IrishRailScene
Does anyone know where and if it’s possible to download MSTS?
Is it possible to get MSTS stuff anymore??It was sold as a DVD-ROM, and you’ll see these from time to time on eBay. However, there were some pretty fundamental patches that are hard to find and even after that, the game is 20 years old so WAAAY off the mark compared to more recent iterations. Since the site uktrainsim.com closed, it has been very hard to get non-US freeware and patches.
Does it work on ASUS?I still own and play MSTS from time to time - it will run on Windows 10, surprisingly! Fortunately I've owned the game since 2001 and have various UK add-ons. It's not, to my knowledge, available to download anywhere, but as jp4712 says the base game does pop up on eBay relatively often.
ASUS is a manufacturer of computing equipment. @IrishRailScene needs to be a bit more specific about whether or not they have a laptop/PC (likely to be running Windows) or a tablet (Android).Not sure what ASUS is I'm afraid.
But note that OpenRails can sometimes have issues with MSTS content and is not a 1:1 replica. You can run MSTS perfectly well on modern hardware and I recommend doing that for MSTS-produced content.Instead of MSTS, you would be better off downloading Open Rails which is an open source TS that was reverse engineered to be compatible with the original Kuju file formats.
This is not entirely true. If you have an Nvidia graphics card MSTS will work fine. If you have an AMD graphics card or use Intel integrated graphics you may have issues. See Steam4me's comprehensive tutorial on installing MSTS: https://web.archive.org/web/2023011...m4me.net/tutorials/installing_msts_win10.htmlFrom what I've read you're not going to be able to run MSTS on anything beyond Windows 7 or 8.x due to DRM issues. You may want to considering running it in a vm..shouldn't be that taxing especially on a modern machine. When I first installed it twenty-something years ago around its original release it wasn't exactly resource-hungry even then.
Any issues to look out for?
- It appears that MSTS will install but not run on PCs fitted with standard Intel Graphics cards (theses are often embedded in the motherboard). Stick to nVidia graphics cards.
- It appears that MSTS will install but not run on PCs fitted with AMD/Radeon graphics cards. Ged Saunders over on uktrainsim writes "The last version of the HD Series drivers available from the AMD site which enables MSTS to work under Windows 10 with an AMD HD graphics card (plus "fix") is 16.8.3. This is shown as 16.300.2511.1003, dated 30/08/2016 on the Driver properties screen (from Device Manager)." The challenge appears to be that Windows Update updates these drivers rendering MSTS unplayable. Once again best to stick to nVidia graphics cards.
- Default MSTS will not run on UHD monitors (ie resolutions greater than 2048 pixeds) - there are patches available (beyond the scope of this particular tutorial).
