That's correct.So are all the SWR station staff at Guildford staying with SWR and not TUPEing to NR?
Wow, while I expected changes I never thought they'd take on board concerns to such an extent! I and others lobbied hard about the reduction in services at Martins Heron and the reduced AM peak service through Ascot so I'm well happy with the outcome.The December 2018 timetable consultation report has been published internally, but does not seem to be available on the SWR website yet, so I will summarise they key outcomes below.
Hounslow/Chertsey/Windsor
Queenstown Road
- The consultation appears to have pretty universally rejected SWRs proposals.
- The current Waterloo-Weybridge via Hounslow service will continue to run all day.
- Waterloo-Windsor will remain at 2tph Off Peak to accommodate the Weybridge trains.
- Waterloo-Windsor up to 4tph in the peak.
- Links between Sunnymeads and Wraysbury, and Feltham and Richmond, maintained at the expense of journey time improvements.
Martins Heron
- 8tph service maintained at Queenstown Road, not cut to 6tph as planned.
Whitton
- Martins Heron to maintain at least the same service level as today all day. No cuts from 4tph to 2tph in the peak.
Camberley
- Whitton to maintain faster peak time services to and from London Waterloo.
- 3 morning peak fast services to London and 3 evening peak returns.
- Journey time of 28 minutes on fast services.
Farnborough, Fleet, Winchfield & Hook
- Peak time through services from Frimley/Camberley/Bagshot to London Waterloo to be retained.
- 3 morning peak services, the same as today.
- 3 evening peak services, one more than today.
Southampton-Weymouth
- Accepted that both the original and altered proposal for peak time services to these stations attracted negative comment.
- Fleet, Winchfield and Hook to get 4tph to London in the peak.
- Farnborough to get 4tph to London in the peak.
- Connectivity between intermediate stations along the route maintained.
- These changes are at the expense of journey time improvements.
- Off Peak, one of the two Basingstoke-Waterloo stopping services will call at Clapham Junction, as now.
West of England Line
- 2tph London Waterloo-Weymouth service maintained all day.
- The slower Weymouth service to divide at Southampton Central all day.
- Front portion to call Bournemouth, Poole and all stations to Weymouth.
- Rear portion to call Totton, Brockenhurst, New Milton, Christchurch, Pokesdown, Bournemouth, Branksome, Parkstone and Poole.
- The proposed Portsmouth-Weymouth stopping service will run between Portsmouth and Bournemouth only.
- Sway, Hinton Admiral and Ashurst New Forest will lose their direct Off Peak London trains.
- 0540 Southampton-Waterloo to start back from Bournemouth.
- 0520 Poole-Waterloo to call additionally at Clapham Junction.
- 0635 Weymouth-Waterloo to call at Clapham Junction instead of Basingstoke.
- 0635 Brockenhurst-Waterloo starts at Southampton Central.
Clapham Junction
- Off Peak services to/from Exeter will continue to call at both Woking and Clapham Junction at the expense of journey time improvements.
- A Sunday morning stopping service will be provided between Salisbury and Basingstoke, extending non stop to Reading. This will run to/from Waterloo in the afternoon.
- Exeter services call at Andover only between Salisbury and Basingstoke all day on Sunday as a result.
- The lunchtime Waterloo-Salisbury-Westbury-Frome-Yeovil service will continue.
- 1625 Waterloo-Exeter/Bristol to call at Overton and Grateley.
- A limited number of Freshford calls on Bristol services.
- The majority of Bristol services to call at Oldfield Park.
- More stops at Whimple and Feniton.
- 0550 Exeter-Waterloo to call all stations between Exeter and Honiton, and at Woking.
Suburban Routes
- Despite much negative feedback, proposals to reduce the number of peak time calls at Clapham Junction will go ahead.
- This will allow more services to run to/from London Waterloo, providing more capacity overall.
Portsmouth Direct Line
- The first Guildford-Waterloo via Cobham service will arrive earlier, before 0630.
- The 0523 Farnham-Waterloo will call additionally at West Byfleet, Weybridge and Walton-on-Thames.
- Extra morning peak calls at Vauxhall in Reading-Waterloo services.
