Looks good! I think the stovepipes here are mainly for the Earth Wire on the UM side; the ones carrying the actual cantilevers look to be square in section.Stove pipes have appeared on the cantilevers in Little Bowden, Market Harborough.
Looking north by the footbridge...
.....south.
Just occurred to me, is the choice between round and square to deal with preventing rotation of the stove pipe and the components directly fixed to it?Looks good! I think the stovepipes here are mainly for the Earth Wire on the UM side; the ones carrying the actual cantilevers look to be square in section.
Possibly - although the allocation of the pipes varies from route to route.Just occurred to me, is the choice between round and square to deal with preventing rotation of the stove pipe and the components directly fixed to it?
Oh well, I suppose it was worth asking but the railway always seems to complicate the answer…Possibly - although the allocation of the pipes varies from route to route.
The WCML has cylindrical stovepipes on all its modernised runs (i.e. UK1 equipped).
More recently, the ECML nr Werrington Jn used square stovepipes for everything.
Just the nature of different designs and suppliers, I suspect.Oh well, I suppose it was worth asking but the railway always seems to complicate the answer…
Is a third wire of some sort being installed on the far right of the cantilevers?Taken from LinkedIn the other day; at Rushton (bridge SPC3-42) most of the cantilevers looking east (towards Kettering) have now been fitted to the stovepipes.View attachment 119258
Yep, that'll be the earth wire. There should be clamps for a second earth wire to the left of them too.Is a third wire of some sort being installed on the far right of the cantilevers?
I can't see any but I'll take your word for it!Yep, that'll be the earth wire. There should be clamps for a second earth wire to the left of them too.
AIUI this bit of the MML will have auto-transformer feeding in use, but these are likely to come into play later down the line. Most of the single track masts have the additional height on them to fix ATF insulators above the cantilevers; an 800mm gap between the ATF (if bare) and main conductors is mandated by NR. I've certainly seen no ATF insulators installed yet, but that doesn't mean that they won't be.I can't see any but I'll take your word for it!
This bit isn't autotransformer is it?
Ah ok, thanksAIUI this bit of the MML will have auto-transformer feeding in use, but these are likely to come into play later down the line. Most of the single track masts have the additional height on them to fix ATF insulators above the cantilevers; an 800mm gap between the ATF (if bare) and main conductors is mandated by NR. I've certainly seen no ATF insulators installed yet, but that doesn't mean that they won't be.
As for the EW clamps, the UM ones are directly on the masts and are a little harder to spot - but they are there.
Surprised this isn't permitted development so no need to notify but helps us keep abreast of what the plans are.That being said, I've had a look on Kettering Borough Council's website, and the following applications should be of interest to people on here:
(no such joy yet on the Harborough District Council Website btw)
- NK/2021/0633 - Bridge SPC3/42 (Rushton) - shows details of new bridge reconstructed in place of existing.
- NK/2021/0748 - Bridge SPC3/39, Harborough Rd (B576) - shows details of bridge parapet alterations to facilitate electrification.
- NK/2021/0745 - Bridge SPC3/40, Pipewell Rd - shows details of bridge parapet alterations to facilitate electrification.
- NK/2021/0775 - Bridge SPC3/34 (Three Arch Bridge), Braybrooke - shows details of bridge parapet alterations to facilitate electrification.
- NK/2022/0389 - Bridge SPC3/35 (Newtons Bridge), Braybrooke - shows details of new bridge installed to south of existing, and removal of existing bridge
- NK/2022/0407 - Bridge SPC3/42 (Rushton) - shows details of revised approach on Up Main side following bridge reconstruction
Assuming the Newtons Bridge submission is representative of the others, they will be mostly/wholly under permitted developmentSurprised this isn't permitted development so no need to notify but helps us keep abreast of what the plans are.
Spicy!Contact wires are in place either side of Bridge SPC3/37F - A6 Desborough Bypass. Stops short of Bridge SPC3/37 - Chaters to the north. Not sure how far they stretch south towards the Desborough Gap.
