New Reston Station - Progress & Updates
Baxenden Bank
23 Oct 2013
There will also be 2 LNER services a day, 1S00 (06:22 NCL-EDB) and 1E30 (18:18 ABD-LDS).
Ah, thanks. RTT doesn't show the trains directly, you have to trick it by searching for Newcastle with 'later calls' / 'previous calls' 'Edinburgh'. I did a search for 'TPE only' to save wading through every train. That'll teach me for taking a lazy option :oops:
OxtedL
Quizmaster
23 Mar 2011
You can get it to show you the trains if you manually edit RESTON to RSN in the URL.
Currently RESTON is Reston GSP and for some reason RTT reverts to this every time you change the search criteria.
adrock1976
10 Dec 2013
Is Reston GSP (unsure of what the initials mean) and the site of Reston station the exact same place, or two totally different locations?
I know that Reston Signal EG402 (northbound) is closer to Berwick-upon-Tweed than Dunbar/Edinburgh, or the site of Reston station.
Also, I have noticed on the RTT pages for the new First Lumo services after the December timetable change that the line that would normally be Reston GSP is not there, but replaced with Reston (RSN) denoting the station.
D6130
12 Jan 2021
West Yorkshire/Tuscany
Signal EG402 is actually situated just North of the border at Marshall Meadows, about seven miles South of Reston....and is the first signal controlled by Edinburgh SC
(Grantshouse relay room - hence the prefix 'EG'). The corresponding signal in the Southbound direction is EG403 and they are both shown in the WTT as the mark the handover point to/from Tweedmouth box (TW).
adrock1976
10 Dec 2013
I believe it's 'Grid Supply Point'
Thanks both.
Are Reston station and Reston GSP the same location, as looking at the RTT website has the GSP before the timetable change, and the station (RSN) afterwards?
Thanks both.
They are not the same, although they are very close to each other. Reston (the station) is replacing Reston GSP as a mandatory timing point from the December change.
Railsigns
15 Feb 2010
It’s “Ground Switch Panel”, according to the SA glossary, on the track plan it’s adjacent to a pair of crossovers at 47m 14ch.
Is it an alternative name for a ground frame?
It performs the same function as a ground frame but has electrical switches instead of mechanical levers.
Thanks - it’s one of those multipurpose abbreviations of course, there will be grid supply points that use the same GSP initials, but I suspect they’re unlikely to be timing points…
hexagon789
2 Sep 2016
Searching GSP only seemed to turn up 'Grid Supply Point', seems a mistake to use the same abbreviations for different things!
Ripe for creating confusion.
pdeaves
14 Sep 2014
Gateway to the South West
Fine in theory, but where does one stop? All sorts of letter combinations mean different things to different people. MCB = miniature circuit breaker or manually controlled barrier (level crossing) or Markham Colliery Branch or Moulsecoomb station. Then there's things that also have meanings to, for example, emergency services with repercussions on the healthcare industry. And there will be other examples. Context tells you a lot (like grid supply points are not shown in the sectional appendix).
AIUI the grid supply points are also normally treated as part of the grid or distribution network, although they‘re often mentioned in a railway electrification context they are not really part of the railway’s equipment even when physically located alongside a feeder station.
Acfb
12 Aug 2018
Does anyone know when Reston is likely to open?
I would like travel to do it from Edinburgh when it does and visit nearby Eyemouth as well.
gimmea50anyday
8 Jan 2013
Back Cab
It's already marked as a station in TPEs crew schedules so I suspect it will be before the timetable change in May
Baxenden Bank
23 Oct 2013
This local newsletter (for local people) suggests a date, have no idea of their source or its reliability, so I did nothing with it re the new station calendar thread.
https://www.restonscotland.com/ Railway Station update - hopefully looking for a March opening, with an official opening in June - watch out for updates on this one!
InOban
12 Mar 2017
There's a bus every two hours along the A1 which goes in and out of Eyemouth.
The day I heard floating about was a Sunday, which could be rather embarassing given the current industrial dispute with the station's primary operator...
gimmea50anyday
8 Jan 2013
Back Cab
There are staff at both Newcastle and Glasgow train crew depots who cannot take part in the strike due to their job role so they may well be tasked with working those trains. I however remain hopeful that some sort of dispute resolution is entered in to before then
Baxenden Bank
23 Oct 2013
Soham station opened on a Monday due to engineering works on the Sunday preventing it opening then.
och aye
21 Jan 2012
I love the quote from the Leader of SBC. If only if it were that simple. :lol:
Meanwhile, Scottish Borders Council leader Mark Rowley says it's "shameful" that no ScotRail trains are planned to serve the station - despite the investment in the new stop in an area previously starved of public transport.
First train in more than half a century stops at Reston ahead of station's reopening​
A nine-car Azuma from Edinburgh has become the first train to stop at Reston in 58 years.
National operator LNER arranged the special service to Berwickshire to allow a series of safety checks to be carried out ahead of the station's reopening.
Onboard was a specialist team onboard who had just 15 minutes before the train had to depart to avoid holding up other trains on the busy East Coast Main Line.
As part of the validation exercise, as it is known in the rail industry, multiple compliance checks are necessary before passenger services can call at any newly built station.
These measures include checking the physical stepping distances between the train and platform for all 18 passenger doors, as well as to confirm that other access and sighting requirements have been satisfied from a customer, driver and onboard perspective.
John Doughty, Engineering Director at LNER, said: “A lot of work from a number of teams across LNER goes into station platform and train interface safety validation. A time, agreed with Network Rail Scotland, and a train must be secured for the exercise, and a specialist team qualified to carry out the compliance checks.
“These exercises, though short, are incredibly important, as they relate to the safety and accessibility of our customers and colleagues as well as ensuring a smooth introduction to services at new stations. We will continue to work behind the scenes in preparation to serve Reston later this year.”
Although exact timings are to be confirmed, LNER is expected be the first and last train service each day to stop at Reston which is located approximately 50 miles south of Edinburgh Waverley.
GLC
21 Nov 2018
I’m surprise by the size of that step at a brand new station
davetheguard
10 Apr 2013
I think the train design is at fault rather than the station platform.
The DfT in its wisdom ordered their pet bi-modes that had to have space beneath the floor for diesel engines - I've read that as a result (Modern Railways?) the floor of the coach had to be higher up than otherwise would be required, resulting in a bigger step up from the platform.
hexagon789
2 Sep 2016
From memory all cars except the driving cars have a higher floor engine or not, but I understood that meant internally a slope up from the doorways rather than higher doorways.
CEN60
17 Dec 2018
The station is compliant to ORR / NR standards - the rolling stock is another matter! This also applies to “Legacy” rolling stock - as the vertical step tolerance changed a few years ago - it is not possible to build a new platform to the current standards to suit all rolling stock - although how the Azuma was allowed to be built not to comply is beyond me!
gimmea50anyday
8 Jan 2013
Back Cab
There is a noticeable difference internally between the driving cars and the middle cars of 80x stock. The floor is around 15cm higher in the centre cars and the step is noticeable when the train doors are open As the step is behind the door. Although the overhead luggage racks are at the same height the red driver buttons are underneath the racks in driving cars but on top of the rest. The slope is in the vestibule between the external doors and the corridor connection and is only there between the driving car and the first intermediate car
CEN60
17 Dec 2018
Harrington Hump to solve that problem?
The platform is compliant - does not need a hump! I repeat, the problem is the rolling stock (or certain types) - for many other types, for instance 380, 385 etc the step will be compliant. How East Linton will Fare is anyone’s guess - planned to be built on a non compliant reverse curve!
