New trains for Northern
Kite159
27 Jan 2014
West of Andover
Sorry, false alarm! I misinterpreted the track access application. The additional Newcastle to Morpeth services substituted for the planned to be removed Carlisle to Morpeth services.
Taken from this thread:
Increases:
 Morpeth- Newcastle – Increase in 13 passenger slots weekday and Saturday (including 1 morning peak) and increase of 1 on a Sunday
 Newcastle- Morpeth – Increase in 12 passenger slots weekday and Saturday (including 3 evening peak) and an increase of 2 on a Sunday (also combine 1 sat Newcastle-morpeth slot
and remove line)
Reduction:
 Carlisle – Morpeth – Reduction in 11 passenger slots weekday and Saturday and remove line
 Morpeth – Carlisle – Reduction in 12 passenger slots weekday and 11 Saturday – remove line”
Back to the idea of 331s to Morpeth, I think that they would be extremely useful as their superior acceleration to Sprinters would allow additional stops to be put in, such as Killingworth and Annitsford.
Breaking out the crayons, hand over Morpeth - Newcastle services to TPE which they can serve using the 802s.
So in the current timetable Liverpool - Morpeth (or Liverpool - Chathill)
Greybeard33
18 Feb 2012
Greater Manchester
Manchester Vic to Stalybridge will eventually (and sadly) be 769’s if the service continues to operate to Southport so that won’t be an issue
Preston to Victoria could be extended to Stalybridge. If Lostock - Wigan is also wired, Stalybridge to Southport could be cut back to Wigan and EMU operated. Likewise Alderley Edge to Southport could be cut back to Wigan and EMU operated, freeing up 769s to replace DMUs under the wires (e.g. Buxton and Rose Hill Marple).
Southport could be served by extending the Leeds to Wigan and Blackburn to Wigan DMU services, routed via Atherton.
Bigman
24 Feb 2011
Could Hitachi's not be an option? The body work could be re-designed to do away with end vestibule doors, and could they not offer 4 and 5 car bi-mode options? The higher speeds would also be useful, especially being able to run at 110mph between Wakefield and Doncaster and on the WCML. Plus, they would be assembled in the North too. Tin hat on!!
New build 195s are impossible, straight DMUs are too difficult politically and few people will want to finance them now the 2040 date has been announced.
153s, 155, and 156s can be replaced by 158s, 150s will just have to wait until electrification as end door stock is not a great replacement for them.
150s could be replaced by more 769s. OK, they aren't new, but they have modern, less polluting engines and can be used on the wires, and basically near enough are (in body terms) a double 150.
Would have to look at the Cumbrian Coast clearances, the only current stock that can work up there is 153 and 156 I believe.
Energy
29 Dec 2018
Lets wait for the 769s to enter service first... personally I would rather we get on and electrify and just keep the 150s going for a few more years.
Peter Mugridge
8 Apr 2010
Epsom
It shouldn't be too difficult to clear the Cumbrian Coast for the 769s though.
In the past, that line was C3 cleared for Mk3 stock and even the International Train as a diversionary route, so unless subsequent engineering work has made substantial changes to clearances, it's very likely only a paperwork issue.
If subsequent engineering has has reduced the clearances, you'd have to wonder who signed that off...
Whistler40145
30 Apr 2010
Lancashire
I wonder if Northern will have the same problem with Buxton services, several classes aren't cleared through Dove Holes Tunnel, and have 195s been cleared?
I don't think the engines on a 769 are powerful enough for the continuous uphill journey from Hazel Grove to Buxton.
Energy
29 Dec 2018
The 769s only have about 260hp per car, the 150s are still underpowered but have 286hp per car. 195s have double the amount of power of a 769.
Domh245
6 Apr 2013
nowhere
The initial modelling for the 769s was done for Buxton
To prove the concept would work, Porterbrook has teamed up with Wabtec/Brush Traction to develop a feasibility study, including detailed modelling work.