- 2 extra morning peak services at Weybridge, running non stop to Waterloo.
- A fast Waterloo to West Byfleet service between 1600 and 1700.
- A fast Waterloo to Hampton Court service around 1930.
Portsmouth-Southampton
- 2tph all day to call at Liss.
- Revised and additional peak calls at Liphook, Liss and Rowlands Castle.
- SWR are working with Wightlink to ensure connectivity and journey times to the Isle of Wight are maintained.
- Many of the new fast Southampton-Portsmouth trains will call at Netley and Woolston.
- An 0717 Southampton-Portsmouth stopping service to be retained with the same calling pattern as today.
I wonder if this will terminate in platform 1 at Bournemouth
4tph to Windsor all day was a requirement for the new franchise. It seems that following the consultation SWR have been able to change this to just provide 4tph in the peak.Does anyone know what the thinking behind 4TPH to Windsor in the peaks is? Can't really see the reason for it myself but there's a good chance I've missed something.
Gosh, I must respond more to consultations as I have achieved what I desired, namely Exeter to Waterloo trains to continue to stop at Woking and CLJ (for all we Gatwick bound pax). I hope my colleague from Overton is not disappointed as I see he has an extra stop on the 1625 ex WAT.
To be honest, as the 1825 ex WAT is sardine can conditions from CLJ until well past Basingstoke, I think I may await a later train in future.
Does start to make you wonder why the ITT was so prescriptive, if when push comes to shove DfT are happy to reduce what was apparently a set requirement.4tph to Windsor all day was a requirement for the new franchise. It seems that following the consultation SWR have been able to change this to just provide 4tph in the peak.
I thought there was supposed to have been some sort of consultation before the ITT. Perhaps they asked the wrong people - or it was ignored at the time. Wouldn’t surprise me because there always seem to be more people around to criticise after the eventual proposals come out...
I think that’s a very fair analysis. I wonder if they’ll learn anything from it...I think in the pre-ITT consultations they'd contact county and district councils, rail user groups, and organisations rather than individuals.
I'm not surprised that "faster journey times" would be one of the requests. And "connectivity" is a relatively hot topic (well, lukewarm, at least!). But at that point, no-one would stop and ask "You do realise that faster journeys probably means fewer stops, don't you?" or "How about a few more trains missing out Clapham Junction?" When the railway is virtually full, doing one extra thing inevitably means doing another thing less. People are used to the pattern of service they have, they shape their lives around it, whether it's where they live and where they work, or knowing that from west of Salisbury they can change at CLJ to get a train to Gatwick. When reality strikes in the form of "a faster journey means xxx is no longer possible", the individuals who weren't consulted in the earlier stages, or knew that something might happen but believed it would be better in all respects, or just didn't apply their minds to the issue, naturally get up in arms to protect the arrangements that suit them.
SWR still believe they will achieve journey time savings of 10 minutes between Waterloo and Weymouth. I personally believe that is a good compromise.....and the journey times being 14 minutes faster into Waterloo?
... So hopefully not too many bicycle spaces will get removed!
It’s difficult to see a connection between timetable changes and any interior layout changes, which I’d have assumed was a completely separate issue. However, have they ever explicitly stated what the bike space changes are?
No mention of Reading so can only assume that it will still get 4tph all day.Does Reading still get its proposed 4 tph all day? The proposed spacing was very uneven. Do we get nearer to every 15 mins if proposed missed stations are re-included?
The issue with Reading was the reduced service for Martins Heron and that's been addressed. 4tph all day has been a long-time ambition. As stated above the only reason that Windsor services remain at 2tph off peak is to make room for the retained Weybridge via Hounslow service.No mention of Reading so can only assume that it will still get 4tph all day.
The report also states that Windsor has been reduced to 2tph as a result of concerns expressed about the length of time the level crossing would be down in Datchet. Whether that is the real reason, or just a convenient excuse justifying the Weybridge through service remaining, I don't know.The issue with Reading was the reduced service for Martins Heron and that's been addressed. 4tph all day has been a long-time ambition. As stated above the only reason that Windsor services remain at 2tph off peak is to make room for the retained Weybridge via Hounslow service.
