richieb1971
- Joined
- 28 Jan 2013
- Messages
- 1,981
All from Bromham road bridge north of the station.
Station pictures looking south, other one looking north.
I can't quite tell, has the siding north of the station been de-electrified? I seem to recall it's too short for a 700.All from Bromham road bridge north of the station.
8 car 700's regularly go in there. I think I saw one in there the other day when passing over the bridge in the car.
It will not take a 12 car unit. So it only gets used periodically when the services require at max an 8 car unit.
As a result of this the 12 car units need to do a double reversal out of the Jowitt Sidings and can only access P1 and P2.
In a few years time it will be interesting to see what Network rail do. You will have EWR, Thameslink and EMR trains coming and going. I always said they should put 2 sidings north of the station near Bromham accessible from Lower farm road or the A6. Or they can utilize the sidings at Corby and just run all units the full length of the OHLE track.
Something has to give. At the moment most freight use all 3 main platforms bidirectionally and that is a sign of a bottleneck. It's well advertised this is the case. I can't remember the last time a freight entered the station from the north without halting at Bedford north. When taking those pics the Bletchley Peak Forest was stuck at St Johns for 30 minutes. There was a 700 parked up in P1 going south, then a track machine coming from the south using P1 (technically the wrong way) on the same platform, followed by the Bletchley Peak Forest 6h10 working using P1 again all in the space of 10 minutes.
No change to the layout at Bedford as part of the Electrification although it would make sense to have a platform on both fast lines.Wasn't there plans a while ago to turn platform 4 into an island with the new P5 becoming the DF and P4 becoming the UF, in which case that would allow the existing UF to become a freight line. Guessing as it hasn't happened as part of the electrification scheme it has been dropped or never progressed passed the 'nice to have' stage.
Ideally both fast line platforms at Bedford need to be on loops so that the fast lines themselves can keep an unbroken 125 through. At the moment this is possible on the platform-free up fast, but not on the down fast because the platform limits the amount of cant that can be applied.I suspect the ideal for Bedford would be 3 island platforms, one for the fasts, one for Thameslink, and the third for EWR, with turnback sidings north of the platforms for Thameslink and EWR. Biggest problem I suspect is the distance between the northern end of the platforms and Bromham Road bridge, which would probably need another rebuild, along with the closure of the road immediately north of it.
Indeed. I was thinking more of a nice smooth speed-profile (though that doesn't seem to be considered as desirable these days as it used to be) and the small cost of braking and acceleration. I haven't looked up today's speeds, but when the MML went from 100 to 110 there were 100 restrictions through Elstree and Ampthill tunnels (pressure questions) and the time-loss for each of those was a similarly small number of seconds.The time loss on the down fast throughthe platform for not being 125mph is about 8 seconds.
The turnouts would need to be on the straight to maintain 125 on the through route, which I think means the loops would have to continue all the way through the reverse curve to the south including new bridges over the river. There's hardly any operational benefit to having loops here, as there's no routine overtaking and anything being overtaken out of course would be on the slow side of the station anyway.Ideally both fast line platforms at Bedford need to be on loops so that the fast lines themselves can keep an unbroken 125 through. At the moment this is possible on the platform-free up fast, but not on the down fast because the platform limits the amount of cant that can be applied.
Yes, the Down Fast has been wired for a while, and the Up Fast was completed at the weekend. They aren't yet live, however.
I have a few days off this coming week, would like to know of any live trains running on the OHLE.
There’s loads, all south of Bedford. (As stated above, the OLE is not in service north of Bedford yet)
Apparently it's been turned on overnight to a point between Bedford and Wellingborough.
Turned on doesn’t equal in service.
Thanks for sharing. The Twitter link confirms it has been energised to Irchester.
That should mean that Harrowden TSC (at Finedon Station Rd) and Kettering North TSC (at Glendon) are in the next job lot for energisation.Thanks for sharing. The Twitter link confirms it has been energised to Irchester.