Simpson wanted Brush to really test the concept before any metal was cut, revealing: “I wanted to test it against the worst route I could imagine.” After speaking with Northern, she chose Manchester Piccadilly-Buxton: “It’s uphill all the way and has 12 stops.”
The ‘319’ Flex train performed admirably in modelling. It was able to complete eight return journeys per day to the current timetable, in effect performing like a four-car Class 15x formation.
quantinghome
1 Jun 2013
It would definitely help with Castlefield, but could potentially hinder the timetable at Shipley, as 6 car sets would overhang junctions preventing other services from departing
I've heard this many times but I'm not convinced. There looks to be enough room at Shipley for platform extensions, although it would mean spanning over the access road.
61653 HTAFC
18 Dec 2012
6x23m is the upper limit for Shipley platforms 2 and 5 without ridiculously expensive rebuilding (or overhangs). It's going longer than that that's the problem. I'm not sure what the allowances are however, so 331s being closer to 24m vehicles might be cutting it fine.
Neptune
29 May 2018
Everyone also seems to forget the issue of signal overlaps. The train might fit but it can still block a junction due to the overlap.
quantinghome
1 Jun 2013
Surely Platform 5 can be extended north-west up to the western end of Platform 2 without interfering with signal overlaps? Likewise Platforms 1 and 2 can be extended east up to the end of Platform 3 without affecting overlaps? The latter would require some form of structural support connected into the viaduct, but this has already been done to extend Platform 3 and doesn't look that problematic to achieve.
61653 HTAFC
18 Dec 2012
The overlaps wouldn't change significantly from what they are today though would they? At present I assume you wouldn't be able to run a train from the Saltaire direction into platform 5 while platform 2 is occupied or have that train leave platform 2 once your ex-Saltaire service is berthed in platform 5... but that's the same whether the platforms are long enough for 1 car or 6. Surely it's still worth making the platform as long as possible- so that capacity per train is as high as possible and dwells are as short as possible. Are the overlaps that precise?
HST43257
10 Apr 2020
York
If 6 cars are really needed on the Bradford/Skipton/Ilkley routes, I’d suggest the entire Northern Class 323 fleet goes there.
Each coach is 23 metres long, so a 6 car would be ok. The lack of tables is not an issue on a commuter route like that. There are 17 3 car 323 units with Northern at the moment and a further 17 due to come from the West Midlands. This comes to 34 3 car units in total. If I remember correctly, there’s 15 full diagrams for those lines, so 30 units there in total. Of the 4 spares, 2 could be used to operate the Leeds to Doncaster, meaning all Neville Hill based EMUs are 323s.
tbtc
16 Dec 2008
Reston City Centre
Eleven including the class 153
Ah, good shout, I'd forgotten about them - haven't seen one for ages - forget they were still around (but then, I've hardly seen any trains as of late!)
To be fair that is 3 families of trains, Sprinters, Turbostars and Civities and although not sharing any parts the 170s can work with Sprinters. I don't really agree with your classification, the subclasses will have very significant amounts in common so counting them seperately is not fair. I would classify it as
  • 150
  • 153/155
  • 156
  • 158
    Half a point as not all 158s have the same engine but share other components
  • 170
  • 195
It's still a lot of classes, plus you'd presumably want to try to ensure that any doubled up 150s are made up of 150/2s (to ensure that staff/passengers could get between units) and try to allocate the three coach 158/195s to certain diagrams.
It just seems odd that the focus is on "simplifying the EMU fleet" (when the small number of Lancashire EMUs are operationally separate to the small number of Yorkshire EMUs) rather than thinking about trying to slim down the number of DMU classes (which are more in number and do mingle a lot more than the EMUs, given the cross-pennine services)
Ordering new diesel trains is politically impossible, ordering 195s would be very difficult with the 2040 date so close. The much better choice is electrification, have a look at the list of Northern routes operated by DMUs, you'll notice there are routes between big cities which aren't electrified such as Manchester to Leeds (although I think this is happening as part of Transpennine electrification, still not electrifying the whole thing though) and the Calder Valley Line.
