And what about all the other stuff that NR do that isn't about track and signalling?I think NR should be split up and employees and assets absorbed by TOCs. This way TOC is responsible for track and signalling maintenance and this will provide an incentive for sorting out things quickly when things go wrong as they would no longer get compensated for failure.
Regarding the suggestion of TOCs running the whole railway, do we really want a TOC, which will only be around for a few years, making long term engineering decisions, such as on S&C renewals which may last fifty years?
Spoken like a true Labour (Scottish branch office) man, John!
The TOCs do not actually own any physical assets
https://www.transportfocus.org.uk/r...ions/how-the-rail-industry-works-an-overview/Do you know of a link which explains (in laymans terms) how the rail network actually operates? The idea that the companies don't own any physical assets is not intuitive, and is likely lost on the majority.
and how do you do that? The infrastructure is owned by the nation, the TOCs run a franchise. Are you suggesting that NR is broken up and 'sold' to the franchisee? The TOCs do not actually own any physical assets
Why? Difficult to be an operator and regulator!How do you devolve System Operator? It is either the system operator or it isn’t....
Though shouldn’t ORR be the system operator?
Thanks, it looks interesting and informative. It says the trains themselves are owned by a rolling stock company and are leased to the rail operators. This suggests to me that when people ask why they can't put more trains on routes that are overcrowded, it is not that simple as that, even if there is spare capacity on the route, there might not be any more trains available to lease. Is this correct?
If the trains are not owned by a rail company and are owned by a separate company, how is it that the rail companies can put their livery on the trains? I would have thought that if the trains are leased, they would all be some neutral livery, but evidently there is some flexibility for rail companies to make alterations.
In most cases, it hardly matters whether trains are leased, or owned by the TOCs - it's simply a case of there not being sufficient suitable rolling stock available. Around two thirds of the lines in this country (by mileage) are unelectrified, and there is a huge shortage of diesel units. So it hardly matters what the ownership structure is - TOCs can't magic trains out of thin air! The best they can do is to reduce the length of other services, but it is always a trade-off, and there isn't one perfect solution.Thanks, it looks interesting and informative. It says the trains themselves are owned by a rolling stock company and are leased to the rail operators. This suggests to me that when people ask why they can't put more trains on routes that are overcrowded, it is not that simple as that, even if there is spare capacity on the route, there might not be any more trains available to lease. Is this correct?
It's simply a term of the lease that has been agreed, that the lessor (the TOC) can livery the train. In most cases, they have to remove at least the branded part before returning the trains (in theory) at the end of the lease.If the trains are not owned by a rail company and are owned by a separate company, how is it that the rail companies can put their livery on the trains? I would have thought that if the trains are leased, they would all be some neutral livery, but evidently there is some flexibility for rail companies to make alterations.
Will Milton Keynes be responsible still for charter planning or will this go to the regions?
Doesn’t train planning need to be at top level due to the trains crossing boundaries?
In terms of system operator/regulator boundary I was thinking in terms of path allocation type stuff.
when you reorganise, you bleed. Gerard Feinnes
the franchise agreements between the DfT and the TOC's will specify the level of service and by implication the number of units to provide that. If more units are needed then that will be an increase in costs to the TOC, and they will say to the DfT, if you want us to run more trains, that means more subsidy. If the DfT say no, then they have to do with what they have.Thanks for the info. If there is a shortage of a particular type of unit, can't more units be ordered and manufactured?
Except he never said it. He attributes that quote in his book to an unnamed speaker at a management course he attended.when you reorganise, you bleed. Gerard Feinnes
Many are on order, but they take years to arrive and be tested.Thanks for the info. If there is a shortage of a particular type of unit, can't more units be ordered and manufactured?
However with modern technology and communications this should be less if a problem. Many schedules do not pass a boundary (the vast majority I’d suggest), so by centralising in MK a lot of local expertise was lost in an attempt to provide this national co-ordination.
Unquestionably. However it has been several years now, and the experience has been built back up again,
Because the terms in the lease allow them to do so, just like they is done for thousands of lorries, vans, buses and cars that are leased. And one of the reasons vinyl wrapping has become so popular on commercial vehicles.
(An example is all the Network Rail vehicles; these are leased but are sign written)
