Could also look at the Stadler GTW. This is available in a variety of dimensions and with a diesel or electric central "power pack" between the two passenger sections, so there is the possiblity of ordering DMUs and rebuilding them as EMUs later.
http://en.wikipedia.org/wiki/Stadler_GTW
I'd much rather sit on a well padded 142bus seat than an 150 where the seats have almost no padding and haven't had any real change since BR introduced them.
Statement of fact or just an opinion?Nobody is going to pay for a high floor design conversion.
The problem with Pacers isn't just the bad ride quality, poor accessibility, unreliability & general poor appearance that makes you feel like you're in a developing country. The problem is that the whole concept is out of date. That out of date concept is building rolling stock as cheap as humanly possible, with full lifecycle costs not emphasised enough.
If you don't want a significant increase in operational costs on routes Pacers currently operate on, then a Class 172 would not be a suitable replacement. A single Class 172 car weighs around 40 tonnes. A single Class 142 car weighs around 25 tonnes. A Class 139 weighs 12 tonnes
I'm not an engineer; but wouldn't it make a difference that the weight of a single Class 142 car is only spread over 2 axles, whereas the weight of a single Class 172 car is spread over 4 axles. So the axle load of the Class 172 would be lower than that of the Class 142.If you don't want a significant increase in operational costs on routes Pacers currently operate on, then a Class 172 would not be a suitable replacement. A single Class 172 car weighs around 40 tonnes. A single Class 142 car weighs around 25 tonnes.
Surely that makes the 172 a better choice than a Pacer if you're considering track maintenance costs?
Sits back to await the inevitable corrections following my total misunderstanding of the science!
Thanks for the comments so far (and to Metrailway for digging out the charges).Interesting that the 150 on the linked list is 4.99p per vehicle mile so the difference can't be down to maximum speed. Also interesting that the 168, 170 and 171 have different figures despite being 99% identical!
In theory the access charge takes account of the wear and tear caused by each unit, which will allow for things like how track friendly the bogies are. The same weight on fewer axles will indeed cause less wear and tear but as pointed out the Pacers are lighter so this may cancel out to a large extent.
Rail Magazine issue 582 said:Each [Class 172] vehicle is around three tonnes lighter than a normal Class 170 because they are fitted with B5000 bogies - as used under Class 220 Voyagers - rather than the Turbostar P3-23 and T3-23 power and trailer bogies. The result is that a three-car Class 172 will weigh 122.7 tonnes rather than a Class 170 133t. Bombardier also hopes that using B5000 bogies will result in lower track access charges for the train.
Could also look at the Stadler GTW. This is available in a variety of dimensions and with a diesel or electric central "power pack" between the two passenger sections, so there is the possibility of ordering DMUs and rebuilding them as EMUs later.
I think they have already decided on the replacement for the pacers in the North West.......it's the Class 319 hand me down Thameslink trains followed by the inevitable casscade of slightly better units and the possible withdrawal of some pacers...oh joy! second hand stock again.
I don't have figures for the 172 but Pacers are charged less by NR for track usage when compared to the other Turbostars. Presumably because Pacers cause less track wear. I would not be able to explain why as I am also not an engineer. Figures from: http://www.networkrail.co.uk/browse...harges/b - track usage price list for cp4.pdf
Pacers:
142: 3.95ppvm
143: 3.93ppvm
144: 3.93ppvm
Turbostars:
168: 6.65ppvm
170: 7.29ppvm
171: 6.74ppvm
Um, I'd look at what's happened in the past. Line is wired, to keep costs down second hand stock is used. Couple of years later New Build EMUs are ordered (For Example Class 323 in Manchester or 333 & 321/9 in Yorkshire)
What lines were wired in the Manchester area that got new trains soon after? Apart from two very short sections of track: Hazel Grove-Stockport and the Airport spur off the Styal line when it opened EMUs had been operating in the area for a while. While those two short extensions were around the same time as the Sale line was converted to Metrolink so the cascaded stock didn't need to come from another part of the country.
Except Pacers are high density units designed to allow quick boarding / unloading whereas the 156s / 158s are longer distance units - so not really a suitable replacement.I think the 2019 Pacer replacement should be cascaded 156's / 158's. That would be a huge improvement.
Pacers are cheap & nasty and are unsuitable for anything other than the shortest distance work, so why in 2013 are they still being used on long distance services such as:
Blackpool South - Colne (1 hour 50 minutes)
Man Picc - Chester via Altrincham (1 hour 30 minutes)
Man Picc - Sheffield (1 hour 20 minutes)
Man Air - Southport (1 hour 20 minutes ?? )
And how many people, on a daily basis, are doing those journeys 'end to end' on a Pacer. I suspect the number runs into a couple of hundred at best.These are probably the worst services in the UK you can possibly ride end-to-end.
Any more anyone wish to add ?
Even if the Pacers get scrapped from 2019, which is too far away as it is, I'd like to believe they will be removed from the long-distance routes well before then.
Although Pacers are too often found doing work that really belongs to a 156 or 158 - such as Newcastle-Carlisle (1h25-1h30)Except Pacers are high density units designed to allow quick boarding / unloading whereas the 156s / 158s are longer distance units - so not really a suitable replacement.
True. But in the Letchworth example, those making end-to-end journeys are more likely to use the fast services to Kings Cross (operated by 317/321/365 units). On journeys such as Newcastle-Carlisle there is no express alternative.Also, just because a journey has a long journey time, it doesn't mean it is a 'long distance' journey - in all of the above, the journey is no more than 50 miles. You have 'inner suburban' stock working in the London area doing exactly the same kind of distances (e.g. Cl 313s to Letchworth).
You can find an exception to suit any rule if you look long and hard enough.Although Pacers are too often found doing work that really belongs to a 156 or 158 - such as Newcastle-Carlisle (1h25-1h30)
Something to do with "demand" no doubt but just to introduce some facts:True. But in the Letchworth example, those making end-to-end journeys are more likely to use the fast services to Kings Cross (operated by 317/321/365 units). On journeys such as Newcastle-Carlisle there is no express alternative.
3. The 319s are currently less flexible so a 4 car EMU could finish up running a service that was expected to be a 2 car DMU in the off-peak periods
That's exactly what I expect to happen. We buy new EMUs for the South, resulting in a unified fleet of Electrostars for Southern and SouthEastern. The random hodge-podge of existing units is cascaded to the North to immediately take advantage of new wires going up. Then, when a new Northern franchise is awarded, with lots of recently electrified route miles, it's under the proviso that the train fleet is replaced with new units.
if you were doing Chester-Bolton on a Sunday in the Bolton direction
Remember Bolton-Southport would only allow half of Northern's Southport services to switch to EMU as the other half travel via Atherton. However, saying that a lot of the Airport-Southport services are now 4 car Pacers
This is true.
But it does spoil your "a three coach 172 would be better than two 142s coupled together" argument (since the 172 is obviously less flexible).
Is this a journey that a lot of people do each week though?
Most electrification schemes see some kind of timetable recast (i.e. running all of the Southport services via Bolton).
