berkhamsted / Leighton Buzzard and Milton Keynes is appalling.
Exactly, that's the cause of a lot of anger. Surely some sort of service could be provided between MK and WJ?
AY1975
14 Dec 2016
I notice also that Real Time Trains appears to show London Overground as running throughout between Euston and Watford, whereas I thought they would only be able to run Euston-Harrow & Wealdstone.
Antman
3 May 2013
The tracks used by LO are some distance from the site of the fire.
AndyW33
12 Aug 2013
Six tracks at this point. Up and down WCML slows are nearest to the scene of the fire and the wall that is the remaining danger, then come the up and down WCML fasts, and finally the up and down DC lines used by London Overground. Isolating the 25kv overheads has no effect on the 750v DC third rail DC lines, so they can operate while the tracks nearer the wall are still out of use.
Wearsunscreen
26 Jul 2017
In this instance, say you was due to come on duty as a train driver this morning on the route affected.. you turn up to work as usual. What would then happen for this train driver given the fact he can't drive the train given the issues??
Lrd
26 Jul 2010
Be ready to go for when the line reopens.
Clip
28 Jun 2010
indeed. I'm surprised in amongst all the faux outrage shown on here people haven't quite got around to the staff on board all the trains that have probably gone well past their hours by now and getting relief staff to them ready for the go would take quite sometime in the car from both Brum or Euston so maybe MK was the sensible option.
GB
16 Nov 2008
Somewhere
If a service could have been run it would have. There is a difference between a planned block that was planned many months in advance vs an emergency isolation and emergency block that encompasses a larger isolation area, a full passenger train service as well as a full freight service.
Dolive22
20 Dec 2009
The local council have certain powers to deal with dangerous structures in an emergency (s. 78 Building Act 1984, if you want to look it up), but I'm not sure the procedure for permanent repairs. Legally, it may depend on the terms of the land transactions at the time that part of the railway was built.
DarloRich
Fenny Stratford
NRE have tweeted that the line is open
They also show pictures of specialist equipment moving onto the site to make it safe.
Cletus
11 Dec 2010
Dover
Virgin have tweeted:
#VTUPDATE All lines have now reopened between Euston and Milton Keynes Residual delays and cancellations are still expected
Was bidirectional signalling left out at a time when Sydney Bridge Junction was still in situ but then not backfitted after the junction was removed?
The Sandbach-Cheadle Hulme bi-di was part of the new signalling at Manchester South (Edgeley) installed during the WCRM upgrade.
No changes were made to the signalling at the Crewe end, apart from the removal of Sydney Bridge Jn.
Thanks - my ticket says 'Valid only via London' but the National Rail website says all restrictions lifted so should be OK to use Farnborough North to Reading on GWR.
It looks like the closure has been lifted, but you could have travelled via Reading and Newport for a quieter journey to Chester/Shotton (hourly from Newport to Shrewsbury/Crewe, plus 2-hourly direct to Chester/Holyhead).
Although connections are not ideal at Newport, and are never kept.
This route is valid today according to NRE.
"Valid via London" does not preclude travel via Oxford, even on normal days, if you have a flexible ticket (not an Advance).
It just means tube travel across London is included.
70014IronDuke
13 Jun 2015
It is clear you don't like having your views challenged ...
I do not mind at all. What is clear is that you have not properly read what I originally wrote.
but you haven't answer the exam question.
Because I never suggested that. Read it again. My principal criticism of this whole affair was merely that all trains were cancelled between MK and Watford, with not even a token service on offer.
How do you get me from Watford to/from Euston? How do you get the train to and from Watford and how do you ensure it is used, mainly by passengers for intermediate stations rather than Euston passengers? ...
If you can't turn trains at Watford any longer, this is unacceptable. As I said, this is the most important main line in the country, and this level of inflexibiltiy in an advanced economy needs addressing. But as others have suggested, you can turn at Tring (it seems). So why no service to there?
You are also thinking about the issue only with a view to considering a journey by rail. Surely the sensible thing to do is to consider the whole picture.
I am trying, but my intellect is just not up to some people's in here, I accept that.
Then answer for most might be - don't take me to Watford. Put me on a bus at MK.
It may well be. I never suggested it was not. Please read what I wrote again - I indicated that bus could well be an acceptable option, perhaps the best for a majority of folks.
CLEARLY there should be some form of service running south of MK to serve the intermediate stations.