Ideally we should be electrifying and then making do with existing 195s, 170s and 158s on the remaining routes.
I'm not suggesting we order pure DMUs, but we could do two things better (without additional electrification or new trains or anything complicated):
1. Rationalise the routes so that we minimise DMUs under the wires (e.g. Alderley Edge to Manchester currently has to be a DMU because it runs through to Southport... same with Manchester Airport to Deansgate having to be a DMU because it runs through Warrington on its way to Liverpool)... we could swap some through service patterns around whilst maintaining frequencies at each end... maybe we cancel the vast majority of Barrow/Windermere services south of Lancaster but use some of the resources "saved" to improve the frequency north of Lancaster... maybe do the same with some Carlisle/ Lancaster services south of Skipton
2. Rationalise the fleet so that you thin out the types of longer distance DMU - e.g. the small number of 170s could be replaced with an equivalent number of 158 carriages - there doesn't need to be so many different types (they all do pretty much the same thing - it's not like a 158 and a 170 have to be kept separate)
If it weren't for the nonsense of maintaining the handful of "local" stations beyond Morpeth then I think giving the Newcastle/ Cramlington/ Morpeth service to TPE would have made a lot more sense when giving them a path north of Newcastle - cramming in an additional "fast" path seems to make things even more complicated/ fragile, but replacing the Northern service pathed for a 156 with an 802 path would have been a better arrangement (and ensured that the TPE service had an "existing" passenger base from day one, rather than being pretty empty at the start)
The maths look pretty good - but I think that the Doncaster services would be better for doubled up 323s than Bradford - Ilkley - however unpicking the complicated interworking of the Aire Valley stuff may mean you'd end up having to run six coaches on Bradford - Ilkley whilst the Doncaster route took a reduction in capacity (which would be a shame, but possibly the least worst option?)
HST43257
10 Apr 2020
York
True. All Airedale stuff has to be 6 car as it’s all on one rotation in the diagram. If the other 9 WMR Class 323s are going into storage, could that just be 7, with 2 extra coming to Neville Hill? Otherwise you have 1 DMU diagram or a Class 331 microfleet based at Neville Hill, which must be expensive and complicated.
Edit: looks like WMR will keep them, but for what route/purpose? Surely they’d prefer more 730s to a 323 micro fleet
Jozhua
6 Jan 2019
Assuming no further electrification, there's not very much (319s) apart that really need binned.
The 323s are decent, and a big enough set that there's no problems with microfleets. They're also probably astoundingly cheap atm, given that WMT didn't want them and northern thought about getting rid of theirs. As above, there are so pragmatic issues (DOO and SDO) to replacing 323s with a new build, so in all honesty I don't expect them to go.
If you replaced the 16x4car 333s with 32x3car 331s, that would be great for capacity, but not so great for comfort. Personally I'd assume a program of platform lengthening to be announced to make such a swap easier, but that's not currently in the pipeline.
If more wires are getting strung up, that would be great, but remember that so far we don't know how far the wires are going to go. The lead time on knitting is significantly longer than the lead time for new rolling stock. It seems a bit premature to be discussing the purchase of new trains without knowing if there will be enough work for them.
But this is a bit of a chicken and egg style situation, so I guess something will have to change soonish.
Importantly, the 323's have a good passenger experience. And the acceleration is pretty good, although they are outclassed by the 331's these days.
I'm inclined to think that the simplicity of standardising on an entirely 3-car CAF fleet, run singly or as pairs, would have a considerable benefit.
If, for example, you could have everything on Castlefield running in that manner, you could mark door positions or even have pseudo-platform edge door fences which would help control the baying mob.
That would be nice. Longer train lengths have definately helped things on the Castlefield Corridor, as has electrification of the Bolton corridor.
