Mk 4 flexibility
I was just wondering how flexible the formations of Mk4s were. I know that the HST Mk3s sets are pretty flexible in that you can pretty much combine them in any combination that you want (such as the FGW set that was almost entirly made up of TFOs for a railtour this summer). So could you have for instance a Mk4 set made up of only TFOs for example and use it in passenger carrying service?
My other question relating to Mk4s is can they be used in service with any locos other than the 91s or the 67 drags? So could you couple up for instance a 90 to a Mk4 set and use it in service with no other modifications?
MCR247
7 Nov 2008
90s have been used on the ECML with MK4s under GNER. I think the reason was 91s were having an overhaul or something. They were used on Leeds trains because although they are slower, the quicker acceleration helped with the stop-start nature of the services :)
jonhewes
8 Oct 2008
I believe that MKIV sets can be used in DVT (Push Pull Mode)with any TDM fitted loco. They could in theory be hauled as conventional pasenger rolling stock in service by any ETS fitted loco.
In the past they have operated with 89001 and various class 90s (both under Intercity and GNER).
Footage of them operating with a Belgian liveried 90 can be seen here
rail-britain
12 Aug 2007
When the Mark 4 coaches were first introduced on the Kings Cross - Leeds service, many had 4 or 5 First Class, 2 RFM, and 4 Standard
The only restrictions to the formation were the TSOE and DVT at each end and the total ETH rating
It would therefore not be possible to have an entire rake of First Class, unless it had a DVT at each end
43167
18 Jan 2010
Keighley
Mk4's can be hauled by anything.
Apart from 91's, been hauled on them by 47's, 67's, 89001, 90's.
junglejames
8 Dec 2010
I think this was when the 91s went from being 910XX to 911XX
Yep, you would be right. A major overhaul to improve reliability. Including using up the space that was left aside for tilt equipment. So it would take a fair bit of work to enable them to tilt now! For something to do with improved cooling i think.
Failed Unit
26 Jan 2009
Central Belt
In the 91 snow the class 91s were removed as they didn't like powder snow and the were replaced by many different locos including the class 31. Shame we haven't got the spare locos or drivers with route knowledge to do that if needed now.
Thanks for the answers guys, its what I was expecting but always nice to be sure :)
Crossforth
20 Aug 2009
Lancashire
Has anybody got any pictures of this as I would find it interesting to see
E&W Lucas
21 Jan 2010
Depends.
Mk IV's are fitted with tightlock couplings, with the exception of the pointy end of the DVT (conventional drawhook), and the north end of the TOE coach ( the one marshaled next to the 91), which has a drop head buckeye. That means it can be coupled to a buckeye fitted loco, or one with a conventional screw link, if you get the buckeye out of the way, and extend the buffers. Only the DVT & TOE can be coupled to a loco. Any other coach needs a tighlock fitted barrier vehicle.
Provided that you can couple to it, yes they can be hauled by anything, but if you want the set to play in Push Pull mode, the loco needs to be TDM fitted, and that seriously limits your options.
