Greybeard33
Are you referring to the latest TfGM Local Rail Service Performance and Station Issues report? That said that:Network Rail have said they do not support ATW's plan for additional Airport services: http://orr.gov.uk/__data/assets/pdf_file/0003/20766/nr-rep-plan.pdf
According to TfGM ATW have now proposed taking over one of Northern's slots which will mean the all-stops service would go and one of the longer distance services would stop at all stations between Piccadilly and the Airport but they do not have the support of TfGM to do that.
This wording is confusing, but I do not read it as saying that ATW want to take a path off Northern. The NR letter you linked indicates that ATW has asked for an additional path to the airport, with the impact being to reduce headways and cut the turnaround time for the TPE Blackpool services.TfGM lodged a position in opposition to the application by Arriva Trains
Wales to secure a direct path to Manchester Airport at the cost of a path
between Manchester Piccadilly and the airport.
The UK DfT has also opposed the ATW application, in this letter of 18 Nov 2015 to the ORR. An interesting point from it:
See also this written answer of 5 Jan 2016 from Andrew Jones, Parliamentary Under-Secretary at the UK DfT.The key point here is that under the terms of the Joint Parties
Agreement that sets out the responsibilities of the Welsh Government (WG) and the
Department in relation to the management of the ATW franchise agreement, the
contractual right to consent to franchisee applying for particular access rights for Welsh
services is exercised by the WG. So, while Rail Executive has for some time been
aware of the aspirations of both the WG and ATW in relation to Airport services, we have
seen this issue as being properly a matter for the WG under the Joint Parties Agreement,
and ultimately for the ORR as arbiter where the industry cannot agree on the most
appropriate allocation of rights.
I would reiterate that Rail Executive does not dispute that ATWs proposal would offer
benefits to passengers in Chester and North Wales. The issue is whether alternative
uses of the available capacity might offer greater benefits.
Regarding the Northern stopper, after completion of the Hub in 2019, it appears that the plain is for Northern to have (off peak) 6 of the 10 hourly paths from Piccadilly to the Airport, with TPE having the other 4. 5 of Northern's paths will be taken up by Northern Connect services, to Cumbria, Blackpool, Liverpool via the Chat Moss, Liverpool via the CLC and Bradford via the Chord. So one of these Connect services will in any case have to call at all stations between Piccadilly and the Airport, in order to provide 2tph at the intermediate stations.