I agree with this. Some services should retain tables though, perhaps predominantly express/long distance ones.
If I’m understanding correctly, you’re suggesting a fully 3 car fleet. Many services, particularly Leeds based, should definitely have 4 cars.
I would certainly extend all the 195s to 3 though. 2-car DMUs have no place on the mainline.
Ugh, those two car sets are a joke. Even during the COVID summer, I saw a number going through Castlefield that were overcrowded. There may be a few branch lines where they are enough, but a two car train going through one of the most congested rail corridors in the country is a bit of a joke really.
3+2 seating belongs in the bin. 2+2 seating but with more airline style seats with less tables.
Totally agree. I don't think the UK really has the loading gauge for it, the seats are far too small. I doubt after covid people are going to be comfortable being that shoulder to shoulder either. Plus, every time I've been on 3+2, people just put their bag on the middle seat to stop people sitting there.
Not sure why the surprise. Northern have consistently said they are looking to procure more new units - not so much in terms of capacity but to homologise their fleet to reduce operating costs significantly in terms of reducing staff training and maintenance costs. I would expect any more 195/331s to be a small order for bi-mode units.
Northern's passenger figures actually look relatively stable compared to other franchises such as long distance routes and London commuter services which seem to be most at risk from the effects of Covid and shift to WFH.
Yeah, the regional services have been holding up relatively well during the pandemic. I think demand will return for most places, but Northern had a decent resurgence of passengers during the summer, I was on some fairly busy trains then.
I think it is hard to predict exactly what changes will happen after Covid. Things may recover quickly back to the old normal, but more likely there will be a big economic shift. Wether this will be positive or negative remains to be seen, knowing the impact on travel demands may very well require a crystal ball. However, considering climate change and the impact on health from air pollution, expanding the availability and capacity of rail services seems like a very sensible option. Especially if cities want to use more space for active travel and to allow local communities to be a little less bogged down in traffic.
Its a pity no bidder for Northern wanted or was allowed to do a total fleet replacement in 2015, along the lines of Greater Anglia whose rural lines have had a whopping upgrade in rolling stock quality. 156 and 150's won't last forever
Yeah, the DfT probably wouldn't let the North have too many nice things. This is the same DfT that said replacing Pacers would be "poor value for money".
The 156's and 150's will indeed not last forever. They were looking pretty raggedy about ten years ago, and considering the lead times on rolling stock, you don't want to let them become too unreliable before you start looking at options for replacement.
  • 150
  • 153/155
  • 156
  • 158
  • 170
  • 195
Unfortunately, ordering new diesel units is politically impossible, but getting more electrification also is too. I don't know if gov expects the railways to run on fairy dust or something.
Battery technology is not going to get much better. Indeed, we are already essentially at the limit of it's capabilities now in terms of weight and capacity. Tesla showed off their increased volume of batteries over 10 years, marketing one as holding 50% more charge. When someone did the math, they found out the new cell was 46% bigger than the old one. So in reality, 10 years gave them a 4% boost in charge per unit volume.
Hydrogen does solve this problem, but introduces it's own inefficiencies and continued operational expenses. Ultimately, we're just going to have to bite the bullet on electrification sooner rather than later. The problems will resolve themselves as the logistics and engineering capacity grows and becomes more capable. Things will be rough to start with, this isn't something we have had much experience with in recent decades. But the results will be fantastic. Indeed, the bolton corridor now runs much longer, more comfortable, faster and greener trains than it did before. Even the 319's were an upgrade compared to the 150's on the line before.
The fact we have surplus EMUs flying about is testament to the fact they are easier to build, and they have a longer, more useful, working life. It is expected you can get about 40 years out of an EMU, Vs 30 from a DMU.
The fact Windemere still isn't electrified is a joke. It's a very short amount of electrification required, to get rid of a hell of a lot of running under wires. I'm sure it would be a fantastic selling point for those looking to visit the lakes in a more eco-friendly manner.
