Nottingham59
And the main uncertainty on track layout is between Wigston and Leicester station, so it makes sense to leave that section for now, if you canSo they could do RS3 and RS2b without having to do the station.
Small price to pay for getting the bulk of the MML electrified and it won't affect operations. Otherwise we get hung up on a complex bit with unfinished aspirations and over engineer it and the whole project stalls (compare with HS2).But, sadly, it means the the only place that diesel fumes are emitted on the journey from St Pancras to the North is in Leicester city centre...
If that is the only place left, it'll be a much stronger case for infill.But, sadly, it means the the only place that diesel fumes are emitted on the journey from St Pancras to the North is in Leicester city centre...
Very true and ideally infill will be done when the track layout at Leicester has developed into what is deemed ideal for operations.If that is the only place left, it'll be a much stronger case for infill.
Batteries will deal with Leicester.Aren't clearances the big issue? It's much easier raising the level of a major road over a bridge in Northamptonshire than London Road in central Leicester.
You'll potentially be able to make big cost savings by combining any works for the track layout with electrification prep works.Aren't clearances the big issue? It's much easier raising the level of a major road over a bridge in Northamptonshire than London Road in central Leicester.
I understand that the main station bridge has enough clearance for electrification, perhaps with special measures.Aren't clearances the big issue? It's much easier raising the level of a major road over a bridge in Northamptonshire than London Road in central Leicester.
Is the really big problem with further MML electrification (whenever it gets approved) the height available at Leicester ?
That is a problem. However AIUI it can be solved in the same was as at Cardiff.
That diagram has an interesting opinion of where South Wigston is in relation to the other lines in grey!It's on page 5 - the summary blob still refers to Section 2 but it's marked as 2a/2b on the line diagram.
(You have to zoom in and the diagram is of low resolution, so not easy to find.)
The pessimistic me, sees this as an indicator that Leicester station will never get wired. I don't believe that little bits should be missed out. Just do it properly.
The class 810s soon to be delivered are Bi-Mode so will cope just fine.Batteries will deal with Leicester.
I don't mind if Leicester is never wired. Sure I like to see it all complete and continuous - be it electrification or any other thing. But it is no great loss. No point stalling the whole MML electrification over one location - Leicester. Look at HS2 it has become over engineered (the way I like it) but all of a sudden DEAD.The pessimistic me, sees this as an indicator that Leicester station will never get wired. I don't believe that little bits should be missed out. Just do it properly.
Nowadays the "get out of jail free" opportunity means electrification is more likely. Remember we have had very very slow progress on electrification in the UK. Now we have Bi-Modes we can get on with what should have been done in the 1970s or early 1980s. The East Coast Mainline was done on a budget as otherwise it would never have happened - granted we have to improve it nowadays but it would still be diesel if we had planned ahead !. The over engineered, over budget and consequently incomplete Great Western Mainline electrification nearly killed off future electrification. The Midland Mainline electrification is proving the railways can have a pragmatic and cost-effective approach to electrification. I do like to see things all neat, tidy and complete but in the real world it isn't like that unfortunately.In my 'left-field' bit of thinking, it's unfortunate that there are now bi-modes. The early 25kv schemes didn't have that 'get out of jail free' opportunity so they were forced to (and did) overcome every problem. The first extension from the MML towards Snow Hill (London!) on slab track being a good example, i.m.o.
Thinking about it I realise the UK has as much as forty years of catching up to do on electrification !. Fingers crossed for the MML sparks effect soon(er).Yes indeed, all fair points well made.
My skim read of it after a large gin last night was the need to increase the rate of progress (which has been painfully slow) and so need a lot more resource.Well i sincerely hope so this team have proven themselves and i know we don't have visibility on costs but in terms of achieving programme they are doing that and thus it would be travesty to lose momentum now.
Not sure why you would tell tenders what your upper limit is!! Anyhow with SPL having done a big chunk of MML of varying degrees of complexity they will have pretty good experience about what drives cost and where efficiencies can be made, ie a blockade would allow an x% reduction in unit rates. Clearly you cant do much about the cost of raw materials and inflationary wage rises but an ability to have a live construction site is an absolute necessity for training staff to build a larger workforce if Network North electrification goals are going to be realised.My skim read of it after a large gin last night was the need to increase the rate of progress (which has been painfully slow) and so need a lot more resource.
However with so little electrification ongoing there isn't really the supply chain to scale and drive cost down.
So to me, the talk of partnership/alliance models mens that I think they want to nurture and grow capability and reduce cost by building out from the current suppliers. It's not a standard retendering asking for a bit more quality and s bit less cost than the current contract.
Also confirmation that current cost is £3.7m/STK and the target is 2.5
I can only see the tender notice and Part 6, "instructions to participants". Is the "Strategic Brief" available to view?My skim read of it
Apologies if I have lost track but is a fourth line Leiceste-Syston and a second Syston platform in scope?
Hi, where is Leicester North exactly?NR issued a contract notice for the MMLE Partnership Framework today, in relation to MML3:
Network Rail Eastern Midland Main Line Electrification Partnership Framework - Find a Tender
www.find-tender.service.gov.uk
Plenty of material to examine, though I'll quote a few key paragraphs (from the Part 6: Instructions to Participants PDF):
Also, RS2 is now split into RS2a (Wigston South-Leicester North) and RS2b (Leicester North-Syston).
It's either that or they're planning to electrify the preserved Great Central Railway from it's southern terminus northwards.I presume NR mean Leicester North Jn, which is immediately north / northeast of the station.
So they are planning to electrify without the fourth track…..please tell me they will design it to not impede adding a fourth later….?As part of electrification? No.
I assume within the disused track bed of Knighton Tunnel?Where is the 4th track going?
From Syston to Leicester. It was four track before no?Where is the 4th track going?
The rail infrastructure company has just started the hunt for four key partner contractors to deliver the next £1.2bn upgrade from Wigston and Nottingham out to Sheffield.
A key objective is to use its SPEED principles and incentives to drive down the spend per single track kilometre on the electrification project.
Using these, the recently commissioned London to Corby electrification was delivered at a rate of £3.7m per STK.
Noe Network Rail procurement chiefs are aiming to deliver the next stage of electrification at £2.5m per STK.
A new 10-year partnership framework to deliver the project, which has just come out to tender, will include the performance-based incentives to drive down the STK rate and achieve other MMLE objectives, including health and safety, decarbonisation and social value.
Partners will be incentivised both individually and collectively.
10-year framework (5+5 years) will be split into the four work disciplines
Lot 1 – Power & Distribution (value £125m)
Lot 2 – Structures & Civils (value £340m)
Lot 3 – OLE & Integration (value £450m)
Lot 4 – Signalling & Telecoms (value £100m)
There will be 1 Partner plus 2 pre-qualified reserve suppliers appointed to each of the lots.
Is cutting a third off costs/quotes realistic ?. Is it going to lead to silly bids that turn sour half way through construction, de-scoping or lead to poor quality.Construction Enquirer is saying Network Rail looking at Contractors for Wigston-Nottingham / Sheffield electrification and wants costs down to £2.5m per kilometre
Target to slash costs by third on £1.2bn Midlands rail upgrade
Network Rail sets £2.5m/km electrification costs target on Nottingham and Sheffield stretchwww.constructionenquirer.com
