Cherry_Picker
Some signalling cable has caught fire in St John's Wood tunnel. Job potentially stopped for 24 hours.
Cancellations to services on all routes
Owing to signalling problems between London Marylebone and Wembley Stadium all lines are blocked.
Impact:
Train services running across the whole Chiltern Railways network may be cancelled or delayed at short notice. Disruption is expected until 08:00 16/06.
Customer Advice:
Marylebone station is closed due to a cable fire. Around 2 metres of signalling cable in the tunnel into the station has burned away meaning the signalling system is not working. Without signals we cannot safely run trains, so are not running to or from Marylebone until new cables are installed and tested. We are not sure how long this will take, but we may not be able to run until Monday morning.
TRAINS TO LONDON:
Trains from Aylesbury via Amersham are finishing at Harrow-on-the-Hill. From there, Chiltern tickets will be valid on the normal Metropolitan line tube trains to Baker Street, which is a few minutes' walk from Marylebone.
Trains to/from Birmingham and Aylesbury via High Wycombe are finishing at West Ruislip. From there, Chiltern tickets will be valid on the normal Central line tube trains to/from Central London. To reach Marylebone, change at Oxford Circus onto the Bakerloo line northbound.
We will aim to run trains at the times they would normally run, but this will not always be possible. Please check chilternrailways.co.uk before travel but there may be some delays during your journey. Trains are especially likely to be delayed or cancelled between 0730 and 0930.
From Birmingham and the West Midlands, it is likely to be easier to use Virgin Trains services via the West Coast Mainline, and your Chiltern ticket will be valid.
TRAINS FROM LONDON:
Trains to Aylesbury via Amersham will start at Harrow-on-the-Hill. Do not travel to Marylebone. Please travel directly to Harrow-on-the-Hill, which is on the Metropolitan line. If you already have a Chiltern ticket, you can use it to travel to Harrow-on-the-Hill.
Trains to/from Birmingham and Aylesbury via High Wycombe are starting at West Ruislip. Do not travel to Marylebone. Please travel directly to West Ruislip, which is on the Central line. If you already have a Chiltern ticket, you can use it to travel to West Ruislip.
Our aim is that trains will leave Harrow or West Ruislip around 15 minutes after they would have left Marylebone. However, these are much smaller stations to turn trains round in, so there may be further delays and cancellations. These are especially likely between 0730 and 0930
If travelling to Birmingham or the West Midlands, it is likely to be easier to use Virgin Trains services from Euston. Your Chiltern ticket will be valid.
Cross Country, Virgin Trains and London Overground services are conveying passengers via any reasonable route until further notice. Arrangements have been made for Chiltern Railways rail tickets to be accepted for these journeys.
First Great Western services are conveying passengers via any reasonable route until further notice.
Last Updated :15/06/2014 08:56
