JamesHorrell
Hello
I've Just Set up my Railway which is the 2 loops and a siding which Hornby Do and i put my Hornby R602 Power Clip in and i tested it all out and it all ran but as soon as i tryed it with one loco o the outside and one on the inside loop and sthen gave them a little power the outside one moved but the inside one didn't, so i checked the loco had it power pick up on the tracks and it did so i tryed again and i had the same result one moving and the inside one not, so i switched the points and the inside and the outside one move but as soon as i switched the points back the inside one stopped dead and wouldn't move.
I Thought its was The Power Clips which had Stopped Working so i took half the inside loop and the power clips out and ran the track with the outside loop and half the inside loop connected by 2 points and to test it i ran one loco around the half inside loop and i switched one points and let the loco run over it and then left that one open and switched the other one and the loco stopped dead so i switchedone point back and it ran again.
So to Run something around the Inside loop i have to
1)switch one point
2)let the train run over that
3)close that point and swicth the other one
4)let the Train Over And switch it back.
Now Having my Baby Cousin sleeping over on Monday Night i want to fix the problem so he can play with it with me.
So can anybody tell me what has broke and why it isn't working??
1)switch one point
