Just seen the timetable options and can safely say that option C is by far my favourite of all. I think consolidating routes into corridors with 2tph clockface on each will be very beneficial for onward connections and reducing conflicts, even if it means there is no longer a service from “everywhere to everywhere”. I’ve always been very fond of the Takt idea and I hope this can be achieved in a way that enables journeys requiring a change to be as quick as they would be with a direct end to end service.
As with any option, there will be winners and losers, so I thought I’d do a summary on the proposed option C routes. I know some points have already been mentioned but I share some similar views so might as well list them here:
Piccadilly - Crewe via Airport
I am all for increasing the frequency of local services on the Styal Line while strengthening the link between Crewe and Manchester Airport, but it is a shame that this particular option comes at the expense of direct Crewe - Stockport stopping services. It would be better to have 1tph terminate at Alderley Edge while extending one of the Stockport stoppers to Crewe in its place.
Mid-Cheshire Line
I am totally in favour of adding a second semi-fast train to the line, but can understand that this will cause a lot of frustration to people in North Wales who would have a slower journey time to Manchester Piccadilly. Even with two fewer stops proposed than the current routing, it would still be slower due to the lower speed limit on the Mid-Cheshire. I wonder if it would be worth looking into increasing the limit as distance wise it is only 5 extra miles to Piccadilly from Chester compared to going via Warrington BQ. As for direct connectivity to Manchester Airport, Welsh passengers will be inconvenienced by the loss of a direct train, but Altrincham would be reached quicker from Chester than the Airport on the current route and could be used as a railhead, with frequent shuttle buses accepting tickets to the airport. The only other option for the TfW route would be to send it into Victoria replacing one of the Northern Calder Valley services from Chester, in which case a Northern semi-fast could operate on the Mid-Cheshire between Piccadilly and Chester only.
Alderley Edge via Stockport
As mentioned above, Stockport - Crewe is going to lose out big time from this. it would be much better to extend 1tph to Crewe in lieu of 1tph from the Styal Line.
Buxton Line
Same as now but without Hazel Grove terminators. The line from there to Stockport will now have an electrified section for no apparent reason, not that I oppose but it might look odd to some.
TPE services via Guide Bridge
Good idea to keep the long distance TPE services running that way, but I wonder if the Huddersfield stopper would be better off going to Victoria via Ashton. The bay platforms at Vic will remain empty under this proposal so you might as well give them some use. Would also free up space at Piccadilly for East Manchester locals.
Liverpool - Victoria - Leeds (TPE)
The most vital part of the North Transpennine corridor, so makes perfect sense to keep it as it is.
Airport - Victoria - Leeds (TPE)
Same as above, and I agree that the Ordsall Chord should still get some use even if it is an operational convenience to some.
Airport - Bolton - Blackpool
The most sensible thing to do IMHO. Strengthens an existing passenger flow while remaining under wires the whole way. Even so, I’m not sure that both tph need to call at Lostock, Blackrod and Adlington. They are sizeable settlements but will slow down the prime Blackpool services. 1tph skipping these would be better to maintain the current Blackpool - Manchester timings.
Airport - Bolton - Cumbria/Scotland
Alongside the Blackpool services, this will provide a corridor 4tph between M’c’r Airport and Preston, a sensible thing to do. Wigan North Western loses out on direct services to Manchester but people can use frequent services from Wallgate instead.
Liverpool - Piccadilly - Sheffield
I really like the idea of running the Cleethorpes and Nottingham services at 30 minute clockface intervals. With the CLC local east of Warrington reduced to 1tph, I would like to think that these two services can provide a skip-stop pattern between alternating stations. Also, I think both services should be operated by EMR as it would allow crew to interwork the two routes.
Liverpool - Manchester via Chat Moss
It is a shame that this cannot be extended to the airport but is a fair compromise as one can easily change at Oxford Road. The main thing is that the local stations on the line maintain their direct link between each other.
Liverpool - Manchester via CLC
Feel a bit sorry for this service, being halved in frequency and curtailed to run between Warrington and Oxford Road only. I guess it had to happen with the other Oxford Road service going via Chat Moss. At least Warrington - Liverpool remains 2tph.
Chester - Victoria - Leeds
A good improvement from 1tph on the existing service, but the big question is whether one of these paths would be better off allocated to the TfW service from North Wales. As mentioned upthread, a handful of people from there will not be happy with a longer journey time to Manchester City Centre, so it may be worth looking at routing it to Victoria instead. In this case you might as well extend it to Leeds as a continuation of the second Chester path. Terminating it at Victoria is another option but would mean reversing in platforms 3&4, and you’d need another Calder Valley service to maintain 2tph between Manchester and Bradford. Also I quite like the idea of having another operator serving the Calder Valley Line, even if TfW may look out of place in Yorkshire.
Kirkby/Wigan - Victoria - Blackburn/Leeds
Good idea. Keeps DMUs off electrified routes as much as possible.
Southport - Victoria - Stalybridge
Again, another good idea. I think it is a fair compromise to keep it off the Castlefield corridor in order to maintain a clockface frequency while keeping DMUs away from wires.
Clitheroe/Blackburn - Victoria - Rochdale
Similar to what exists now but with additional calls between Bolton and Salford Crescent. These will increase journey times which I am sure will inconvenience some people, but should hopefully improve the quality of service for passengers at those stations. Not a bad idea overall.
