Merseyrail Northern Line 11&12 and 18&19 Jan Engineering Works
chiltern trev
28 Mar 2011
near Carlisle
Anyone know what the engineering works are for 11&12 and 18&19 January 2020 week-ends?
https://www.merseyrail.org/seasonal/northern-line-engineering-work.aspx
For two weekends in January there will be significant engineering work taking place on our network that will impact our Northen line services.
Saturday 11 January
Rail replacement buses will be in operation between:
  • Kirkby – Liverpool Central
  • Aintree – Liverpool Central (Trains will run between Aintree and Ormskirk)
  • Hunts Cross – Seaforth & Litherland via Liverpool city centre stations (trains will run between Seaforth & Litherland and Southport)
Sunday 12 January & Saturday 18 January
  • Aintree – Liverpool Central (Trains will run between Ormskirk and Walton)
Sunday 19 January
  • Hunts Cross – Sandhills via Liverpool city centre stations
Trains will run between:
  • Sandhills and Southport
  • Sandhills and Kirkby
  • Sandhills and Ormskirk
Skie
22 Dec 2008
Interesting (and rare) move, not had Seaforth & Litherland used as a terminus before! Looks like trains will head to Bootle New Strand and head back turn round using the crossover for the North Mersey Branch, which gets rarely any use.
Statto
8 Feb 2011
At home or at the pub
Seaforth & Litherland is a weird location for a terminus, Waterloo is more natural location with a turning circle for buses opposite the station, trains would still have to go to Bootle New Strand & reverse at Marsh Lane Junction though.
jamesst
4 May 2011
Merseyside
Its been used a fair few times on a Sunday as a terminus to be honest.
AntoniC
28 Dec 2011
Southport
The ramp between Waterloo Bus Turning Circle and Waterloo has been closed for a while now - perhaps thats why they arent using Waterloo ?
Kite159
27 Jan 2014
West of Andover
I assume the work they are carrying out is also the reason why the Liverpool South Parkway (HL) to Warrington Central is closed? [Due to something around Hunts Cross]?
Skie
22 Dec 2008
Theres a bunch of things being done. Power Supply upgrades, track relaying (Brunswick I think?) and signal work. Likely a large rush of jobs to get the network ready for the new trains which will arrive very soon.
chiltern trev
28 Mar 2011
near Carlisle
From RTT
https://www.realtimetrains.co.uk/train/U23155/2020-01-10/detailed
Crewe BasHall S.S.M.[XXM] dep 2228 Friday 10th Jan
via Alderley Edge, Stockport, Manchester Oxford Road, Liverpool South Park pass 0035
Brunswick arr 0046
FRGT 600 tons, diesel loco
https://www.realtimetrains.co.uk/train/H44546/2020-01-11/detailed
Wigan L.I.P.[XWM] dep 0239 Sat 11th Jan
tour around Wigan, St Helens Central, Olive Mount pass 0324
Edge Hill reverse
Bootle Branch past Walton & Anfield to Bootle Oriel Road pass 0351
Southport plat 2 0413-0417 reverse
Liverpool Central pass 0447
Hunts Cross 0458-0503 reverse
Liverpool Central, Ormskirk 0531 reverse
Sandhills, reverse Kirkdale C S arrive 0620 dep 0801
then back to Wigan via Sandhills, Bootle, Edge Lane, St Helens Central, Wigan L.I.P arr 0952.
Diesel loco 75mph but path as EMU (Merseyrail?) when on Merseyrail system.
And another Wigan dep 1451 - Merseyrail tour (Southport plat 1 1646-1750, Ormskirk 2011, Kirkby2123 ) - Wigan 2327 Sat 11 Jan
And 5 Wigan-Wigan circuits on Sunday 12 Jan
https://www.realtimetrains.co.uk/search/detailed/HNX/2020-01-12/0000-2359?stp=WVS&show=all&order=wtt
Any comments on these movements?
jamesst
4 May 2011
Merseyside
From RTT
Brunswick arr 0046
Edge Hill reverse
The first one looks like an engineering train, the second is the path used by the mpv.
CICERO55
6 Sep 2018
According to merseyrail sources, you can ask them, the new trains wont be able to run for the foreseeable to the south of Liverpool due to the bridges at aigburth and cressington. You couldnt make it up.
