LA50041
- Joined
- 20 Feb 2017
- Messages
- 2,167
66122/661264S44 1216 Daventry Int Rft Recep Fl to Mossend Down Yard
Two DRS locomotives (I can't think of the last time I saw two locos at the front)
Many thanks66152
it was indeed 377+249
66562Evening all, can anyone please identify today's 4M94 0750 Felixstowe North F.L.T. to Lawley Street F.L.T.? Passed where I was this morning exactly behind the Garston cars and unbelievably at the exact wrong speed with cars blocking the numbers both ends the whole way past me!!
Thanks Rhys.66562
Hi. Can you tell me what 3q99 was doing prowling around The Northwest in the wee hours of this morning and the traction please?
37421 | 96604 | 99666 | 72630 | 9806 | 62384 | 9701 |
66539Can anyone let me know what’s on7M29 Purfleet to Wembley please
Thank you
37421 96604 99666 72630 9806 62384 9701
66539
Morning,Good morning
Thank you for yesterday, helped me to get 350374 in.
Are 350263 or 350368 out today, and if so, what will they be working around 1500?
Many thanks again and thanks in advance
Reported in the class 701 thread as 701509Just saw 701512 at Clapham Junction. Does anyone know what it was coupled with? May have been 501 but not sure.
2G33 is showing as 507010 on its own.Hi,
Does anyone have the numbers for the 507/508s on the below services yesterday (02/03/23) please?
2G33 0949 Ormskirk - Liverpool Central (6 car)
2C26 1231 Chester - Chester (3 car)
Many thanks.
Very odd, was definitely a 6! Thanks very much for those!2G33 is showing as 507010 on its own.
2C26 was 508111.
Should be:Hello all
Please may I ask for allocations on the following TFW services as they don’t seem to be showing on RTT
1V44 Manchester Piccadilly to Tenby
1V48 Manchester Piccadilly to Carmarthen
Tia.
1V48 shows as 158838 on TRUST.Should be:
1V44 -175108
1V48 -150282
No problem must have set swapped since coming off Canton.1V48 shows as 158838 on TRUST.
Hello, does anyone know what worked 4L82 Basford Hall to Felixstowe in the early hours today?
377328 for Wednesday:No problem must have set swapped since coming off Canton.
Can I get the services/diagram/headcodes that 377328 operated on Wednesday (01-03) looks like it sat at Littlehampton for several hours.
Many thanks.
Beautiful! Now the berthing at Littlehampton makes sense. Thank you.377328 for Wednesday:
2U06 0641 Brighton - W Worthing
2U03 0722 W Worthing - Brighton
1S12 0801 Brighton - Ports & S
1S15 0933 Ports & S - Brighton
1S18 1100 Brighton - Ports Hbr
1S21 1229 Ports Hbr - Brighton
1S24 1400 Brighton - Ports Hbr: this was diverted to Littlehampton and terminated.
1S30 1700 Brighton - Ports & S: started from Littlehampton
1S33 1833 Ports & S - Brighton
1S36 2001 Brighton- Ports & S
1S39 2133 Ports & S - Brighton
2N72 2309 Brighton - Hove
2N73 2328 Hove - Brighton
2N74 2342 Brighton - Hove
2N75 2356 Hove - Brighton
Yes was due to driver shortage.Beautiful! Now the berthing at Littlehampton makes sense. Thank you.
Many thanks Turbostar