Kite159
27 Jan 2014
West of Andover
I always had an image of a 385 style body/interior on top of a 800 style bi-mode. Maybe 3 coaches with engines with a coach for the pantograph & equipment.
Ideal for Barrow/Windermere, even for services via Warrington Central.
(Although that image was for Scotland as replacements for 156s if the line towards Kilmarnock gets wired to work towards Carlisle)
And what doesn't help with the 2/3 coach 195s is some guards blocking off 2 thirds of the rear coach in order to do the doors due to the arrangement of door release panels.
61653 HTAFC
18 Dec 2012
If TPE has pretences of being an "intercity"* operator, handing them what is essentially a rural "social railway" service that just happens to share tracks with a 125mph main line doesn't sit right for me. On paper the solution there would be (leaving money aside for the sake of argument) to extend services to Berwick and run it hourly, or maybe two-hourly using EMUs with decent acceleration (331s ideally). Get rid of the extensions beyond Newcastle if they still exist, at least until Metrocentre gets wires or we have decent bi-modes.
*=for this reason, once the TransPennine upgrade is done I'd hand the Leeds-Huddersfield stopper back to Northern and run it with EMUs, be they 331s or whatever.
Wolfie
17 Aug 2010
That seems far too logical to ever actually happen...
Neptune
29 May 2018
Or use the 3 car 331’s in pairs that already have ASDO fitted as planned so that this route doesn’t suddenly inherit units that are 7 years older than the ones that have worked the route for 20 years that they replace.
Jozhua
6 Jan 2019
Is the Transpennine Upgrade still happening?
I can't keep up with scheme cancellations and empty promises, they come too thick and too fast
HST43257
10 Apr 2020
York
Fairly sure it’ll go ahead in some way, shape or form. Probably without some of the capacity relief and signalling upgrades planned.
Halish Railway
26 Apr 2017
West Yorkshire / Birmingham
Taken from post #3,511 of the TransPennine Route upgrade and updates thread:
The first OLE piles are in at Colton South Jn... https://flic.kr/p/2knutxf
...and Bolton Percy: https://flic.kr/p/2knzYqV.
At both locations, piles seem to be concentrated near the Up Normanton line. It also seems to me that (possibly due to Storm Bella) the OLE modification didn't occur at Colton, Copmanthorpe & Dringhouses - all of which are locations consistent with booster transformer removal.
Whistler40145
30 Apr 2010
Lancashire
I can't see why the line between Colton South Junction to Normanton would be electrified, I assumed that Colton Junction to Neville Hill was being considered for electrification, plus Hambleton West to Hambleton South Junction
HST43257
10 Apr 2020
York
Which bit is getting wired?
Fairly sure the plan is to wire YRK - MCV and the bit to Hambleton from Micklefield. Might as well go though to Selby/Hull (Hull for NPR prep) in my opinion. I’ve heard no mention of the Normanton route.
tbtc
16 Dec 2008
Reston City Centre
I'm not sure why you think there are "pretences" of being an InterCity operator - does a service from Liverpool to Edinburgh, stopping in Manchester/ Leeds/ York/ Newcastle not link enough cities?
All I was talking about was adding in a stop at Cramlington, in addition to the one at Morpeth, to replace the 75mph DMU paths on the ECML - that way you ensure that the "new" TPE service (north of Newcastle) has an existing passenger base and make things a bit more reliable overall.
(obviously it wouldn't have happened because we need to keep running a service to the "one man and his dog" stations beyond Morpeth, which really should have been closed many years ago)
Nothing (from Leeds) terminates at Selby though, so there'd not be much benefit.
However, it does make me wonder why the people wanting to spend hundreds of millions of pounds on "diversionary resilience" (i.e. re-opening some failed line) never bring up BR's failure to wire the Selby "loop" off the ECML - one of those little omissions that will have saved about a fiver in the eighties (like the "headshunt" at Morpeth)
