MSTS Problem
devon_metro
11 Oct 2005
I have a problem with MSTS. Sometimes when running an activity MSTS closes without any errors, meanong i have to start it again. The problem is frequents.
Secondly in Dorset Coast 'Weymouth Wanderings' does not even load because of the above.
Also MSTS looks for train consists from activities i have deleted.
Anybody know the problem?
Thanks
EDIT: for example, Weymouth wanderings loads showing the voayger cab, then after about 2 seconds packs up.
MSTS Looks for trains like the FGWL 166 although i have no activity installed that uses this train. :x
Coxster
9 Jun 2005
Could be to do with the services.Trainstore is best option for MSTS in general.
devon_metro
11 Oct 2005
I tried trainstore, this eliminated the train errors, althouth the activity 'Weymouth wanderings' did not. All of the others work on Dorset Coast
Jonno2055
9 Aug 2005
Essex
I hate it when that happens, it happens to be on very detailed, complex routes:
Southern Region
LSE
LBE
BrightonProtsmouth
ETC
I ususally just load it up and try again but if that activity isn't working you may have to give up, or reinstall if you haven't already.
devon_metro
11 Oct 2005
Southern Region
LSE
LBE
BrightonProtsmouth
ETC
Yer it is quite annoying, only one route activity seems not to work, probably the most complex of them all, A shame as i wanted to do that activity! So it is a MSTS Problem, thank god for that!
Coxster
9 Jun 2005
Did you install any activities from UKTrainSim in conjunction with using the Dorset Coast v2 CD? DO NOT do this. They're not designed to work in conjunction with eachother?
