Motive power in Wessex area in the 1980s
alistairlees
29 Dec 2016
Often had a 47 on it, but a fortnight after 31 appeared, a class 46 Peak did it and I got to ride behind it from New Milton to Brockenhurst. My one and only Peak hauled service train on Southern Region. I think it was July 1978. Somewhere I have a photo of it.
Can you dig the photo out? Would be good to see that one. Peaks on the Southern were super rare.
big all
23 Sep 2018
redhill
This is an interesting subject which I often ponder. One thing which strikes me if the S&D had survived is that in the 1986/7 era there were a lot of Hastings DEMU's and 4TC units going spare as a result of the Hastings and Weymouth line electrification schemes.
It strikes me that if you'd matched a Hastings power car with half a 4TC, you'd get a 3 carriage DEMU with 2+2 seating and vestibule connections throughout. In other words, ideal for a longish cross country route, but possibly with the need for access by a conductor-guard due to several unstaffed stations. If you put two together with the TC driving trailers facing inwards, you could have five carriages of accommodation all accessible to the guard - an ideal unit for a surviving S&D !
Unfortunately, EMUs with a 27 way control jumper were not compatible with DEMUs with DEMU jumpers, so they were not able to run in multiple.
Yes it was quite simple to alter the jumper and the connections over a few days or hours to allow some sort of compatibility between 'Thumpers' and EMUs, such as a 'Tadpole' or 1111 unit, as the refurbished unit with ability to connect to EMUs for a through service to London, with a 27way jumper rather than a 'Thumper' jumper.
Yes, the tadpole units must have needed some work as the traileer was from an EPB. Nothing too expensive though.
big all
23 Sep 2018
redhill
as an aside
if you look at a picture off the early 73s "JA" 73001-6 they have an extra jumper socket that was a thumper socket for coupling to demus on the secondmans side
randyrippley
21 Feb 2016
big all
23 Sep 2018
redhill
Dunno how true it is, but this section of the Wikipedia article on the class 73 fleet in interesting
https://en.wikipedia.org/wiki/British_Rail_Class_73#Multiple_working
Basically it says that two of of the 27-way wires on the DEMU fleet were crosswired, resulting in the direction of movement being reversed
by crosswired you mean diagonal then yes but only as far as the low level blue star jumper are concerned as high level jumpers are only jumper one loco or unit facing a socket the other side so cant go wrong
with the low level you only have the sockets with a jumper and extension air hoses in the engine room
if you crossed the jumper diagonally things like locos go different ways and compressors work continuously but would never get anywhere sf f/f kicks in [faults and failures]
randyrippley
21 Feb 2016
I think you misunderstand.
What I take from that wiki article is that on the DEMUs two of the wires in the high level jumpers were incorrectly transposed internally making them run in the reverse direction compared with the settings on the EMU fleet.
No idea if its true...
Cowley
15 Apr 2016
Devon
I think I’ve heard that that would happen as well.
big all
23 Sep 2018
redhill
As they are not physically compatible, it won't matter.
EPB EMU emu stock have three indicator lights:
  • Green = Electro Pneumatic brake
  • Red = Line
  • Yellow = Motor Generator [providing 90-110volts ]
Regarding Thumpers, I cannot remember if they have a green EPB light or not, but yellow is oil priming pump, which illuminates with the master switch away from off.
You also have the red light which illuminates if the engine is not running; you then crank the engine until it starts and the red light goes out.
The yellow light goes out because the mechanical engine oil pump takes over.
You also have engine start and stop buttons and many other differences which prevent an easy coupling. However permanent coupling like to a "Tadpole" unit would be easy enough as you are making things do one job, not more than one in different modes.
nw1
9 Aug 2013
I suppose that would be an option, although loco-hauled seemed to be going out of fashion at that time.
I must admit, I only thought DEMU's were only used on Waterloo - Salisbury services in extremis !
I do seem to remember (perhaps, not 100% sure) that one of the Saturday Waterloo-Salisbury diagrams around 1983 - possibly summer only - was formed of 2x3H; the other being a 33+TC.
Mon-Fri I more definitely remember that of the two diagrams, one was 33+TC and the other was 33+MkI stock. There might have been a third (33+TC) diagram too but given Waterloo-Salisbury and return could be done in well under 4hrs and the Salisbury terminators were two-hourly, alternating with Exeters (50+MkII at that time) I doubt it did anything off-peak; this third diagram was probably peak only.
nw1
9 Aug 2013
Yes, with 4VEPs on summer weekends (or occasionally a 4CIG)
Definitely remember on the Network Day in June 1986 the shuttle unit was a 4VEP. There was also a through London working in the 1980s on summer Saturdays only (10:00 off Waterloo, 8VEP IIRC) which would run in the path of one of the shuttles, the shuttle unit sitting at Brockenhurst while the through train was down the branch. I *think* the shuttle was only hourly at that time, but not 100% on that. Also ISTR on Sundays it extended back to start from Eastleigh - the "93" weekday slow from Waterloo-Bournemouth being covered on Sundays by as many as four services: a Waterloo-Basingstoke stopper; the Reading-Portsmouth making the Micheldever and Shawford calls; Eastleigh-Lymington; and the Waterloo-Bournemouth "92" covering all stations beyond Brockenhurst.
In the 1990s the shuttle was a "normal" 4VEP 7 days a week, then may have become a regular CIG around 2000, before the dedicated three-car units came in later.
PG
Could Radstock have been retained by somehow diverting the northern part into Bath Spa along the main GWR route? I would agree that this is an area which surprisingly lacks a rail connection, given its proximity to Bath and Bristol.
Looking at a map
https://osmaps.ordnancesurvey.co.uk/route/3647843/Sustrans-Bath-to-Bournemouth
(zoom in at the Bath end and you can see where the S&D crossed over the GWR about 300 yards west of Oldfield Park Railway Station immediately adjacent to Bellotts Road) it doesn't appear impossible to have made a connection to/from Bath Spa though some redevelopment may well have been required.
30907
Looking at a map
As the climb out of Bath and the tunnel were notorious, that wouldn't have made much sense, and the GW sration wasn't and isn't a suitable terminus point.
I believe Midford to the GW at Limpley Stoke (using the "Titfield Thunderbolt" branch) was suggested, but TBH using the GW into Bristol would have been more useful in some ways, though that was just as steeply graded as the S and D and buses had taken most of its passenger traffic.