Apologies for having not quite kept up, but could somebody answer the following questions please?They don't reach Bridge SPC3/38 - Judges; that I can confirm.
Wigston South Junction.Apologies for having not quite kept up, but could somebody answer the following questions please?
Exactly how far north has now been fully funded and committed?
Others will correct me, but a lot done as far as Market Harborough, very little north of thereOf this, are all the masts up or are some sections still waiting for big steelwork/piles? And how much wiring still requires to be fitted?
No, though there has been some preliminary contractor engagement.Separately, have invitations to tender for the contracts for any later sections been issued by DfT/NR?
Have contracts been signed/work begun on this section? Sorry, I'm just a little confused by references to the Desborough Gap, implying work has started north of MH when I thought the Wigston Section had only been approved but not contracts issued. I took my eye off this project for a bit and am just catching up now!Wigston South Junction.
AIUI, the section to Wigston South is now a live project. The presentation referred to in this post shows what was said at the public meetings.Have contracts been signed/work begun on this section? Sorry, I'm just a little confused by references to the Desborough Gap, implying work has started north of MH when I thought the Wigston Section had only been approved but not contracts issued. I took my eye off this project for a bit and am just catching up now!
The presentation (in PDF form) from the recent 'NR + public' meetings at places north of Mkt Harboro' has been published on NR's website.
It also gives locations of work compounds and substations (compounds in yellow, substations in pink):
Timescales are also given for the next phases of the work:
- One at East Langton (where there'll also be a substation; East Langton ATS if memory serves),
- One at Kibworth Harcourt (Wistow Rd; no substation), and
- One at South Wigston (either side of Blaby Rd Overbridge; compound to the north, substation (South Wigston SATS) to the south).
- Ground Trial Holes: started 15/7/22, planned to run to 29/10/22;
- Compound Setup & Road Rail Access Point (RRAP) install: started 15/7/22, planned to run to 27/10/22;
- Vegetation Management: started 15/7/22, planned to run to 6/6/23;
- Piling: planned to run from October 2022 to August 2023;
- Steel installation (assuming main steel & small part steel): planned to run from November 2022 to September 2023;
- Wiring: planned to run from January 2023 to December 2023; and
- Adjustments & Assurance: planned to run from February 2023 to January 2024.
Aha! Much obliged, 18 July would tie quite nicely with me being rather distracted at the time! (I know I posted around then, but I wasn't paying as much attention as I might like!)AIUI, the section to Wigston South is now a live project. The presentation referred to in this post shows what was said at the public meetings.
Midland Main Line Upgrade - Network Rail
We’ve started the biggest programme of improvements to the line since its completion in 1870.www.networkrail.co.uk
That’s one stove pipe on the left for an overhead line, but another will be fitted for the other track. The smaller tube on the right is to carry another wire, I think it’s an aerial earth wire that was mentioned earlier.The missing cantilever by the footbridge in Little Bowden, Market Harborough has appeared with two stove pipes. One smaller than the other?
Thank you, interesting.That’s one stove pipe on the left for an overhead line, but another will be fitted for the other track. The smaller tube on the right is to carry another wire, I think it’s an aerial earth wire that was mentioned earlier.
But if you check out the earlier photos in post #5630 you’ll see some with the 3 stovepipes fitted. The 4th photo probably shows it best.
This is an infrastructure thread so it’s probably not the right place, but I think it’s fairly certain that there will be no change to the service, particularly as the current work will not even get as far as the station.This may not be the right place - I apologise.
Once the electrification is completed to Leicester what will be the effect on the timetable/service?
For example will Market Harborough have an improved service - faster more frequent trains?
Agreed - any further timetable changes are a way off yet.This is an infrastructure thread so it’s probably not the right place, but I think it’s fairly certain that there will be no change to the service, particularly as the current work will not even get as far as the station.
St Ricardo, welcome (in case that's not been saidThis may not be the right place - I apologise.