Aha! So now you are agreeing with myself and several others on this point. We are getting somewhere after all.
The problem is where to turn it around and how to make it work with one depot worth or train crew and trains short becuase of the blockage.
Of course, major disruption like last night causes problems for operators. That does not mean giving up and saying 'we can't run any trains south of MK' surely?
We might have a crossover at Watford North but for a landslip and a desire to avoid voluble critics wailing and gnashing their teeth ( perhaps such as yourself) about inconvenience with two routes closed.
Two routes closed? I'm confused on that one.
But in view of your superior judgement on posters here, I certainly shall be careful not to metaphorically wail or gnash teeth at any time in the future, just in case. The verbal lashing is just too frightening a prospect.
Well I think I do know. What with having used such a route several times. It is much easier ( and i think quicker) to go to Luton by bus form MK than stagger down to Watford and then be left there.
Well, why not say it like that first time round. You could well be correct - for the majority. But again, I did not suggest the majority go "staggering down to Watford." I was suggesting that for some people, eg heading to the HArrow, Webley area, it still might be a useful option - if there were some trains.
However I know that this means making heinous suggestion: using another mode of transport to rail but in situations like this a rail only view wont help passengers go about their business
"heinous suggestion" - your words.
... it seems you hadn't as you simply went for the straight forward moans and complains about the lack of diversionary routes.
ER, read my original posts again, please. Even a six year old knows it takes time to build a railway line. I am a bit older than six, so I really didn't need to be told that. (and I had written that it would take eight years in any case - but you decided not to read that.)
What you term "moans" is another person's opinion (terribly sorry about that). I happen to think that part of the initial reaction to this crisis - ie closing all tracks between MK and Watford, is unacceptable. Efforts should have been made to offer some basic service.
Longer term the ability to turn trains easily at Watford Junction needs to be addressed.
BTW the financial loss here wont cause the government to fund a network of such routes.
Also complaining about what we should have wont fix the problems we do have today. How do people get home from work tonight? THAT is the issue not diversions.
That is the issue (of several in this incident) you have decided to highlight. It's certainly a valid issue, but just because my original post did not particularly address it, does not make discussion of other issues, including solutions longer term, unworthy of discussion does it?
As one esteemed poster here has mentioned: "Surely the sensible thing to do is to consider the whole picture." - ?
Sarcasm. sweet.
Merely following in the footsteps of a master of the genre. (Apart from rereading my posts, perhaps you should read your own again - gnashing teeth, heinous, MK bus interchange, etc )
Good news. Well done to those involved.
oversteer
26 Jan 2011
Seen a few references to Tring - you could indeed use the two platforms there, but it's a relatively rural station, with limited bus service to the town with no room to turn/queue coaches, no disabled access etc
You'd just drop people off and they'd have nowhere to go to that they couldn't get to via Aylesbury / Milton Keynes / Luton etc
You'd just drop people off and they'd have nowhere to go that they couldn't get to via Aylesbury / Milton Keynes / Luton etc
You're making the assumption like LM did that everyone is going to London. There will be Tring to MK commuters etc.
The coaches don't have to go from there.
E16 Cyclist
14 Oct 2011
Out of interest how long is the section of ohle that needed isolating as that might be the answer to why nothing could run to Watford
TimboM
12 Apr 2016
Not sure what was "needed" as such, but the emergency isolation last night was from North Wembley to Bourne End Jnc, which includes Watford Junction.
Pumbaa
19 Feb 2008
Anything south of Northampton is a distraction to the current Govia setup at the best of times.
Not running anything south of MK is just the ticket for them.
Albion91
17 May 2015
I dont know about the possibilities in terms of what trains could feasibly run, but I found it very frustrating this morning that, at 6.20am, many hours after the incident, ticket office staff at Leighton Buzzard could not provide any transport, advice, or useful information at all for people not gong to London. (Even those going to London seemed to be met with the advice of 'drive to Thameslink or Chilterns - not much good for those without a car)
I was told it was unlikely I would be reimbursed the taxi fare to Berkhamsted (£30).
Would it be unreasonable for London Midland to own a small fleet of coaches (say 15) for these kind of eventualities? Maybe train a few drivers to drive coaches?
AndrewE
9 Nov 2015
Given that TOCs seem to be currently abandoning route and traction knowledge I can't see them investing in this - unless they were planning to give up running trains and would thus be using "railway" funding to prepare for their next mission!