Skie
22 Dec 2008
First one of those is definitely an engineering train, there's a similar move to Bootle Jn in the early hours.
chiltern trev
28 Mar 2011
near Carlisle
What is/are the problem(s) with the bridges at Aigburth and Cressington?
Presumably the 507s/508s do not have a problem at these bridges.
66502 on the engineering train at Brunswick.
https://www.flickr.com/photos/45566949@N07/49366787142/
M60lad
31 May 2011
If the above is true about those 2 bridges how soon will the problem with the bridges at Aigburth and Cressington be sorted out? What will happen to the service in the mean time while the bridges are sorted?
Skie
22 Dec 2008
The bridge stuff could be getting sorted as we speak as the engineering work is happening on that stretch. But as it’s all just “someone told someone who told my cat” there’s no way to tell if there’s a troll under the bridge that needs a bung to allow more than the existing stock under his bridge or if it’s just a simple alignment issue.
Geeves
6 Jan 2009
Rochdale
It sounds similar to the 195 horror stories over the Calder Valley where entire bridges and tunnels had to go, when in the end it was a week's worth of over night work to shave 10mm of stone off the tunnel walls.
I expect to see a 777 down there in 6 months time.
urbophile
26 Nov 2015
Which bridges and what is the problem? Is this a fault which would need rectifying anyway or something to do with clearance, which seems strange since the new trains are no larger surely. And if it's the latter why was this not identified ages ago when the work on the platforms was being done?
jamesst
4 May 2011
Merseyside
I'd take the someones told me with a large pinch of salt to be honest, if anything the main problems on the route are the signalling at Liverpool Central and Southport. That's meant to be getting sorted early this year.
chiltern trev
28 Mar 2011
near Carlisle
Some photos have appeared on David Powell's twitter feed - https://twitter.com/DavidPo22194359
photos
https://pbs.twimg.com/media/EN_fBtxX0AEwM0L.jpg
https://pbs.twimg.com/media/EN_fBtwXUAAnC8F.jpg
https://pbs.twimg.com/media/EN_fBt9XUAAPPhb.jpg
https://pbs.twimg.com/media/EN_fBt_X4AEuRGx.jpg
Looks like work in the tunnel(s) between Brunswick and Liverpool Central - by Upper Parliament Street/St James Church junction.
And from https://twitter.com/merseyrail there is this photo (in same tunnel(s)?)
https://pbs.twimg.com/media/EOGXZInW4AIyJFX.jpg
https://pbs.twimg.com/media/EOFBJd8X0AAepiR.jpg
https://pbs.twimg.com/media/EOFBJm9X4AAl2kB.jpg
https://pbs.twimg.com/media/EOFBJ4ZW4AA581J.jpg
https://pbs.twimg.com/media/EOFBJv0WkAIZlr2.jpg
MR-507508
17 Jan 2020
North West
Do you think Merseyrail will be announcing a series of planned works to be undertaken this year soon (similar to what they did for the platform upgrades) regarding the works which still need to be undertaken with the signals and Southport station track layout/platform lengths-maybe other stations too?
jamesst
4 May 2011
Merseyside
Yep theres another round of closures due to be announced soon
jamesst
4 May 2011
Merseyside
All lines and terminal ends. For example if a train at New Brighton is shunting from the platform to siding or vice versa the signalling will have to take increased coach lengths into account. The underground which uses axle counters will be another area that needs doing
Bevan Price
22 Apr 2010
With the various changes, will 777s & 507/508s be able to operate simultaneously, or will Northern & Wirral lines each require a single date on which "new" completely replaces all of "the old" ?
73001
2 Jun 2010
I think somewhere on here it said Kirkby line was first for new trains. I expect the systems can cope as they already have 3 car and 6 car and the MPV travelling round so it must be able to tell the difference.
modernrail
26 Jul 2015
A sort of on topic question I think...why are there no buffer stops at Southport? Is there not a safety requirement for them at all stations?
Tomnick
10 Jun 2005
Just out of interest - why, exactly? Taking the example of the shunt at New Brighton, and assuming that the longer trains fit inside the signal on the platform and in the sidings, the shunt move will just have to go a bit further to get clear behind the dolly, but I can’t imagine it’s *that* tight to the next signal in advance?
jamesst
4 May 2011
Merseyside
It depends on the location of the various track circuits New Brighton as an example can be a bit problematic as it is when shunting from siding to platform with the system sometimes reading a 3 car as a 6. This will obviously have to be rectified before any potential 8 cars start running.
