So they delay vital upgrades yet continue to pump money into HS2??
Well, that might be because the issues facing the "vital upgrades" are different from those facing HS2.
It's a non executive position. He shouldn't be involved in the detailed planning of infrastructure projects.
At a time when everything is being cut to the bone, the money planned for HS2 isn't palatable. No matter which of the departments spends it - public opinion will give them a massive battering. I never said the money will be diverted to the current network
Mr McLoughlin seems a little confused.
He says:
And then says he's 'pausing' large chunks of that investment. Seems very odd.
And what does this mean for rolling stock on the MML? Refurbished HST? LHCS? Bi-mode IEP running in diesel mode?
]It is slightly odd that the money can be found for what might arguably be a vanity project while the money can't be found to feed the paups.
Will this impact on future projects such as Cross Rail 2, which is still in the design stage I believe.
Would it be possible to make infrastructure changes that were cheaper to put in or is that a false economy?
If the MML is not electrified, how does that impact o rolling stock and rolling stock contracts and/or cascades?
Where does the pause on transpennine electrification leave Hull Trains who were building their case for future open access agreements, and decisions on rolling stock, around them contributing to Selby- Hull electrification?
Commons said:Diana Johnson (Kingston upon Hull North) (Lab):
What does pausing trans-Pennine electrification mean for the privately funded initiative put forward to electrify the line from Selby to Hullwhich was, of course, missed out in his Departments original plans?
Mr McLoughlin:
The hon. Lady is not being quite fair, because I made some extra money available to take that route to the next GRIP stage. To say that we missed it out is slightly unfair, but leaving that to one side, I hope that the plans being developed will be acted on.
I also note the speech effectively reinforces the argument for building completely new high speed lines like they do in most developed countries. France has done so for thirty years. I used the LGV to the South of France in the summer of 1986. We might actually be waking up at last here in the UK.
I can see this being good news for HS2 and Crossrail2. I can see HS2 being extended across the Pennines to Leeds (bit off topic) rather than tinkering with the existing lines. Though electrifying the existing trans Pennine routes might free up some useful DMUs ?.
Talk of HST displaced from East Coast being used to provide temporary expanded capacity on MML while electrification delayed, presumably with a derogation for 2020 requirements.
This is the only mention in the statement:
And so they should. At government level, HS2 is as closely related to a duplication of the M1/M6* as it is to the MML and TP northern route.
* - but much better value.
Given the realisation that it's difficult to upgrade existing infrastructure and Network Rail are delivering late on projects, will they allow more time for HS2 and/or Crossrail 2 to complete and perhaps even start if there is now an admitted a shortage of skilled staff or high turn over? Is there a shortage of staff with the right skills?The biggest hole in rolling stock is, as I see it, for suburban type DMUs. For example to replace and augment Pacers and ageing Sprinters. The electrification scheme being paused now (Midland Mainline) would not have supplied the right kind of diesel trains anyway. There are speed improvements to be had on that route regardless of electrification.
Generally it seems to me that the only real backwards step is a pause on electrification after GWML.
So, the South is a priority for electrification but the Trans Pennine route isn't. There's a surprise.
From the full report in Hansard (referenced above):
Mr Patrick McLoughlin:
Anybody who goes today to Sheffields Victoria station will see a station that has been rebuilt as a result of this Governments investment.
eh???????
If there's new rolling stock to be announced, can we assume a lot more IEPs?
Why is GWML 'prioty' but MML isn't??
If the Midland Mainline was electric to London from Sheffield and Nottingham for example, the only diesels needed would be to serve Corby and the limited Leeds, Lincoln and Scarborough trains. Virtually eliminating most diesels.
The Great Western Mainline would still need many more diesels to run as it won't serve Devon and Cornwall and many other areas.
I think it's mainly to save the government from embarressment from IEP trains not being ably to run and partially political allegiences in Berkshire etc.
According to the BBC text but not the map, its only north of Sheffield that is shelved anyway. Certain logic in that given the present pattern of services (Leeds is only because of Neville Hill).
However that is of no use to towns and cities that don't have a station on HS2. If you take the MML as an example that includes Chesterfield, Derby, Nottingham and Leicester not to mention all the others.
because, simply, the work has reached a more advanced stage on GW and the resources can be focused on finishing that one off
He was doubtless thinking of Manchester Victoria.
